Old 07-09-2013, 01:10 PM   #29
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
This issue just started for me too. I have around 10,000km.
It only grinds (so far) when I do a rev match downshift from 6th to 5th.
When I downshift slower with a quick delay in neutral it doesn't happen but I need to be able to rev match.
Time to visit the dealer to check this and an annoying window clicking noise when it rolls down.
Hope it is not an inherent issue with no fix yet, but thats what it seems to be from what you all are saying.
EL_to_TBD is offline   Reply With Quote
Old 07-10-2013, 01:07 AM   #30
Wasabi
おい、だいじょうぶ?
Wasabi's Avatar
Drives: BRZ Limited 6 Speed
Damn, this happens to me as well... subscribed
Wasabi is offline   Reply With Quote
Old 07-10-2013, 01:18 AM   #31
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Originally Posted by RD1428 View Post
When downshifting Into 5th, don't force it place slight pressure and let it engage on it's own, it won't grind. ( not too good on explaining it) there was another thread about this
While I have known this to work for a while now, I still don't think it's normal to grind (even when rev matching) while downshifting quickly. My old T56 didn't do it.. Why should this?
tech4pdx is offline   Reply With Quote
Old 07-10-2013, 01:20 AM   #32
tech4pdx
Make love
tech4pdx's Avatar
Originally Posted by PCaddict View Post
for the 5 gear problem the dealer flush and change the oil but doesn't fix the problem now he waiting the authorization from toyota to replace the whole transmission
My hunch tells me that a trans swap will not fix this issue. Let them do it and let's see what happens.
Old 07-10-2013, 04:48 PM   #33
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Originally Posted by chae View Post
Try this and you will have 5th gear grind 100% of the time. Drive at a highway speed while in 6th gear, pop it out in neutral and let the rpm drop and attempt to put it back in 5th gear, you will grind.
Tried this today, no grind. When I put it into 5th from neutral, there is a little resistance getting into it, but I rev match and no grind.
Old 07-10-2013, 06:31 PM   #34
gvan1998
Drives: Blue FRS
Try without rev matching.
gvan1998 is offline   Reply With Quote
Old 07-10-2013, 06:37 PM   #35
Wes
Wes's Avatar
I have a feeling it would grind without doing so I don't really wanna try, plus that makes me cringe! lol
The Following User Says Thank You to Wes For This Useful Post:
ftc~brz (07-27-2013)
Old 07-10-2013, 07:50 PM   #36
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
It's kind of getting on my nerves that everyday I'm seeing more problems. This car was built for the track in mind. Shouldn't direct injection and transmission problems not happen on a car like this, especially a Subaru/Toyota? Dodge, I would understand. But come on.
husker741 is offline   Reply With Quote
Old 07-10-2013, 11:24 PM   #37
tech4pdx
Make love
tech4pdx's Avatar
@husker741
Try not to let the problems get to you too much. Although I was annoyed by the issues, I see them as part of the character of the car now. I have learned to work around the issues and not focus on them too much. It really is a unique car and they did a great job for a 1st year model.
The transmission will probably see some upgrades down the line. Any DI issues will be dealt with as well. Stick to it and it'll work out..
Old 07-10-2013, 11:34 PM   #38
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Dealership told me to bring th car back to the dealer. Toyota told the dealership to video record the problem and send it to Toyota Headquarters. A day later I get a response stating that there is no fix as of now, and take the car home. They will figure out a solution and give me a call. Its sounds like Toyota knows the problem exists but no solutions.
They take videos when they open a case file to find the issue a fix will probably come in the next 2-3 months
Old 07-25-2013, 11:31 AM   #39
gvan1998
Drives: Blue FRS
UPDATE
After calling Toyota several times complaining about the issue. They told me to take the vehicle to the dealer where a Toyota Regional Tech will test drive it. After the tech test drove it, They are replacing my transmission to a new on. But I cant get it installed now boecause the FRS transmission is on nationwide backorder and could take over 2 months. Service advisor told me that this is not a common problem and first she ever heard of, then why is the transmission on backoreder if no one else is having transmission issue
Old 07-25-2013, 11:35 AM   #40
gvan1998
Drives: Blue FRS
I dont feel comfortable with my new car with only 2000 miles having transmission replaced. Its like , newborn baby with a heart transplant
Old 07-25-2013, 06:07 PM   #41
BRianZ
Brian
BRianZ's Avatar
Drives: '11 Frontier CC & '13 BRZ Limited
I had this problem. I have another thread with my whole story. But to summarize here, I took my BRZ to my local Subaru dealer, they ordered a new transmission for me the same day. One week later, (yesterday) I got the car back. Better than new!
Edit: I almost forgot, the service manager at the dealer said that if I had changed the transmission fluid with something other than OEM fluid I would not have gotten anything from the dealer. It would have been blamed on the fluid and case closed.
Sent from my iPad using Tapatalk HD
BRianZ is offline   Reply With Quote
Old 07-27-2013, 08:16 PM   #42
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
So is the grind an actual grinding noise as if you didn't use the cluch or is it just hard to put it in gear? As for the fluid I guess you could swap before you go to dealer.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 10:39 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 03:47 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 06:25 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 03:41 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
