Old 07-27-2013, 03:21 AM   #995
ft_sjo
Drives: GT86
Originally Posted by Fast_Freddy View Post
You may have missed it but a Vortech SC BRZ recently ran the 1/4 mile in 13.1s @ 111mph
Don't you mean a 13.981?
Old 07-27-2013, 04:06 AM   #996
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Exaggerate much? Instead of letting your emotions control your keyboard you should pay heed to those first two lines at the beginning of the thread. This little e-charger appears very promising for those who can't afford real FI but is no where close to competing with traditional super and turbo chargers. Neither will a stage 1 GTI "rape" or even keep up with a SC BRZ. You may have missed it but a Vortech SC BRZ recently ran the 1/4 mile in 13.1s @ 111mph.
Idk about the numbers now, but I was at the evasive dyno meet and two well known SC FRS's ran 203hp and 205hp.. And the bottom end was not even close to this.. Of course they make a bit more now.. But this is still in the tuning phase like those were
Gixxersixxerman is offline   Reply With Quote
Old 07-27-2013, 04:15 AM   #997
Fast_Freddy
Drives: Passat
No, I mean 13.1 @111mph with a Vortech kit on pump gas.
http://www.ft86club.com/forums/showp...&postcount=174
BTW, the innovate SC is already up to 255whp on pump gas.
http://www.ft86club.com/forums/showp...&postcount=515
Fast_Freddy is offline   Reply With Quote
Old 07-27-2013, 04:30 AM   #998
Fast_Freddy
Drives: Passat
I don't mean to knock this e-charger down below it's true value but IMO the marketing and fanboy BS is getting out of hand. I don't recall just how much dyno correction has been applied to compensate for the testing altitude but it must be significant to allow 1.6psi boost to equal 7.5-9.0psi boost.
If this little e-charger is equal to "over-priced $5000 fans with a pulley", let's see those 255-275whp dyno sheets and 13.1 @ 111mph time slips. Until then perhaps it would be best to speak about what this relatively economical e-charger is actually capable of.
Old 07-27-2013, 04:44 AM   #999
Gixxersixxerman
I personally think 230 will be about the most this will do, at sea level.. One dyno sheet was posted and it shows the power sap the SC takes on a engine as this was making the same power as the SC was at 5psi I believe.. I don't think anyone here is saying or suggesting this is as good or better then a proper SC TC kit.. Just an alternative to them for roughly half the cost.. Again, for what a good exhaust, header, and intake cost you can get something that makes decent power.. I'd love to do some testing here in Vegas and at the track.. To see how long it takes to deplete the batteries.. I'm thinking a lot longer then some people are guessing.. Even at the track I'm not full throttle that much.. Granted I'm wide open more the coasting.. But it's not like I'm wide open 1:20 seconds on a 1:30 second track.. I don't think this will run all 20 minute session.. But after about 5 laps my tires are roasted anyway.. So if this could give me three good laps, that's all I need for my time attack..
Old 07-27-2013, 04:49 AM   #1000
unijabnx2000
unijabnx2000's Avatar
Drives: Nissan
Thats an E85 run. What did it do on pump 93?
unijabnx2000 is offline   Reply With Quote
Old 07-27-2013, 05:01 AM   #1001
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
http://www.ft86club.com/forums/showthread.php?t=40850
latest run is 255 on 93. he just posted it up tonight
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 07-27-2013, 05:39 AM   #1002
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Wow such negativity on this thread at times. I'm sure this is why Innovate was keeping quite in the long build up to releasing their supercharger.
Step back, take a deep breath, and try to relax before posting.
Old 07-27-2013, 06:47 AM   #1003
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I don't know where the 1.6 psi figure comes from. Can you provide a citation? I believe 4.0 psi has been referenced by Fenton and it is thought that 5.0 psi would be achievable at SL.
Also keep in mind that the eCharger does not have any parasitic loss at the crank nor any significant pumping loss through an intercooler. Depending on the SC design, the parasitic loss on a SC is somewhere in the 1.0 to 2.0 equivalent psi range. So yes, the eCharger can have an equivalent effect of a SC in the 7.0 psi range. Where a SC is superior is at during increasing RPM, a SC makes more boost as rpm's increase where the eCharger makes the same boot over the entire range.
We are all looking for installation updates from the 4 new beta testers, some of which are at or close to sea level.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 07-27-2013, 06:52 AM   #1004
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Wow, lots of strong opinions in this thread....
- The Ancient BRZ Sacrament
by Zaku
Old 07-27-2013, 08:41 AM   #1005
Calum
That Guy
Drives: 2013 asphalt FRS MT
Check the boost plot in this graph.
Old 07-27-2013, 09:42 AM   #1006
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Haha, continue to defend with insults. Good way to be the "spokesperson" for a product.
I'm even complimenting this kit for what it is and where it works. It has a bottom end power and like a good turbo, but putters out up top, just like the avo kit with its baby snail. But this doesn't have big potential in the turbine itself to compete. That's all I'm saying. My opinion on it hasn't changed since my first post like 30 pages ago stands, it's an interesting build but I've found out its being done by people with a chip on their shoulder trying to prove something.
I was able to afford my toys because I've been deployed 10 months a year for the last 8 years. I also sold off several personal items to include very rare and personally built rifles. I work for my toys, I'm willing to sacrifice to get there. I also bought my BRZ used.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 07-27-2013, 09:51 AM   #1007
Wonderbar
Driveway labs.
Wonderbar's Avatar
Lots of hate and violent defenses.
Old 07-27-2013, 10:03 AM   #1008
utekineir
blowhard
Drives: frs, project forester
Originally Posted by Wonderbar View Post
I agree, again, I'm just providing a different perspective on it. I don't see why it shouldn't be a viable option once it is sorted out entirely. The limitations need to be very well known as well as what it is comparable to.
Who has nos on an eclipse? It's 2013. Nos is a shitty energy drink now, is it even still a shitty nitrous kit?
Fact of the matter is, a header and a tune will put a car not too far behind this kit, albeit this kit has a much better bottom end torque but not nearly the top end.
The appeal to this for me over a header/tune is the dealer apsect. Yank in a half hour and appear stock in the case of issues. This is only a year old platform, nobody has seen yet what issues may crop up over a longer period of time, fi or na.
If i wanted to dump in 30+ (mssrp brz/frs + mods) grand on a rwd sports car with no warranty a c5/6 or cayman would fit that bill far better than this car. For most people this isn't a race car. Its a sporty car, with some dd usability and good economy at a suitable price point.
I have one moneypit, don't need 2 (even though its starting to look like that will be the end result).
does anyone even drive eclipses in 2013?
utekineir is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
