#477 |
Drives: 2013 SWP BRZ
hm so back to my sti gas mileage basically
#478 | |
WUB WUB
Drives: 2013 Firestorm
#479 | |
Drives: 2013 Black FR-S
#480 |
Drives: Scion FR-S/Toyota Yaris
With the normal 91 tune I imagine timing is pulled and fuel added fairly extreme, I am thinking it would be a good idea to replace the stock exhaust manifold with an uncatted header, or have the EGT's proven to not be a concern with overheating the factory manifold cats?
Also looking at the 91-93 octane dynos I have to question is the throttle response on this kit really a lot better than the small turbo kits? Why all the choppiness? Comparing videos I'm not seeing the huge gain with positive displacement SC throttle response people keep talking about. Especially with these low boost levels is the difference even mentionable? The main reason the innovate kit is a nice choice is because it is a good bargain and should be very very reliable. The base kit puts you at a nice spot where you can keep the clutch and no injector or pump upgrades. There just seems to be a lot of emphasis on E85 and methanol with this kit but its main selling points to most are low cost of ownership, low maintenance, easy install, reliability, simplicity. I think a lot of us would like to see improvements with the pump gas tunes smoothness with headers and datalogs rather than trying to compete with turbo kits. There are a lot of potential buyers out there that just want a quick bump in power and as we are discovering the warranty on these cars is not very good, why not bolt on some FI and have fun!
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib Last edited by regal; 07-26-2013 at 06:27 AM. |
#481 |
Drives: 2013 Asphalt FR-S
If anyone has some datalogs from the basemap that is available with the retail kit.. please shoot me a PM. I have seen a lot of FI tunes lately that do not look very good at all and I would like to compare from a drive-ability and safety stand point.
I'm fine with people deleting the ignition timing and cam timing columns if HG or whomever does the basemap is worried about protecting their IP. I mainly want to see long and short term fuel trims as well as learned knock correction, IAM, and knock correction, MAP etc.
~Namaste~ |
#482 | |
x2 thanks
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#483 |
WUB WUB
my problem with using a different dyno, is that when I used a dynojet (build thread, first dyno run) it showed 174whp STOCK. seems a bit high to me, unless I really do have a freak engine.
#484 |
Drives: GT86
Is this thread only for superchargers badged up by Innovate, or can others join in the party?
#485 |
Grip>Slip
#486 |
Please see the OP
#487 |
You are preaching to the choir, he isn't known to be a good reader or able to take correct info/suggestion on board.
#488 |
Have you decided on your tuner/fuel supply route yet?
#490 |
WUB WUB
Dyno tuning right now, first run at 250.9, second did 243. We're letting her cool off a bit, then will get photo proof
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
