Old 07-27-2013, 10:55 AM   #547
swift996
swift996's Avatar
Originally Posted by xjohnx View Post
is the pulley on these blowers a standard rotrex 8 rib pulley? If so, I've located the 70mm for $80... I could probably have one of these in hand before my install. @moto-mike @Pure Automotive - feeling adventurous?
Do it for science!
Some very solid numbers appearing (about what I was expecting). I wonder if these kits hate 102 degree ambients or if the OEM over pipe and cat back really choak the flow off.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-27-2013, 11:04 AM   #548
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by swift996 View Post
Do it for science!
I doubt the OEM catback is the restriction. @robispec is making good numbers with the stock exhaust, no? I don't recall what his exact power mods are, but I know @DeliciousTuning posted them the other day. I do remember that he was on the 70mm pulley, stock catback, stock injectors and a 65c.
If the guys at Underdog Racing respond to me and confirm it will fit (or someone takes a bunch of pictures of the stock pulley bolt pattern/ribs) and @moto-mike thinks he can safely adjust the basemap tune for the 70mm pulley, i'll grab one and have brady throw it on Friday.
I'm not sure if a new belt is needed or not though. Maybe robi or delicious can comment.
anything else i'd need (map sensor?) or should stock be fine?
Old 07-27-2013, 11:10 AM   #549
whataboutbob
AutoX-10/10ths every run
Added a new thread with some of my install notes here: http://www.ft86club.com/forums/showp...84&postcount=1
Build thread:Here
Old 07-27-2013, 12:09 PM   #550
PRE-Erich
Drives: 1981 Toyota Corolla TE72
Figured we would share a few of our results with this group.
First has mods listed in picture.
Second has headerback exhaust, stock air box, 92 octane pump gas with no meth.
Tuning another similar setup to the second one today except this one has the Perrin CAI and the ACT clutch setup. Will be interesting to see the difference.
Can't wait to see what these will do on pump gas with an intercooler!
PRE-Erich is offline   Reply With Quote
The Following 3 Users Say Thank You to PRE-Erich For This Useful Post:
djdnz (07-29-2013), mad_sb (07-27-2013), swift996 (07-27-2013)
Old 07-27-2013, 12:15 PM   #551
Silverstar
Drives: 2013 SS BRZ
how well did the meth combat heat soak? i.e. in consecutive passes how much power would be lost with meth compared to no meth?
I'm a fan of WMI but the gains here are not what I expected...maybe I just need to expect smaller gains since this is an overall smaller output motor. I was pretty spoiled with my Legacy GT.
Regardless, these are good numbers for this car and that torque curve (or I should say line) is killer. Can't wait for a Portland meet so I can see this kit in person!
Silverstar is offline   Reply With Quote
Old 07-27-2013, 12:28 PM   #552
PRE-Erich
Gains on supercharged and n/a cars are minimal because you simple can't turn up the boost like you would on a turbo car. As for the incercooling effect of the methanol the results were great with almost no heat soak and very consistent hp results on back to back runs. The install was a little tricky because it's boost activated which required us to tap a boost reference into the manifold. Luckily Innovate gave us a nice flat spot to tap a nipple next to the MAP sensor on the same plate. Worked very well and looks very professional. Today's tune will be the 3rd of these kits we have tuned each with a considerably different setup.
Old 07-27-2013, 12:29 PM   #553
mad_sb
Drives: 2013 Asphalt FR-S
You guys should offer a BRZedit basemap (editable by the personal version of course) for those of us that refuse to use ecutek
Old 07-27-2013, 12:30 PM   #554
PRE-Erich
Next Friday we have another one similar to the first car we are tuning. Really we need to get someone with headers to run Methanol so we can see a real apples to apples comparison of meth vs non meth.
Old 07-27-2013, 12:31 PM   #555
PRE-Erich
We will discuss this in our staff meeting next week. We have never offered e-tunes in the past for any platform for a variety of reasons but a base map may be possible.
Old 07-27-2013, 12:34 PM   #556
xjohnx
Grip>Slip
xjohnx's Avatar
Bet this would've helped:
Old 07-27-2013, 12:52 PM   #557
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by NickFRS View Post
We usually call it the heart breaker. Stock cars dyno 160-168 on it
That's where stock cars are at on a dynojet. So your numbers would be pretty much the same on a dynojet. Thanks. Great to see others getting 240+ whp without inter cooling.
Old 07-27-2013, 01:33 PM   #558
PRE-Erich
Haha, that is nice! Why couldn't they just ship the kits this way?
Old 07-27-2013, 03:59 PM   #559
xjohnx
Grip>Slip
xjohnx's Avatar
Nameless will have them available shortly.
Old 07-27-2013, 04:01 PM   #560
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by wrxgoose View Post
here's my baseline.
You had a baseline torque peak of only 85 lb-ft!?!
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
