Old 07-23-2013, 11:03 PM   #1
mrk1
Drives: Sterling BRZ Ltd
Blow through vs draw through MAF
Simple question, whats the pros and cons of each style. Looks like exsisting kits are all blow through.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-23-2013, 11:06 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I can't see any advantage to mounting a MAF prior to the turbo. I want the MAF as close as possible to where the air enters the engine.
Old 07-23-2013, 11:40 PM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My 400hp gti runs a 4" maf housing with oem sensor pre turbo. Zero issues. Then people run blow through maf's on many turbo cars and have zero issues as well. Guess there's no real right answer
Old 07-23-2013, 11:58 PM   #4
mrk1
correcting my original post, the AVO kit is a draw through with the stock air box
The Build Thread
Old 07-24-2013, 12:02 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
works turbo kit also uses stock maf and airbox. zero issues
oem look and will be carb legal
86_ZN6 is offline   Reply With Quote
Old 07-24-2013, 12:15 AM   #6
sw20kosh
Drives: 2013 Black FR-S
Blow Through MAF has one advantage (if it is placed post intercooler) because the IAT sensor is integrated with the MAF sensor: IAT measures air temp properly and the tune can be adjusted based on IAT
The Following User Says Thank You to sw20kosh For This Useful Post:
xkalelx (04-18-2017)
Old 07-24-2013, 12:31 AM   #7
ptuning
ptuning's Avatar
Drives: White FR-S
Advantages of a Blow-thru MAF:
1) You can run a true BOV without worrying about recirculating it. This is a very big deal for most turbo set-ups.
2) If you pop-off a coupler or intercooler pipe while boosting, the engine will still run and allow you to "limp" home or at least to the side of the road.
3) Air temp compensation for fueling and timing can be applied as it is metering actual air temp post-intercooler.
4) No need to cut or extend MAF wires, depending on turbo intake location.
Advantages of a Draw-thru MAF:
1) Technically speaking, all air going into the engine, including through the valve breather and PCV is metered and accounted for, but this is very minor and does not affect real-world tuning. Blow-thru would never pass emissions at the OEM level.
2) MAF doesn't get oily if your turbo seals decide to take a dump. Again, not a really big deal unless you plan on using an eBay turbo.
3) You can run a 3.5" MAF housing without having a ridiculously huge looking upper intercooler piping. Not a big deal now either, because you can tune SD blending to prevent MAF overrun on big HP set-ups.
In the end, you'll find most tuner shops and manufacturers going with the Blow-thru MAF route, because the advantages clearly outweigh any perceived disadvantages. Hope this helps.
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
mrk1 (07-24-2013), xkalelx (04-18-2017)
Old 07-24-2013, 12:56 AM   #8
sw20kosh
It is also hard to have a blow through MAF with a PD supercharger system sitting ontop of the engine. =)
Old 07-24-2013, 12:58 AM   #9
ptuning
ptuning's Avatar
Drives: White FR-S
LOL, agreed.
The Following User Says Thank You to ptuning For This Useful Post:
sw20kosh (07-24-2013)
Old 07-24-2013, 07:21 AM   #10
mrk1
Thanks ptuning, I tend to like draw through or SD just based on past setups I've built. Obviously both style has pros/cons.
The Build Thread
Does you A/C blow cold? boredom.is.me Issues | Warranty | Recalls / TSB 45 07-29-2017 03:04 PM
catch can for blow-through maf jamesm Forced Induction 13 05-25-2017 10:54 AM
Subaru STi - flexible draw stiffener illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-29-2013 11:04 AM
Tial Q Blow off valve Gen Engine, Exhaust, Bolt-Ons 1 11-01-2013 08:34 PM
Draw your BRZ! LeeMaster BRZ Photos, Videos, Wallpapers, Gallery Forum 14 09-26-2013 01:34 PM
