Old 07-22-2013, 07:12 PM   #995
GreenPants
Drives: Burnt Orange GT86
Some things I would like to address, not sure how much I'll be able to do:
  • Include Google Map API by default [done]
  • Radio - Image resources - swap Red/Blue channels to get red backgrounds [done]
  • Radio - Text resources - change colour to suit
  • Launcher - Image resources - remove default wallpapers (reduce size), replace with FT86 appropriate defaults (customize).
  • Launcher - Change default layout (cleaner)
  • Logos - Remove existing logos that aren't FT86 applicable (reduce size).
  • Logos - Add FT86 logos (customize) [done]
  • Install Google Car Home
  • Hack up a fix for the cache size problem so Cache Fixer isn't needed anymore
  • Media player - Fix up Chinglish warning image
  • General settings - Fix up Chinglish settings text
  • Bootanimation - Default to grey car
  • DVD splashscreen - Replace with something a little nicer (haven't been able to locate this yet)
  • Possibly add a file explorer by default - one less thing to install after upgrade, allowing easier installation of user .apk files from USB/MicroSD out of box
GreenPants is offline   Reply With Quote
Old 07-22-2013, 09:29 PM   #996
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
couple gripes:
i had previously closed my "stock app" by holding the back button for 3 seconds. This prevented it from booting up and loading the stock app anymore, which was perfect for me. Now all of the sudden, this also makes it mute my sound and will not unmute. I cant listen to music in poweramp or mx player videos or anything unless i reopen the stock music app or ipod or whatever other stock app i can use. If i try closing it, the same problem happens where the whole unit becomes muted. Very frustrating.
The stock music app also sorts my music in z-a or 9-0 order rather than the normal way. I have yet to find a solution for this.
All i want with this unit now is a much shorter boot time, a way to get my reverse camera working and to have my most recent app boot on startup (excluding stock apps)
Why is this so hard?
ph0en1xtk is offline   Reply With Quote
Old 07-22-2013, 10:06 PM   #997
GreenPants
Are you saying my new system.img made it perform differently - or that the existing firmware is suddenly behaving differently?
Just a random thought -things may act differently depending on which stock app you shut down with the 3-second Back trick.
It's a cheap Chinese knock-off. Things are never going to be simple.
Old 07-23-2013, 02:31 AM   #998
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
couple gripes:
about muting, do you try to re-assign panel keys function?
Trap63 is offline   Reply With Quote
Old 07-23-2013, 02:41 AM   #999
Trap63
Trap63's Avatar
@GreenPants
I bought several apps in googleplay, may be useful for you to integrate? i.g. Torque Pro and widgets (knock sensor, racing meters), SU explorer, USB dongle, Office Pro, wifi connection...? I can save and store in dropbox for you.
Old 07-23-2013, 02:47 AM   #1000
coyote
coyote's Avatar
Drives: Slowly
My phone contacts are sorted numerically by their phone numbers, rather than alphabetically by their names.
Anyone else have this issue? It's the same on my Nexus4 and SGS4.
As far as a rom goes, I'd like it to be as light as possible. Logos and wallpapers are something I think people can add themselves if they think they need them.
And Navigon Australia is rubbish. Used it before on my SGS2, but it actually seems to have gone backwards since then.
coyote is offline   Reply With Quote
Old 07-23-2013, 05:05 AM   #1001
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
No problem @nzer. Toyota have already run all the important cables for their OEM camera, for handbrake, and reversing switch. Just need to run one from the head unit to the boot lid which is easy.
Tech is offline   Reply With Quote
The Following User Says Thank You to Tech For This Useful Post:
nzer (07-23-2013)
Old 07-23-2013, 07:21 AM   #1002
ph0en1xtk
ph0en1xtk's Avatar
My unit also does the same thing with my phonebook as mentioned above
And no, I have not yet flashed your custom image on here. Still on hal9ks
I tried playing with the buttons in extra settings but I guess I dont know what I'm doing cause nothing I press has any response
Old 07-23-2013, 05:08 PM   #1003
Trap63
Trap63's Avatar
go in settings (not extra), press START (lower corner left), it comes grey, then choose i.g. "mute" and press (not turn) volume button. Your check "Mute" will vary to "set+" or other and START comes black on yellow background. Repeat for each action/button. I discover this procedure on manual after trying several times...
Old 07-23-2013, 05:10 PM   #1004
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Attempting to open a RMA to send my unit back. The usb seems to just not work at all on this unit ... @2forme do we have any other rom I can try just incase its having issues with that for whatever reason? Stock or another rooted version?
pheoxs is offline   Reply With Quote
Old 07-23-2013, 05:15 PM   #1005
Trap63
Trap63's Avatar
Warn....not all usb hubs operate correctly. Did you try standalone and/or other usb key to verify usb port?
Old 07-23-2013, 05:17 PM   #1006
pheoxs
Same thing plugged straight in without a usb hub. Front and rear port. @nzer is amazing and sent me a bluetooth dongle that he tested and had working and it won't work on mine at all. It just keeps freezing my head unit everytime I turn on bluetooth and I need to reboot it.
Old 07-23-2013, 05:20 PM   #1007
Trap63
Trap63's Avatar
damn! if you reflash with other ROM you loose warranty....be careful before claiming for a RMA.
Old 07-23-2013, 08:25 PM   #1008
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Suggest you PM @2forme as that will send him an email alert. He's not active on the forum any more - long story...
nzer is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
