Old 12-11-2011, 01:19 AM   #99
caeavesrsx-s
Drives: 02 Swede
No one will make stock size rotors with aluminum hats I wouldn't think, and biggers ones would weight slightly less but need a bigger bracket and bigger caliper, which may or may not be lighter depending on construction, size, etc.
Already made! But will it fit?
http://www.dba.com.au/products/DBA5010BLKSL
caeavesrsx-s is offline   Reply With Quote
Old 01-02-2012, 04:57 PM   #100
Alfie
Alfie's Avatar
Drives: Sheeveek Si
In my 23 years of driving I've never had a flat,
but a doughnut is cheap insurance, otherwise i'd have to do CAA every year : (
____"In essence they're identical, and identically excellent." Ollie Marriage TOP GEAR____
Alfie is offline   Reply With Quote
Old 01-02-2012, 06:00 PM   #101
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Give me a spare. If I want to save weight then I will take it out and leave it at home while risking being stranded somewhere with a flat.
Rampage is offline   Reply With Quote
Old 01-02-2012, 06:14 PM   #102
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
What? No Triple A?
S2kphile is offline   Reply With Quote
Old 01-03-2012, 10:58 AM   #103
Rampage
Rampage's Avatar
And sit on the road for a couple hours until they get around to you? No thanks, that is what friends are for.
Old 01-07-2012, 02:29 PM   #104
SilentMike
Drives: 2013 FR-S 6MT Asphalt
My 06' Miata did not have a spare. I did augment the can of goo and miniature tire inflator with a tire plug kit. Luckily, all but one of my tire issues was a slow leak (nail, screw), that allowed me to inflate and limp up to Discount Tire to get it patched.
A full sized spare would be nice, provided the fronts and rears are the same size. I had a rare sidewall puncture on my front right tire on my current DD 08' Civic SI sedan. In the rain of course. Since the SI comes with a donut, and has an LSD, I had to jack up the right rear, remove the tire and replace it with the donut. I then lowered the car, jacked up the front right, removed the wheel/punctured tire, replaced with full sized wheel/tire from right rear.
The recently updated Scion FRS webpage specifies slightly wider rears. I hope this is a typo. It bugs me not to be able to rotate my tires.
SilentMike is offline   Reply With Quote
Old 01-08-2012, 11:43 PM   #105
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
I can't image a full spare tire fitting in the FR-S, but I would be fine with a doughnut.
iff2mastamatt is offline   Reply With Quote
Old 01-09-2012, 12:30 AM   #106
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Really? Because I can image it twice.
old greg is offline   Reply With Quote
Old 01-09-2012, 12:54 AM   #107
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
I think these pictures came after the initial show-down from Toyota side. Now, are these tires production ready?
I would guess that the purpose of these pictures is to show you how to carry that 4 track tires to the track. In DD mode, you get a donut spare tire with a nice flush cover at the back. When on track day, take off the donut spare and cover and then put on the first track tire in this spot and lock it. Then you can stack another one on top of it and the remaining two tires to the back seat. This may be the way that you could fit 4 track tires for track day.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 01-09-2012, 03:59 AM   #108
Levi
Drives: Toyota
Re: Would you want a spare tire in your AS1?
No, there'll be a subwoofer.
Levi is offline   Reply With Quote
Old 01-09-2012, 04:29 AM   #109
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Once upon a time my 19yr old house mate begged me to take him to Glendora Mountain Road (Los Angeles) just to take a look. He crashed his 350z into the curb going at 15mph. He didn't know how to change a damn tire. But lucky there was one cuz otherwise I'd be stranded with him.
Stigmaru is offline   Reply With Quote
Old 01-09-2012, 10:29 AM   #110
Levi
Drives: Toyota
Are not the stock Tires some Michelins like the Prius? We can see the spare tire is a Yokohama on stel rims. Interesting!
Old 01-09-2012, 02:29 PM   #111
iff2mastamatt
Feeling Iffy?
Well, if you put it that way, then I can imagine 4 spare tires .
Old 01-09-2012, 05:45 PM   #112
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
A donut is fine with me. I don't want a can of goo and compressed air, mainly because cleaning that goo off of the inside of the wheel is a pain when you do replace the punctured tire, and if it isn't cleaned off, it can make balancing that tire a real PITA. They also tend to go out of balance faster if you do leave the goo in there.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
spare, tire, weight
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
