Old 07-29-2013, 05:28 PM   #29
topazsparrow
Drives: slow
Originally Posted by mav1178 View Post
In case you don't know what a dual mass flywheel is:
http://www.zf.com/brands/content/en/...dmf_SACHS.html
The root cause (if this is happening when shifting into neutral) is either a ECU tune (most likely), or a bad transmission/clutch design that is prone to noise when load input is changed suddenly (least likely).
-alex
Is the FRS flywheel a dual mass as well? That certainly might explain the shakes the motor gets at 1650 - 1850 rpm in neutral... and the noise.
EDIT: More info about dualmass flywheels: [ame="http://www.youtube.com/watch?v=DbvP5EvpUbA"]ZF zms dual mass flywheel for passanger cars - YouTube[/ame]
topazsparrow is offline   Reply With Quote
Old 07-29-2013, 06:12 PM   #30
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's more of a "what manual car doesn't have dual mass flywheels" these days...
Ever since Aisin came out with the compact 6-speed RWD transmission, virtually all the cars running the Aisin 6-speed is running a dual mass flywheel.
-alex
Old 07-29-2013, 06:54 PM   #31
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Originally Posted by Rayme View Post
Yea but the MR2 is just a FWD drivetrain in the wrong side.
Nah, it is a FWD drivetrain on the RIGHT side!
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
Rayme (07-29-2013)
Old 07-29-2013, 09:29 PM   #32
Turk
Drives: 2012 V10 R8
Originally Posted by kALMIGHTY View Post
This happens to me. Climbing into somewhat steep driveways, I slow down but I don't want to downshift into 1st while the car is moving so I keep it in 2nd and go really slow and when I try to give it a bit of gas, I hear that rattle. Is this the issue you're talking about? If so, I'm concerned. I only got my car a 10 days ago.
Do your engine a favor and downshift into first.
Turk is offline   Reply With Quote
Old 07-29-2013, 09:37 PM   #33
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
-alex
But the FR-S doesn't have one uh
Rayme is offline   Reply With Quote
Old 07-29-2013, 11:02 PM   #34
kALMIGHTY
Drives: TRD Ultramarine '13
It's really hard to shift into first unless I'm completely stopped or crawling speeds of less than 5 kph. I mean, I can downshift into first at higher speeds but it requires a lot of force to get into to the gate, and it just feels like I shouldn't be doing that.
Old 07-29-2013, 11:13 PM   #35
Turk
Drives: 2012 V10 R8
I don't own an FRS or BRZ, but I understand the feeling you're getting, but I also think the engine is probably "lugging" in 2nd gear up the hill at low speeds.
Old 07-29-2013, 11:37 PM   #36
ShowTime_DW
Drives: FRS
Originally Posted by Sigh-on-Rice View Post
If you're talking about the noise that happens when you're in neutral, it might be the direct injection noise.
Thats what I am talking about!!!
ShowTime_DW is offline   Reply With Quote
Old 07-29-2013, 11:41 PM   #37
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Then it's not your transmission. It's direct injection. And it's normal. When I bought the car, the sales person explained about this noise to me before I left. I'm glad he did. I would've been worried too.
Overpipe rattle? Kregar Engine, Exhaust, Transmission 36 09-06-2014 04:58 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
