#5853 |
Drives: Scion FR-S
I had that too, but I assumed it was because I didn't let the car idle for 5-10 minutes after I flashed. I cleared the dtc and haven't had a problem since.
Sorry this was in response to the cam sensor cel carwhisperer got. |
| The Following User Says Thank You to djliquidsteele For This Useful Post: | Carwhisperer (07-24-2013) |
#5854 |
Drives: 13' FRS, 95' Nissan 240SX
My kit supposed to be delivered today. Can't wait to get my first tune
#5855 |
Drives: Scion FR-S
#5856 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Hopefully not a stupid question.
I have installed header and fitted the O2 sensors directly to the header without any spacers, as the StG 2 tune would prevent any CEL. I run Torque Pro most of the time to keep track on how the car is performing, when I noticed the Cat temp up at 740 degrees, which is almost 100 degrees more than the car normally operates at. Would the increase in temp registered by the ECU, do anything to the car to counter the heat readings and possibly affect the tune performance.?? |
| The Following User Says Thank You to Ryan86 For This Useful Post: | Sensisnow (07-24-2013) |
#5857 |
I don't have experience with the BRZ but most likely it shouldn't. In everything I've worked with you truly disable the CEL, not hack your way around it.
| The Following User Says Thank You to qoncept For This Useful Post: | Ryan86 (07-24-2013) |
#5858 |
Drives: A lot of supercars.
Anyone using a K&N typhoon CAI?
#5859 | |
Drives: 05 TSX & 13 BRZ
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1 |
| The Following User Says Thank You to Sensisnow For This Useful Post: | Ryan86 (07-24-2013) |
#5860 |
Drives: SWP Limited manual BRZ
I just experienced Racerom for the first time tonight. Pretty decent drive. Launch control is amazing, so sweet how it is adjustable. Flat foot shifting?!?! It's too good to be true. The way it works, has that awesome blip sound... flat foot shifting is incredible. Finally... I still haven't mastered it, but the auto blip is very cool, I will have to get better at using it. Awesome stuff!
#5861 | |
Drives: Toyota GT86
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr) |
#5862 |
so im trying to flash my car and I try to open the file that john sent me and it says not supported whats up with this anybody know??
#5863 |
once I get to the part where it says load up rom file to program and I click the file that john sent me it gives me a error message and says the file is not supported and says to contact tuner for correct file
#5864 |
Drives: 2013 FRS
I would say open a support ticket with John and put priority as high
#5865 |
Check the log on right side and verify that the dongle ID that it shows matches the label on your dongle. My first dongle was mislabled, so the tune file didn't match the ID that my computer detected.
2013 DGM BRZ
#5866 |
the numbers match yea I guess ima do that was looking forward to getting off and flashing my car
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 02:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 07:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 01:42 PM |
