Old 07-28-2013, 02:38 PM   #575
NickFRS
Drives: 2013 Asphalt FRS
The PDX cars.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
mxsled (07-29-2013)
Old 07-29-2013, 08:32 AM   #576
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by sw20kosh View Post
I have been told the dyno dynamics has two modes:
1. Comparison mode - #s like a dynojet
2. Heartbreaker mode - low #s
Depends on the calibration. DD is the easiest of all to correct / fudge. Only takes one keystroke ("x" then enter your desired correction factor).
The older models, like the one shown in this thread, if uncorrected will read about 15% lower than an AWD dynojet on AWD cars. They seem to read at least that much lower in 2wd mode. If stock twins are making 160 - 165 then this one has either been corrected or recalibrated by dynodynamics.
Old 07-29-2013, 09:17 AM   #577
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by ft_sjo View Post
Thanks. If we assume that dyno over-reads by about 10% (going by the N/A figures), then 220hp for the supercharged run sounds about right.
Don't forget, his baseline has a header-back exhaust and tune.
Old 07-29-2013, 09:28 AM   #578
xjohnx
Grip>Slip
xjohnx's Avatar
T minus 4 days to install! Tune from @moto-mike is in my inbox. Fuel pump and injectors should be delivered by UPS today. Innovate Supercharger should be arriving at @Pure Automotive 's shop tomorrow (I believe).
Looks like it's all coming together!
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
ill86 (07-29-2013), Ruckus (07-29-2013)
Old 07-29-2013, 09:45 AM   #579
Draco-REX
Corner Junkie
Draco-REX's Avatar
I am so far behind schedule. Still haven't been able to get the car in for the flywheel yet..
The Following User Says Thank You to Draco-REX For This Useful Post:
Subzero (07-29-2013)
Old 07-29-2013, 10:29 AM   #580
Subzero
Old...
Subzero's Avatar
Drives: Subaru
This I am anxious to see. It should brap straight to the rev limiter.
Subzero is offline   Reply With Quote
Old 07-29-2013, 12:10 PM   #581
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
This is a massive upgrade, I feel that swapping to a light weight flywheel transforms the character of this engine for the better.
mines13 is offline   Reply With Quote
The Following 4 Users Say Thank You to mines13 For This Useful Post:
ill86 (07-29-2013), sw20kosh (07-29-2013), Toyota86.ir (03-03-2016), Xero-Limit (07-29-2013)
Old 07-29-2013, 01:24 PM   #582
xjohnx
Grip>Slip
xjohnx's Avatar
dammit, i really need to block your account. Every time i read your posts i'm tempted to spend more money.
mines13 (07-29-2013)
Old 07-29-2013, 01:27 PM   #583
mines13
mines13's Avatar
You are not kidding, I spend WAY too much money as it is on my own stuff.
Old 07-29-2013, 02:01 PM   #584
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Why am I not married? Because I can't have a spare on the shelf. :happy0180:
The Following User Says Thank You to Subzero For This Useful Post:
ill86 (07-29-2013)
Old 07-29-2013, 02:13 PM   #585
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
My attitude about the dyno numbers is that it doesn't really matter if you compare apples to apples. Do a baseline and a post-install run on the same dyno and you will get a realistic percentage increase in your power. I don't bother comparing my numbers to other dyno sheets... but gives you an idea.
The Following 3 Users Say Thank You to DarrenDriven For This Useful Post:
ftc~brz (07-30-2013), NickFRS (07-31-2013), whataboutbob (07-29-2013)
Old 07-29-2013, 03:12 PM   #586
swift996
swift996's Avatar
Was there a verdict on the Perrin CAI?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-29-2013, 03:14 PM   #587
DarrenDriven
NW Region Moderator
My car and the Hot Lava car owned by @tech4pdx
The Following 5 Users Say Thank You to DarrenDriven For This Useful Post:
mines13 (07-29-2013), NickFRS (07-31-2013), Subzero (07-29-2013), whataboutbob (07-29-2013), wrxgoose (07-29-2013)
Old 07-29-2013, 06:20 PM   #588
wrxgoose
WUB WUB
Drives: 2013 Firestorm
now we need to get the two of them on a track to have some fun.
wrxgoose is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
