Old 07-22-2013, 05:42 PM   #2927
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by DoomsdayJesus View Post
Not sure what Utah laws are, but contest the ticket in court and if the cop shows up, claim mitigating circumstances. If the cop shows up to court, ask to have it kept off your record, pay a reduced fine, for traffic school, or any combination of the above. Also, demonstrate that you passing him was safe to do at the time.
There should be more information online about contesting a speeding ticket in Utah.
I might, but since my record is clean and my time is expensive, it may be better to just take the fine. Traffic school online will already wipe the point from my record. I'll have to see what I can do though.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-22-2013, 07:56 PM   #2928
Seraph
0_o
Seraph's Avatar
Drives: 2013 SWP BRZ, 1995 Black M3
Yeah...I got my first ever speeding ticket in mine too... but I can't really fault the cop in my case... I was going...quite fast...and in California the show up in court thing is kinda annoying cus you have to show up the first time to plead guilty or not then, they schedule you for the "trial" where if the cop doesn't show up you MIGHT get let off the hook, so you have to go twice. I went with traffic school =/
Originally Posted by enwave
Told him that the problem with slowing down is that I'm still behind those bouncing pebbles.
As for the pebbles - consider Expel or 3M?
I got mine covered with Expel...full hood, partial fenders, partial roof...just areas more likely to get hit.
Seraph is offline   Reply With Quote
Old 07-22-2013, 09:02 PM   #2929
enwave
enwave's Avatar
I got the ClearBra, which helps, but I was also worried about my windshield. I guess I'm just a little overprotective. Gonna call them tomorrow and ask what the process for fighting it in Utah is, I'm originally a NorCal native so I'm not quite familiar with traffic court here.
The last ticket I got was in CA probably 10 years ago, speeding around a drunk driver. Officer pulled me over instead of him cause he saw me first and gave me the same treatment. Didn't bother fighting it then. Apparently I should be slowing down instead of aggressively avoiding things... But try to convince the BRZ to do that. It has a mind of it's own.
The Following User Says Thank You to enwave For This Useful Post:
chanomatik (07-23-2013)
Old 07-23-2013, 03:41 AM   #2930
Seraph
0_o
Seraph's Avatar
Haha, yeah I know - tell me about it!
Old 07-23-2013, 05:45 PM   #2931
Hagbard
Hagbard's Avatar
Smile Nvidia N1
Installed this today.
Thanks as well to @Stav from JRP for getting it for me had it in stock picked it up same day i decided to get it so that was awesome! (think i got there last one tho)
Some underside Pics,
How it snugs up to the Subaru rear defuser no problems, lots of clearance still
Hagbard is offline   Reply With Quote
Old 07-23-2013, 06:42 PM   #2932
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Laws vary, but in CA for tickets if you want to fight:
- postpone on last day of original ticket
- postmark a written letter for Trial by Written Declaration on last day of extension
- http://www.courts.ca.gov/8450.htm#tab9275
- If you somehow lose, just ask judge for traffic court.
The goal here is to drag it out so you have the upper hand. About the only thing you'll lose (at the start) is your fine, which you have to pay no matter what.
-alex
Old 07-23-2013, 11:10 PM   #2933
Scoobidude
Drives: DGM BRZ
I did mine the other day. I love it and it looks sick with my rear diffuser. Just gotta check the connection from mid pipe to front pipe. May not be tighten enough
Scoobidude is offline   Reply With Quote
Old 07-23-2013, 11:12 PM   #2934
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Got my Injen intake installed! Name:  ImageUploadedByTapatalk1374635534.998724.jpg
Old 07-24-2013, 01:26 AM   #2935
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Originally Posted by mrauburnhd View Post
Got my cold air intake installed!
Not trying to rain on your parade, but that is simply an "intake" not a "cold air intake". That is located in the stock position, drawing the same air as the stock intake basically. A cold air intake works by reaching cooler air (typically from down by the road surface), thereby lowering the intake air temp.
/rant
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
The Following User Says Thank You to JonnyRocket For This Useful Post:
chanomatik (07-26-2013)
Old 07-24-2013, 01:30 AM   #2936
Rinzler
Rinzler's Avatar
Drives: BRZ Limited
Friend helped me put in the 10" factory sub! .. kicks ass.
Rinzler is offline   Reply With Quote
Old 07-24-2013, 01:30 AM   #2937
enwave
enwave's Avatar
/rant
While this is theoretically true, why is lower air cooler? Doesn't the higher ambient temperature of the ground warm the air? Is there some article somewhere that proves the lower air is actually cooler?
Old 07-24-2013, 08:07 AM   #2938
dannyboy8793
dannyboy8793's Avatar
Drives: BRZ Limited SWP
I got my 3m hood protection, looks great.
dannyboy8793 is offline   Reply With Quote
Old 07-24-2013, 08:16 AM   #2939
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
A great question. The lower air is actually "cooler" than the air in the engine compartment, which is where the OEM and this intake pull the air from. Take a look at the Perrin intake and you'll see that it is located outside the engine compartment behind the front bumper; the configuration looks quite different.
Now, how much difference does this make? I guess you could dyno them back to back...not sure there's data to conclusively say one is the much better than the other.
MightyMeeple is offline   Reply With Quote
The Following User Says Thank You to MightyMeeple For This Useful Post:
enwave (07-24-2013)
Old 07-24-2013, 11:25 AM   #2940
enwave
enwave's Avatar
Oh right, of course. Forgot the air is more inside the engine compartment at first.
Thanks for the explanation!
