View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-23-2013, 10:32 PM   #2395
thill
1400 miles and finally got the crickets. Running 92 octane Sams Club gas. They are mild compared to the waste gate rattle in my 13 Gencoupe......
Old 07-23-2013, 10:48 PM   #2396
hattrickey
Drives: Scion FR-S
I had my fuel pump replaced July 12th. The crickets went away for 4-5 days, however, I'm sad to report that they are back with a vengeance. Take this for what you will, but, I'm using 91 Octane gas (93 isn't available in CO) which contains ethanol. I would try the 0 ethanol gas, however, there isn't a station remotely close to my area which has it.
hattrickey is offline   Reply With Quote
Old 07-23-2013, 10:52 PM   #2397
dt's ft86
Drives: 2013 ft86
chirping
just about to break 300 miles and yes I have the same noise....
dt's ft86 is offline   Reply With Quote
Old 07-23-2013, 11:03 PM   #2398
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Originally Posted by Deepseadiver View Post
Third tank no problems
Fourth tank, started to come back, now on my fifth tank since having the pump replaced "green dot" and the noise is back, going to start filling up at the ethonal free pump. New pump did not fix the noise.
Deepseadiver is offline   Reply With Quote
Old 07-23-2013, 11:06 PM   #2399
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by sierra View Post
I know they say it can safely run on 91 but clearly 93 and higher is the fuel to use unless you get caught out somewhere with only low octane available.
Some people don't have access to 93 just like some people don't have access to E0. There is literally no where in Wichita that sells 93.
DylanFRS is offline   Reply With Quote
The Following User Says Thank You to DylanFRS For This Useful Post:
strat61caster (07-24-2013)
Old 07-23-2013, 11:08 PM   #2400
sierra
Drives: Skoda Yeti DSG diesel 4x4
How about someone organising a register with all the chirpers, FRS and BRZ, on it with names and rego. Then contact Scion/Toyota and Subaru with the numbers and demand a resolution or you take it to the press?
It's been well over a year now and they've done nothing to solve the problem.
sierra is offline   Reply With Quote
Old 07-23-2013, 11:14 PM   #2401
sierra
It must be very frustrating.
Maybe they should have set the car up specifically for 91 E10 for the US but then the lower official power output might have scared off customers?
The Following User Says Thank You to sierra For This Useful Post:
DylanFRS (07-23-2013)
Old 07-23-2013, 11:56 PM   #2402
thill
Keep in mind for folks in places like Colorado and Utah. They typically don't have access to higher octane gas in most locations because they are above sea level and air is thiner. Which means you have less air going into the cylinders. 91 octane above sea level is most likely the equivalent to 93+ octane gas @ sea level.
Old 07-24-2013, 12:03 AM   #2403
Sio86
Sio86's Avatar
Drives: Frs argento
weird sound
i got 752 miles on my frs and i start hearing weird noise! is this normal or should i go back to dealership or wait for my first oil change service.. i need help thanks!
Sio86 is offline   Reply With Quote
Old 07-24-2013, 12:18 AM   #2404
thill
Weird noise like crickets when you are idling in the car with the windows down? If this is the noise, I would note it with the dealership but there is no known fix, so even if they give you a new high pressure fuel pump, you will most likely get them again. One solution to try is if you have access to 0 ethernol gasoline. Try filling up with that. I am going to give it a shot as well.
Old 07-24-2013, 12:31 AM   #2405
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
So after I switched from Petro Canada 94 to Shell 91, the chirping stopped, as I previously stated.
NOW.. they are back :/ I'm at 3500k sooo 2000 miles? It sounds like belts to me
Wilso is offline   Reply With Quote
Old 07-24-2013, 12:32 AM   #2406
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Chirp chirp chirp... reported to Subaru, waiting for permanent fix.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 07-24-2013, 12:41 AM   #2407
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Mine went away after a few thousand miles. I'm at 10k+ now and it's completely gone.
denkigrve is offline   Reply With Quote
Old 07-24-2013, 07:38 AM   #2408
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
take what to the press? that your car makes noise? That will be front page on New York Times...
This is whats called a non-impacting issue. It does not affect performance or operation of the vehicle, no gurantee or promisory note was made as to the sound of the vehicle.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
The Following User Says Thank You to Grishbok For This Useful Post:
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
