Old 09-24-2012, 03:29 PM   #15
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
LOL this thread is hilarious. I love that doggy collar on the car; now all you need is a whip and some vinyl spandex. Kinky level just went over 9000!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 2 Users Say Thank You to DaJo For This Useful Post:
pcporo (07-24-2013), Squishy86 (08-28-2013)
Old 09-24-2012, 03:32 PM   #16
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I know this a more expensive solution ($20 each) but the HKS filters have a magnet built into them
No Limit Motorsport is offline   Reply With Quote
Old 09-24-2012, 11:58 PM   #17
showbe
Drives: A nice one
Why not put these at the oil pan like what other posters have suggested instead of getting a filter mag. I remember another poster saying get like neo dynanium magnets and put them at the drain pan near hte drain plug. Wouldnt these work the same way?
I dont think getting a filter mag is worth it for its price when you can just buy a magnetic oil filter like HKS like the poster above mentioned. I also made a thread about tempest oil filters and was asking for opinions if anyone has ever used them since they also have magnets built in.
Since most metal shavings are at the engine break in wouldnt getting magnetic oil filter from HKS or Tempest and putting those HD magnets at the drain pan work just as well? I was going to ask this since I saw another forum mention putting HD magnets on the drain pan when I was googling K&N/Pure Power Reusable oil filters.
showbe is offline   Reply With Quote
Old 09-28-2012, 02:25 PM   #18
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Ghetto Magnetic Sump Mod.
Ok, the following picture may put to rest some people's concerns about a heated magnet in the engine bay(on a HOT oil filter/or Oil Sump).
That is a 15kg plate the magnets are holding up. I could have tried to put more but I don't have a bigger plate than that. I could spin(two times) the plate freely, albeit slowly with the magnet holding it up - WITHOUT the plate falling down.
I'm going to put these magnets on the sump next to my Fumoto valve.
stevo_12v is offline   Reply With Quote
Old 09-28-2012, 02:34 PM   #19
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
go go magnets!
mechaghost is offline   Reply With Quote
Old 09-28-2012, 02:45 PM   #20
stevo_12v
Installed!!
Before...
After!!
EDIT: You may noticed that I have put the magnets somewhat to the SIDE of the sump. There's a reason for that later.
Next oil change, I'll be taking off my F108N oil valve and do some more ghetto-modding on it to make it a F108S Valve :P
So the Fumoto will be taken out during the next oil change. I'll also be sticking a magnetic pick-up into the sump to get any shavings that are attached to the HDD magnets(on the side of the sump). Then simply sliding the HDD magnets OFF the sump so the shavings/particles can be attached to the magnetic pickup.
Old 10-01-2012, 05:55 AM   #21
CMOS
Drives: 2012 FUJI Z
Wherever you place the magnets make sure they do not come off after any length of use, very bad things will follow.
CMOS is offline   Reply With Quote
Old 03-25-2013, 08:10 PM   #22
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Such as? you've got my attention..
And OP, love your creativity
eurominican is offline   Reply With Quote
Old 04-09-2013, 10:16 AM   #23
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by ahausheer View Post
First off, those magnets despite being stronger than hell may loose a significant amount of their magnetic strength when heated slightly, not all magnets are equal in this respect. Second, they are going to hold stuff that is already going to be held by the filter. They are like a jail inside a jail, they don't do anything. If you want to use magnets effectively you need to capture material before it gets circulated through the oil pump and filter, ie, you need to capture it in the oil pan. Get a magnetized oil drain plug or put heat stable magnets in the oil pan itself. Also keep in mind most of the metal components are not ferrous. I like your thinking and creativity but I dont think this application is all that effective.
this. im working on an application at work using Neodymium magnets and we are having issues with them losing their properties after processing. if they are heated to a certain point they can permanently lose their magnetic properties.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 04-10-2013, 07:44 PM   #24
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Aside from the block...shouldn't all of the important bits be steel? Cylinder liners, pistons, piston rings, connecting rods, crankshaft, cam shafts, valves, springs, retainers, rocker arms. That's a lot of steel.
Mobius357 is offline   Reply With Quote
Old 07-10-2013, 10:59 AM   #25
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Does this work for aluminum engine?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-24-2013, 07:09 AM   #26
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Like several others here, I have no clue on the effectiveness of the famous Hard Drive Dog Collar Magnet Mod of '13, but either way, +1 to OP for creativity, resourcefulness, and comical new use of dog collars as well as tasteful color selection.
It would be cool if we could determine definitively whether this works or not.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
stevo_12v (08-03-2013)
Old 07-24-2013, 09:42 AM   #27
Mikem53
Drives: FR-S 6MT
Originally Posted by Hix View Post
Do people not realize that a HDD gets super fucking hot. These magnets were chosen for their extreme strength and durability when heated. Do you know how precise a HDD is? These are much better than some magnet sleeve. I am not sure what people think makes those magnets are to make them so special because they are not. Also they are ounces of weight, the shirt on your back weighs more.
HD drives don't run that hot.. Warm at best.. Nothing more than a spindle motor and a small servo motor for arm access.. Clever idea... Probably not very effective though..
Mikem53 is offline   Reply With Quote
Old 08-01-2013, 01:52 AM   #28
Drofnum
Drives: CBS Subaru BRZ
My server HD's consistently run at around 110-120f. While not engine oil hot its by no means warm at best. This is easily confirmed by installing any HD monitoring software.
My normal desktop is only slightly cooler than that since they arent spinning all the time.
Drofnum is offline   Reply With Quote
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
