Old 07-23-2013, 11:56 AM   #1
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Rubber exhaust hangers
Hey everyone, anyone know where I can get some longer rubber exhaust hangers? I'm trying to slightly lower a section of my exhaust and I need some slightly longer hangers. I know they sell firmer hangers, I'm just looking for longer. Autozone, etc., does not seem like much help. Any online sources? Anyone? Anyone? Bueller?
JimmyMac is offline   Reply With Quote
Old 07-23-2013, 11:59 AM   #2
JimmyMac
JimmyMac's Avatar
Never-mind, I think I found some... hehe
Old 07-23-2013, 12:07 PM   #3
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Maybe you could provide what you found, including the outcome.
Others may encounter this thread through a search or otherwise.
Nothing sucks more than a dead end
CircuitJerk is offline   Reply With Quote
Old 07-23-2013, 12:20 PM   #4
JimmyMac
JimmyMac's Avatar
Kartboy and Torque Solutions both offer 12mm (our hanger size is 12mm NOT 15mm) LONG exhaust hangers. Just Google them up. Ebay has a lot or you can buy direction from their respective websites. My problem is that I want to lower my exhaust tips on my Invidia N1 exhaust. The stock hangers are preventing this from happening. We'll see how it works out.
The Following User Says Thank You to JimmyMac For This Useful Post:
CircuitJerk (07-23-2013)
Old 07-23-2013, 12:40 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
Did you try just loosening the bolts where each tip connect to the main pipe?
Im able to get plenty of movement, I have mine adjusted as high as they will go and I still have clearance.... got pics?
I had some fitment issues before and it was due to a crappy midpipe that changed the exhaust alignment.... tips were way too high and off center
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-23-2013, 01:30 PM   #6
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Do not get the Kartboy 12mm ones, they are slightly shorter than the stock rubber hangers. I'm SOL
LeeMaster is offline   Reply With Quote
Old 07-23-2013, 01:37 PM   #7
qoncept
qoncept's Avatar
Kartboy makes regular length and longer hangers. Go order the other ones :P
qoncept is offline   Reply With Quote
Old 07-23-2013, 03:39 PM   #8
JimmyMac
JimmyMac's Avatar
Yeah did that, but as I said, I need longer hangers. If I was just running stock exhaust and N1 cat back I'd be fine. But since I'm full exhaust now, I need to make adjustments. I should have them in a few days. So we'll see.
86_Insider (07-23-2013)
Old 07-23-2013, 04:22 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
What is the rest of your exhaust system? If anything just for reference so others going your route can plan in advance for longer hangers
2013 FRS
Vortech V3 11psi
Old 07-23-2013, 06:41 PM   #10
JimmyMac
JimmyMac's Avatar
P&L catted header and overpipe, ARK Helmholtz Resonated front pipe, and N1 cat back. I'd like to switch out the ARK for a catted front pipe and switch the down pipe on the header to non-catted. But that's a later project. Every fit is going to be different. I'm sure my needs are a little different than others. Mostly cosmetic. But going back a step, I think the ARK might have throw off the setup. It's a tight fit. Blah blah blah. Hehe
Old 07-23-2013, 08:32 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Advance Auto Parts carries long hangars. I don't have the part# handy, but I'll try to remember to get it tomorrow.
Old 07-23-2013, 11:40 PM   #12
JimmyMac
JimmyMac's Avatar
They didn't have anything when i went there. They had one small one. That's it. But that's okay. I ordered a set of 4 Torque Solution Long ones from Ebay for $36 shipped. It's coming from Florida, so it should be at my house in a day or two.
Old 07-24-2013, 01:07 AM   #13
Dan@AWD
Drives: 2013 Argento FR-S
What Ebay seller did you order from?
Dan@AWD is offline   Reply With Quote
Old 07-24-2013, 02:01 AM   #14
JimmyMac
JimmyMac's Avatar
You, haha. Did I order the wrong ones?
Both: EZ DIY Rubber Trunk Mat (FR-S Only) Calidrifter DIY (Do-It-Yourself) Guides 16 10-17-2020 06:07 AM
exhaust hangers jazztennor Engine, Exhaust, Transmission 7 02-19-2013 10:57 AM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 02:15 AM
Rusty exhaust hangers? finch1750 Issues | Warranty | Recalls / TSB 5 11-12-2012 01:29 AM
Anyone else smell rubber? pinoyplaya BRZ First-Gen (2012+) — General Topics 15 09-24-2012 04:40 AM
