Old 07-23-2013, 05:03 PM   #1
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Vortech 12.5 psi running on pump gas?
Has any seen or heard about someone running the 2.87" pully on pump gas? I'm not looking for wow numbers I'm looking to see if its safe at all.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 07-23-2013, 05:05 PM   #2
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Maybe
@ft86me @charged86
pheoxs is offline   Reply With Quote
Old 07-23-2013, 06:04 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
From what I've heard, anything above 12 is kinda bad news on such high compression motor that we have. Now there are things you can do in order to run a smaller pulley and benefit from the torque while maintaining boost way under 12.
ft86me is offline   Reply With Quote
Old 07-23-2013, 06:29 PM   #4
Opposed
Drives: 2013 Asphalt FR-S
Not anymore. There are a few guys on here running 12-14 psi on 93 pump gas with their turbo kits.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 07-23-2013, 06:50 PM   #5
Adeets
OEDC
Adeets's Avatar
I'm looking more for someone with a vortech, I'm not running 12.5 psi for pump gas, I'm running it for E85, but incase e85 isn't around I was making sure I could still run pump.
My BRZ FI Build
Old 07-23-2013, 07:10 PM   #6
ft86me
ft86me's Avatar
Drives: 2013 FRS
I'll leave my opinion and what ive seen to myself so ill just say ok. =]
Old 07-23-2013, 07:41 PM   #7
charged86
charged86's Avatar
I am running the 2.87 right now on e85. More updates soon
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-23-2013, 07:44 PM   #8
swift996
swift996's Avatar
I know it's another system but have you considered WMI for those times you have 93?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-23-2013, 07:45 PM   #9
dabocx
dabocx's Avatar
Drives: Scion FRS
If your worried about pump you could get meth? Just run meth when your on 93 and dont use it when your on 93. A bit of hassle and cost to buy and install but the gains could be worth it?
dabocx is offline   Reply With Quote
Old 07-23-2013, 08:29 PM   #10
Adeets
OEDC
Adeets's Avatar
I'd rather run an EBC then meth, never runs out and adds .1 lbs
My BRZ FI Build
Old 07-23-2013, 08:30 PM   #11
Don@Accelerated
Don@Accelerated's Avatar
You should talk with Visconti. We were running 300+whp last week on 93 octane on a stock engine. Our setup is pretty badass and works great.
Don@Accelerated is offline   Reply With Quote
Old 07-23-2013, 08:32 PM   #12
Adeets
OEDC
Adeets's Avatar
A: is it a vortech
B: what psi
Once again I'm not worried about the numbers I just want it to be safe for those times I'm not running E85
And I don't think visconti and I are on the best terms ATM.
Might as well try: @Visconti
My BRZ FI Build
Old 07-23-2013, 10:52 PM   #13
ptuning
ptuning's Avatar
Drives: White FR-S
Our soon to be released WMI system will likely enable you to tune for true MBT or very very close to it at 12.5 psi. The extra timing that you can run will likely amount to quite a bit more power than you can get tuning for knock on 93 pump gas alone.
Since your centrifugal SC builds boost with rpms, you'll likely go for quite a long time between WM refills if you're not constantly revving out the engine. Just an option to consider. :happy0180:
ptuning is offline   Reply With Quote
Old 07-24-2013, 12:26 AM   #14
pheoxs
Originally Posted by ptuning View Post
Since your centrifugal SC builds boost with rpms, you'll likely go for quite a long time being WM refills if you're not constantly revving out the engine. Just an option to consider. :happy0180:
Lol not with my driving habits.
Then again I get free methanol at work so... any chance i can sign up now and get it when it's released? ?
Sent from my Nexus 4 using Tapatalk 2
Nolan
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
DI pump Internals SkullWorks Issues | Warranty | Recalls / TSB 60 10-30-2014 02:23 PM
Electric fuel pump running with car off??? bpracer Issues | Warranty | Recalls / TSB 13 08-08-2013 09:42 AM
Vac Pump sw20kosh Engine, Exhaust, Transmission 1 06-06-2013 07:46 PM
What gas do you pump? its_the_biz Scion FR-S / Toyota 86 GT86 General Forum 45 02-27-2013 11:22 PM
