Drives: Sterling BRZ Ltd
Blow through vs draw through MAF
Simple question, whats the pros and cons of each style. Looks like exsisting kits are all blow through.
#2 |
NASA SpecE30 Racer
I can't see any advantage to mounting a MAF prior to the turbo. I want the MAF as close as possible to where the air enters the engine.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#3 |
Drives: 2JZ FRS
My 400hp gti runs a 4" maf housing with oem sensor pre turbo. Zero issues. Then people run blow through maf's on many turbo cars and have zero issues as well. Guess there's no real right answer
#4 |
correcting my original post, the AVO kit is a draw through with the stock air box
#5 |
Drives: 86 ZN6
works turbo kit also uses stock maf and airbox. zero issues
oem look and will be carb legal
#6 |
Drives: 2013 Black FR-S
Blow Through MAF has one advantage (if it is placed post intercooler) because the IAT sensor is integrated with the MAF sensor: IAT measures air temp properly and the tune can be adjusted based on IAT
| The Following User Says Thank You to sw20kosh For This Useful Post: | xkalelx (04-18-2017) |
#7 |
Drives: White FR-S
Advantages of a Blow-thru MAF:
1) You can run a true BOV without worrying about recirculating it. This is a very big deal for most turbo set-ups. 2) If you pop-off a coupler or intercooler pipe while boosting, the engine will still run and allow you to "limp" home or at least to the side of the road. 3) Air temp compensation for fueling and timing can be applied as it is metering actual air temp post-intercooler. 4) No need to cut or extend MAF wires, depending on turbo intake location. Advantages of a Draw-thru MAF: 1) Technically speaking, all air going into the engine, including through the valve breather and PCV is metered and accounted for, but this is very minor and does not affect real-world tuning. Blow-thru would never pass emissions at the OEM level. 2) MAF doesn't get oily if your turbo seals decide to take a dump. Again, not a really big deal unless you plan on using an eBay turbo. 3) You can run a 3.5" MAF housing without having a ridiculously huge looking upper intercooler piping. Not a big deal now either, because you can tune SD blending to prevent MAF overrun on big HP set-ups. In the end, you'll find most tuner shops and manufacturers going with the Blow-thru MAF route, because the advantages clearly outweigh any perceived disadvantages. Hope this helps. |
#8 | |
#10 |
Thanks ptuning, I tend to like draw through or SD just based on past setups I've built. Obviously both style has pros/cons.
| Does you A/C blow cold? | boredom.is.me | Issues | Warranty | Recalls / TSB | 45 | 07-29-2017 03:04 PM |
| catch can for blow-through maf | jamesm | Forced Induction | 13 | 05-25-2017 10:54 AM |
| Subaru STi - flexible draw stiffener | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 11-29-2013 11:04 AM |
| Tial Q Blow off valve | Gen | Engine, Exhaust, Bolt-Ons | 1 | 11-01-2013 08:34 PM |
| Draw your BRZ! | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 14 | 09-26-2013 01:34 PM |
