#1037 | |
So far zero problems without it though ![]() Sent from my HTC One using Tapatalk 2 |
#1038 | |
StatusLow
Drives: 2013 10 Series FRS
But I really don't want to use a stock air box. So I will definitely be making some custom brackets if I get this. I'll prolly polish the charger too.
Follow my instagram page @86_Nation
#1039 | |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
A lot of my vote towards the vortech kit was because its such high quality, even then I sent an email to vortech pointing out what I called "cheap and garbage looking components". Aside from the performance points I hit on, a few physical changes or additions would make this more pallatable.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | fenton (07-27-2013) |
#1040 | |
#1041 |
Driveway labs.
Any thought of running this off of a programmable water/meth controller? You could set an rpm range or throttle input range that this would run at say 2500-redline or 30%-100% throttle.
#1042 | |
Adding all this other stuff would probably put it in the price range of a turbo and he is shooting for less than half the price of the cheapest turbo. Sent from my HTC One using Tapatalk 4 Beta |
#1043 | |
StatusLow
Thats they way i would prefer Plus that lets me make my own brackets and customize it so it loks unique as well |
#1044 |
Drives: Asphalt FR-S Porsche 944e
@Wonderbar Try not to take this the wrong way, but it is my opinion that your posts here continue to be both negative and frivolous. Maybe you ought to think about moving over to the open source electric charger thread. They seem to be going down a little bit different path than Phantom. I think that product would be better suited for you. Don't forget that the title of this thread is "Full Throttle Electric Supercharger Build"
| The Following User Says Thank You to Danh818 For This Useful Post: | DAEMANO (07-27-2013) |
#1045 | |
Driveway labs.
| The Following User Says Thank You to Wonderbar For This Useful Post: | Danh818 (07-27-2013) |
#1046 |
Driveway labs.
Bro trust me, if you want to spend your money on this then that's what you're going to spend it on, I'm merely raising my own concerns, questions and spitting out a little of what I would do. Not once have I said that this is terrible and probably the most negative thing I've said has been that I think for direct comparison to capabilities is that nitrous is better.
I've gone as far to say and actually consider it as an alternative for running a high boost/waste gate option on my s/c to get a faster climb under 2500 rpms. If you're unable to take constructive critisizim about something you're doing then you're gonna have a hard time in life. Not everyone is going to love everything.
#1047 | |
With the electric setup we were making 180 torque as low as 2000 rpm holding tell 5500 Sent from my HTC One using Tapatalk 4 Beta |
#1048 |
Driveway labs.
To be honest I think it would be great for one of the fat turbos that don't spool until 4k or higher. Vortech makes power from 0-redline it could just use a little push under 2500 if for whatever reason you found yourself there.
#1049 | |
This is a torque plot plus boost plot vs a 9psi vortech kit running their base tune. Keep in mind this is before I was tuned so we have about 10 HP more on the top end . ![]() Sent from my HTC One using Tapatalk 4 Beta |
#1050 |
Drives: Scion FR-S A/T, Whiteout
So has a solution for the CEL under 3000 rpm on the stock ECU been found? Will there be a window switch included with the kit? The big selling point for me on this kit is that it can be safely run without requiring modification to the ECU.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
