#85 | |
Waited 5 years for this
Drives: '18 MX-5 Club
I put 2500 miles since then and have 0 chirp. My car used to have this strange noise too, but that noise went away also after I got the new pump. But I would suggest to wait a little bit longer. I would feel comfortable if there is no chirp even after 5000 miles. |
#86 |
Drives: 2013 BRZ DMG manual Limited
Chirp came back! Original Pump was replaced with the green dot. Only took about 5 tanks of gas.
#87 | |
When was your pump replaced? Which gas station do you use? I had 10800 on original. Replaced on 5/22. I'm on the 8th tank now and only used Chevron. |
#88 |
Island Style Noob
Drives: 2013 Scion FR-S [Ultramarine]
Well, I do have the chirp now -_-
Definitely can hear it [it's still pretty quiet really] - filled up with 92E Tesoro gas and sure enough it manifested by the time I got home. Doesn't bug me too much yet but just knowing that it's not a "normal" noise a car should make will make me go for the replacement in the near future. I know Tesoro is pretty solid gas wise, but I think I'll probably try to hunt down a convenient Chevron location as I've always felt like my cars ran best on their fuel. If someone has a better suggestion for fuel, lemme know. That being said I actually have a call in to Aloha re: the E0 92 situation down Waianae side too so just for info purposes I'll post that here when they get back to me. |
#89 |
8SiX
Drives: FRS 10series
I've got the chirps, and it gets louder on Costco gas (I think they use the same stuff as Aloha or Tesoro). Chirps seem faintly more quiet on Chevron gas.
Weird, considering all of Hawaii's gas is supposed to be top-tier, right? |
#90 |
8SiX
Update on chirping. I've filled up with Chevron, and the chirping is definitely quieter.
Anyway, I brought my car in for an oil change today at Servco, and mentioned that I had a squeeking/chirping coming from my car. The service attendant said it's the fuel pump and they'll look into it. Hmm... Do they already know how to address this problem? The said my car should be ready in a few hours... It would be great if I can go back to using Costco gas. |
#91 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
#92 |
Drives: Raven FR-S
I gots the 'newest' pump, put about 600 miles on it and bam, noise came back. I might try putting two stroke oil in the tank, see what happens....
#93 | |
This seems to be so random. It works for some people and doesn't work for others. I got mine replaced in May when it had almost 11k miles on it. It's been 3.5k miles since then and I still have no chirp. I got mine replaced at Mapunapuna. |
#94 | |
| The Following 2 Users Say Thank You to DoomsdayJesus For This Useful Post: | John.Hong (08-29-2013), Sigh-on-Rice (08-29-2013) |
#95 |
Drives: Asphalt FRS
No point in wasting time to get it constantly replaced, until a true fix is out.
#96 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
If you have a tune, or a tuner that can help you out, stick E0 fuel into your car. It works for me. No chirps unless engine oil is at 205 for more than 40 minutes. As before, this issue may occur because of how the fuel pump strains when fuel pressure rises from engine heat.
~Matt
Efimia (asphalt FRS) |
#98 | |
It's on page 2. I don't know if anyone tried that. |
| Tags |
| engine chirping |
| Engine idle chirping (cricket) noise poll. | Hanzo | Issues | Warranty | Recalls / TSB | 5031 | 05-18-2017 09:41 AM |
| Engine idle chirping (cricket) noise poll. | Hanzo | BRZ First-Gen (2012+) — General Topics | 229 | 02-16-2016 01:21 PM |
| TSB Chirping | ngabdala | Issues | Warranty | Recalls / TSB | 10 | 11-04-2012 10:04 PM |
| TSB for Chirping | mankarn86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 09-28-2012 05:09 PM |
| Grasshoppers or Birds Chirping?!? | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-05-2012 01:29 AM |
