Old 07-28-2013, 11:04 AM   #15
kodyo
Drives: Scion FR-S
I got a small ding a month ago on my door and have been debating paintless dent removal. I like this better, so I think I'll use this to cover it up and use the ding location as a good locator for the strip to hopefully prevent this in the future. For what it's worth, my dent is about where you put your strip. Thanks!
kodyo is offline   Reply With Quote
Old 07-28-2013, 12:21 PM   #16
White64Goat
Is your car lowered or running bigger wheels & tires? looks good
Old 07-28-2013, 12:27 PM   #17
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
thanks! 1" drop on swift springs, Front 18x8.5 +33, 235/40/18, Rear 18x9.5 + 40 265/35/18 toyo proxes T1
shiumai is offline   Reply With Quote
Old 07-28-2013, 03:56 PM   #18
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
i wonder how it would look on pearl white
Minovsky is offline   Reply With Quote
Old 07-28-2013, 05:02 PM   #19
shiumai
shiumai's Avatar
Originally Posted by Touge86 View Post
why no sti side skirts
i'm not really enamoured by the look of the STi side skirts - i prefer the more subtle chargespeed ones or the prova ones. but, i'm not 100% sure i want side skirts otherwise i'd have put some on. i'm sure more styles will come out as time goes on.
Old 07-29-2013, 12:24 AM   #20
sumo junkie
sumo junkie's Avatar
Drives: WRB Series.Blue
I like it, goes really well with the car. You did a great job.
For those not wanting to stick something permanent on the car, I saw these on a car the other day. They're called Door Shox
http://www.doorshox.com/index.htm
sumo junkie is offline   Reply With Quote
Old 07-29-2013, 01:22 PM   #21
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
What kind of spats and rear diffuser you got on there. Looks sick! Even these door ding things look good on urs.
Say that 5 times fast "Door Ding Thing"
TONYpepperon1 is offline   Reply With Quote
Old 07-29-2013, 01:46 PM   #22
OrangeJuleas
OrangeJuleas's Avatar
Originally Posted by qoncept View Post
That looks a lot better than I would have ever thought. I think the dark color helps hide them. Probably won't try it on my WRB.
If you click the BRZ/FR-S link, I believe there is a WRB one that has these installed and it actually looks pretty good. (I can't believe I'm saying this! I've removed these on every car I've ever owned!)
I'm not insane, in fact I'm kinda rational, when I be asking y'all, "Where did all the passion go?"
OrangeJuleas is offline   Reply With Quote
Old 07-29-2013, 02:37 PM   #23
shiumai
shiumai's Avatar
Sti front lip and spats. diffuser is the copy of the OEM one.
Old 07-29-2013, 04:07 PM   #24
TONYpepperon1
Where did you get the copy from. I dont wanna pay 500 for the oem
Old 07-29-2013, 05:18 PM   #25
shiumai
shiumai's Avatar
you can get it from a vendor here:
http://www.ft86club.com/forums/showthread.php?t=29019
Old 09-07-2013, 05:22 PM   #26
kodyo
Drives: Scion FR-S
I was having issues with door dings (Already got two on both sides of the car), so bought these as well. Took 3-4 weeks to come in. Paint matched really well, but a few minor paint defects did exist, but nothing major (a few small pits). Took about 1 hour to install. Just some tips:
1) When using the bond promoter, don't push too hard when applying or it will drip and run down your door panel (promoter comes with trim). I had to use scratch remover to get the drip out.
2) Use painters tape to tape the trim to the door and then step back and see if you like positioning. I used the trim to cover a dent, so I didn't follow the dimensions given in the instructions. After the dent was covered, I measured from the door handle scoop and the side mirror to get the same height on the other side. Then use painters tape to mark where the trim is, and take off the trim (then use bond promoter etc. per instructions)
3) The gap between my small trim and large trim is a bit off from one side to the next due to my own fault (1-2 mm), so before you stick it, double check that it's exactly where you want it.
Overall pretty happy. Where I put them was exactly where the damage was on both sides due to door dings. I'm pretty confident this will prevent quite a few in the future.
Here's a pic installed.
Old 09-07-2013, 05:41 PM   #27
kba
kba's Avatar
Drives: FR-S Whiteout
My thoughts exactly^^. Looks great on your car, but I'm sure it would be awful on white. Sucks cause I'm super paranoid when it comes to people dinging my door. I park in egypt and for some reason people still park right next to me
kba is offline   Reply With Quote
Old 09-07-2013, 07:32 PM   #28
shiumai
shiumai's Avatar
i don't know - i think white on white would blend in just as well. the thing that gives it away on dark colours are reflections. on lighter colours, it's the shadow beneath the trim. i don't think it'll be much different in any colour.
Plastic protection strip on bottom corner of door sill robo_robb Scion FR-S / Toyota 86 GT86 General Forum 38 12-12-2015 12:11 PM
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 01:30 AM
Shoes Driver side door gr8scott Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 05-12-2013 09:22 PM
Door ding prevention! smbrm Cosmetic Modification (Interior/Exterior/Lighting) 16 01-29-2013 06:22 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
