Driveshaft Shop, Jesse
Old 07-22-2013, 08:11 AM   #1
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Low car + replacement axles + raising diff advice
So last friday I was out drifting and it was all fun and games until I shattered a bearing casing and had to get the car towed home. Good to see I waited seven months for the car and I've very successfully broken it in three months.
It's on BC BR's which are wound quite low and soon to have a lot of negative camber to tuck aggressively offset wheels on the rear.
My question is....
I'm assuming, due to the ride height being so low, additional stress has been put on the axles and coupled with drifting and some hard driving, is the reason why the casing has exploded after such a short time. At this stage I'm looking at replacing the factory axles with THESE axles from the Drive Shaft Shop.
I have no doubt these axles will be strong enough to withstand the cars power, now and in the future, but I want to know if these axles would be able to withstand the stress of low cars due to the angle off the diff being changed so dramatically. I really don't want to wreck a set of DSS axles if they haven't been over engineered very low cars.
Alternatively, has anyone considered or attempted to raise their diff to reduce the angle/stress on the axles?
Current mods for reference.
Work Kiwamis 8.5 front 9.5 rears both wrapped in Achilles
BC BR coils
Racer X fabrication rear upper control arms
Cusco front/rear sway bar
Cusco rear sway bar
Car has no engine/power modifications.
These are old pics for reference to low. If anything it's a little slower now and rear upper control arms aren't installed in these.
JordanWho is offline   Reply With Quote
The Following User Says Thank You to JordanWho For This Useful Post:
nix (07-24-2013)
Old 07-22-2013, 09:44 AM   #2
OrbitalEllipses
Drives: Attitude
Do you really have to ask if your suspension modifications contributed to blowing the axle? Of course they did. I'm sure the whack geometry will blow another axle eventually, it'll just take longer.
civicdrivr (07-22-2013)
Old 07-22-2013, 04:49 PM   #3
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I love aggressive offsets just as much as the next, but unless you're going to be running wider fenders, you should probably have appropriate/functional sized wheels and tires.
Unless I'm missing the point of massive camber in the rear for drifting.
slicktop is offline   Reply With Quote
Old 07-22-2013, 05:02 PM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
PBM is working on subframe and diff inserts to help fix the geometry. Between those and some Stance LCAs, the problem will probably be gone.
Wait it out.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
JordanWho (07-22-2013), WolfsFang (08-01-2013)
Old 07-22-2013, 11:31 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
DSS can and will build axles for lowered cars, you just need to supply them with the measurement between the hub and the diff with the suspension compressed (to ride height).
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-23-2013, 12:11 PM   #6
wparsons
wparsons's Avatar
How would lowering the diff fix your issue?? If anything you want to raise it higher. You want the axle as straight as possible at rest, with the car lowered the hub is higher than stock in relation to the diff, so you want the diff higher to flatten the axle. I have no clue how much room there is before you hit the floor of the trunk though.
Which end of the axle did you blow apart? The hub end, or the diff end?
flickr
Old 07-23-2013, 01:16 PM   #7
JordanWho
JordanWho's Avatar
Yeah my mistake.
Broke on the diff side.
Old 07-23-2013, 03:54 PM   #8
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
Subscribing to this thread... gone through this twice even with lifting my car up alittle on BC Racing Coilovers... I've had enough with this problem happening. I want to get some more info on the best route to take to lowering this car without running into these problems : /
CoRi J is offline   Reply With Quote
The Following User Says Thank You to CoRi J For This Useful Post:
nix (07-24-2013)
Old 07-23-2013, 05:46 PM   #9
wparsons
wparsons's Avatar
Keep in mind that as you raise the diff you'll also have to change the angle of it to not totally mess up the pinion angle for the driveshaft.
flickr
civicdrivr (07-23-2013)
Old 08-01-2013, 05:03 AM   #10
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Rumour has it, that if you go low enough.. :P
[ame]http://youtu.be/ox-lfowevqA[/ame]
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 08-01-2013, 09:42 AM   #11
JordanWho
JordanWho's Avatar
New axles arrived this morning. Looks strong as fuck. Will be on tomorrow.
Old 08-01-2013, 11:54 AM   #12
mike the snake
When I asked my tuner about longer rear lower control arms, he mentioned that this causes problems with blowing up CV's and axles popping out, because the longer lower control arms cause the axles to be extended too far out.
I bet your problem has more to do with this than excessive angles.
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
JordanWho (08-05-2013), wparsons (08-02-2013)
Old 08-01-2013, 02:38 PM   #13
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Subframe/rear diff risers!
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 08-04-2013, 04:07 AM   #14
KONVERTER
KONVERTER's Avatar
What exactly "Broke" here? Pic?
KONVERTER is offline   Reply With Quote
HVT BRZ/FRS Non-raising Camber Plate Turn in Concepts Brakes, Suspension, Chassis 25 08-18-2013 04:57 PM
should i upgrade axles? Frs300 Engine, Exhaust, Transmission 16 07-02-2013 12:00 AM
Lowering/raising driver's seat? Dreamshot Scion FR-S / Toyota 86 GT86 General Forum 16 06-07-2013 05:59 AM
Anyone lowering their BRZ with coilovers and raising the BRZ for winter? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-29-2012 07:37 PM
