Old 07-29-2013, 02:10 PM   #15
swift996
swift996's Avatar
BUMP
Seems like there have been SOME (not saying it's a fact) reported issues with FA20Club, Motiv, and PLM.
Can anyone confirm the rest? Perrin did a sneaky job of picturing their over pipe without a sway bar attached to the car. @PERRIN_Chris ??
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-29-2013, 02:36 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by swift996 View Post
BUMP
Here is an old photo from when we were running the Perrin overpipe. We don't have any issues with the Motiv overpipe either...
Running a Whiteline 22mm bar up front.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
flippy (07-29-2013), ft86me (07-29-2013), swift996 (07-29-2013), whataboutbob (07-30-2013)
Old 07-29-2013, 07:09 PM   #17
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
As long as you're using the factory header, or header that ends in the same spot as stock, with our overpipe and our swaybar, you will be fine. There isn't a ton of room there, so with an aftermarket header or different bar, it might not clear.
PERRIN_Chris is offline   Reply With Quote
The Following 2 Users Say Thank You to PERRIN_Chris For This Useful Post:
Old 07-30-2013, 09:20 AM   #18
swift996
swift996's Avatar
I've ordered a Perrin over-pipe and will update with fitment on the hotchkis sway bar (25.4mm). I'm running the FA20club catted header so I'll cross my fingers on the fitment..hopefully it clears well. Being that close to engine heads I don't want the control arm or sway bar smashing into it under heavy compression of the suspension.
Old 07-30-2013, 11:40 AM   #19
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Keep us updated. I'm running the same header and sway bar as you. I feel confident its not the header cause I had the same noise with the stock header. I think it is just a little louder and happens more often since adding the sway bars. I'm gonna be under it tomorrow adjusting and perhaps spacing down the sway bar brackets like chutrain did.
FastLane1000 is offline   Reply With Quote
Old 07-31-2013, 09:33 PM   #20
swift996
swift996's Avatar
Barely clears but clears:
http://www.ft86club.com/forums/showp...&postcount=334
The Following User Says Thank You to swift996 For This Useful Post:
Hotchkis (08-01-2013)
Old 08-01-2013, 01:05 PM   #21
Pele86
Pele86's Avatar
Drives: Firestorm fr-s
Do you notice any rubbing or hitting?
Pele86 is offline   Reply With Quote
Old 08-01-2013, 01:09 PM   #22
swift996
swift996's Avatar
Nothing so far but have had it on for 12hrs.
Old 08-01-2013, 01:10 PM   #23
FastLane1000
The problem is not sitting still or at idle but when the motor is under load and it twists on the motor mounts. After adjusting I've got about a half inch of clearance now over the sway bar and its doing well under load in 1st and 2nd gear with no noises.
Old 08-01-2013, 03:47 PM   #24
swift996
swift996's Avatar
Update
Unfortunately after a further road test it does make contact with what sounds like the sway bar in 2nd gear from about 4.2k - 6.3k rpms and in 3rd gear for a little less time. This is under WOT. It's like if the pipe shifted the hump back about an inch it would be perfect. It's not violent but you can feel the vibration come up through the chassis.
Old 08-01-2013, 03:53 PM   #25
FastLane1000
You might try dropping down the brackets the sway bar mounts to like chutrain advised. Thats what I did yesterday. I spaced it down about 2-3 mm with 2 washers per bolt. I think what we've learned here is stay with a thinner solid sway bar when combining with an aftermarket overpipe
Old 08-01-2013, 04:01 PM   #26
ft86me
ft86me's Avatar
Drives: 2013 FRS
What size away bars are you guys running?
ft86me is offline   Reply With Quote
Old 08-01-2013, 04:11 PM   #27
swift996
swift996's Avatar
Is there a pic? I can't visualize how that would work in my head. It seems like it would move it forward/upward.
Old 08-01-2013, 04:14 PM   #28
qoncept
qoncept's Avatar
Here, not the ones you're thinking of. Pic from http://www.ft86club.com/forums/showthread.php?t=39003
qoncept is offline   Reply With Quote
The Following 2 Users Say Thank You to qoncept For This Useful Post:
mrjj (03-21-2022), swift996 (08-01-2013)
Wheel Directory: Forgestar F14 18x9.5 +38 empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-26-2014 05:24 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Body Kit with the most clearance? Sambo FRS Cosmetic Modification (Interior/Exterior/Lighting) 7 06-20-2013 01:47 PM
Driveway Clearance? topazsparrow Scion FR-S / Toyota 86 GT86 General Forum 17 06-14-2013 11:37 AM
BRZ front clearance a2cpc BRZ First-Gen (2012+) — General Topics 14 01-23-2013 07:38 AM
