Old 07-26-2013, 09:37 AM   #1
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Door ding protection - side molding
I recently got a door ding even with my best efforts to avoid them, so i decided to consider some door side molding in an attempt to protect the sides from dings. granted, the other car's door has to match up at a certain height for the molding to be effective, so it's not a 100% solution.
now, i really hemmed and hawed about adding 'sedan' door molding to my BRZ - i don't see any modern sports cars with molding. but i hate door dings even more. plus, the FR-S/BRZ door panels are so thin that they dent very easily.
when i did my research, i found that sportwing.com offers colour-matched molding for the BRZ http://sportwing.com/Subaru-BRZ-Body...013-FE-FRS-BRZ
and FR-S: http://sportwing.com/Scion-FR-S-Body...013-FE-FRS-BRZ
however, i could not find a single photo of the molding actually mounted onto a car anywhere. even the picture on the sportwing website looks photoshopped. so, i decided to be the guinea pig and take the plunge.
the moldings are made from ABS and are painted to order. took about two weeks from when i ordered the set until i received them. colour match with my DGM BRZ was perfect.
the set came very well protected with pretty good installation instructions. 3M adhesive tape is already applied to the backs of the moldings, of which there are two pieces per side - the long one on the door and the short one right behind it. like any other trim held on by adhesive tape, they're removable down the road if desired.
they're more subtle than i thought they'd be; since they're colour matched and quite low profile. if subaru or scion offered OEM side molding, it'd probably look like this. less garish than the modellista chrome side molding and much, much cheaper:
http://japanese-culture.ocnk.net/product/692
i was initially afraid that they'd spoil the lines of the car, but they follow the lines of the kick panel below, and also compliment the BRZ side vent garnish quite well, IMHO. not too bad and the unique look is growing on me.
of course, the molding is subject to damage, so i might 'protect the protection' with some xpel paint protection film (i've been buying that stuff and applying it myself to protect different areas like the kick panels).
i understand that many owners will never consider putting these on, and might hate the look, and they're not for everyone. but here are some quick snapshots i took right after installation for anyone considering these.
edited to add latest pics.
shiumai is offline   Reply With Quote
Old 07-26-2013, 10:19 AM   #2
qoncept
qoncept's Avatar
That looks a lot better than I would have ever thought. I think the dark color helps hide them. Probably won't try it on my WRB.
qoncept is offline   Reply With Quote
Old 07-26-2013, 10:32 AM   #3
Foobar
SLO NO MO
Foobar's Avatar
In my humble opinion, I don't think it looks bad. That said, YMMV on it actually protecting you from door dings. I used to have something similar on another car and my experience was that you can't protect yourself from all the different doors out there that will come in contact with your car at varying heights and angles. Thanks for showing what this could look like though!
Old 07-26-2013, 10:34 AM   #4
leon78
leon78's Avatar
Drives: 13 Whiteout
That’s tolerable...but on a lighter color twin I bet it would look like shit.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 07-26-2013, 10:48 AM   #5
nalc
Drives: 13 BRZ Limited 6MT GBS
Looks better than I thought it would, but I'd be worried about getting dings above it, with the large number of SUVs now.
My old LGT had the door strips, and they helped, but I got a fair number of high dings between the strip and the window, caused by large cars. And the BRZ is a bit lower.
nalc is offline   Reply With Quote
Old 07-26-2013, 01:27 PM   #6
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Has a bit of a retro look goin for it now.. Not bad on DGM..
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 07-26-2013, 01:38 PM   #7
shiumai
shiumai's Avatar
i'm gonna add two more right above the one that's there now to protect against higher dings.
just kidding.
single side molding = door ding protection
multiple side moldings = aero stabilizing fins
Old 07-26-2013, 01:59 PM   #8
DAEMANO
Time Traveller
Thanks for taking the plunge OP. The strips give the car more of a GT or executive look which ain't bad. Subtle.
Old 07-27-2013, 07:12 PM   #9
shiumai
shiumai's Avatar
a couple more 'nice' pics added.
Old 07-28-2013, 02:11 AM   #10
toysub
Drives: DGM
Looks clean. Thanks for the link.
toysub is offline   Reply With Quote
Old 07-28-2013, 02:36 AM   #11
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
why no sti side skirts
Touge86 is offline   Reply With Quote
Old 07-28-2013, 03:15 AM   #12
Tromatic
I do believe that's the first body mod that does not look like total ass. As was stated above, "subtle".
Tromatic is offline   Reply With Quote
Old 07-28-2013, 10:12 AM   #13
Mehaha
Drives: Mpv
Think not most necessary. Cos the car is low, most of the little bums would most likely be at higher level than protective strip.. Just my 2 cents of opinion
Mehaha is offline   Reply With Quote
Old 07-28-2013, 10:40 AM   #14
White64Goat
STI side skirts are like $672 +/- and that is just way too much for 2 skirts. Eventually they'll come down in price. Unless someone knows where to get them for WAY less.......
Plastic protection strip on bottom corner of door sill robo_robb Scion FR-S / Toyota 86 GT86 General Forum 38 12-12-2015 12:11 PM
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 01:30 AM
Shoes Driver side door gr8scott Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 05-12-2013 09:22 PM
Door ding prevention! smbrm Cosmetic Modification (Interior/Exterior/Lighting) 16 01-29-2013 06:22 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
