Old 07-02-2013, 03:15 PM   #183
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
Originally Posted by Nm86 View Post
Run by an exhaust shop and get them to adjust it, they heated up the hangers on myne and just pulled it down, that fixed the rubbing issue.
Sounds good. Mine doesn't rattle like I've seen in other videos but it does vibrate the cabin a bit.
Pooverdam is offline   Reply With Quote
Old 07-02-2013, 09:52 PM   #184
troek
troek's Avatar
Drives: 2012 Toyota 86
I bought longer rubber hangers to fix that issue
troek is offline   Reply With Quote
Old 07-02-2013, 10:15 PM   #185
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
I have the quad variant of this catback. I have a mild rattle on cold-start that dissipates after 3-5 seconds even after utilizing elongated hangers and verifying there is clearance everywhere. It's subtle and not terribly notable unless you're listening for it specifically.
I thoroughly enjoy the duality of sound from this catback (deep bass rumble at lower RPM and higher-pitched roar up top), but exhaust notes are like aesthetic modifications and I'm sure it isn't for everyone. The quad is VASTLY louder than the J2 dual setup on a friend's FR-S.
No before/after dyno videos unfortunately, but judging by benchmark runs, it certainly didn't lose anything. Buttdyno says it picked up marginally, and the revs certainly feel smoother.
My $0.02 review: You get what you pay for. For a third the price of most catback systems, I'm thoroughly impressed. The metal is very thin, and it is definitely 409 not 304 SS---you will get corrosion that can be removed with a scotchbrite pad but nothing horrific. Dip/coat the system before installation if you're concerned. The fitment isn't completely perfect but I had zero installation issues with good clearance everywhere (though it does sit on the shield by the rear bumper if you don't use longer hangers).
Nightbringer is offline   Reply With Quote
The Following User Says Thank You to Nightbringer For This Useful Post:
Pooverdam (07-06-2013)
Old 07-06-2013, 08:21 PM   #186
Pooverdam
Pooverdam's Avatar
Well said. I agree with everything. I will add that it does quiet down a bit with time. But cold starts are still pretty obnoxious for the first 5 seconds. But overall the J2 is great!
Old 07-06-2013, 08:33 PM   #187
troek
troek's Avatar
haha i feel bad when i start my car up in the mornings before work. id like to edit the ecu so it dosnt do that and i just sit and let it warm up on its own.
Old 07-22-2013, 01:04 PM   #188
dOMEmE
Drives: 2013 Scion FRS WhiteOut
alrrigt so i bought this exhaust around a month or more ago...sounds great, and didnt have a problem installing it.... over the month i noticed only the far right exhaust tip was getting darker. (and now its super dark)
sure enough all other 3 tips are super clean, i wipe my finger on them and there suuuuuper clean...seems like its only escaping out the far right tip.
anybody else have this problem?
dOMEmE is offline   Reply With Quote
Old 07-22-2013, 01:26 PM   #189
invaliduser
Drives: 2017 86
I did notice in this video [ame="http://www.youtube.com/watch?v=Lrn8BnpsyJo"]100 0051 - YouTube[/ame]
that the visible gasses coming out of the car were primarily via the far right exhaust tip.
invaliduser is offline   Reply With Quote
Old 07-22-2013, 01:31 PM   #190
dOMEmE
Originally Posted by invaliduser View Post
I did notice in this video..
think that could be bad for the motor? maybe restricting the exhaust flow? losing power?
Old 07-22-2013, 03:22 PM   #191
Nightbringer
Drives: Scion FR-S
Mine only darken the outside tips as well, but BOTH outside tips for mine. Exhaust gas will always find the easiest exit route. It's not bad for the motor, it's just not optimal routing.
Old 07-22-2013, 03:24 PM   #192
invaliduser
Drives: 2017 86
Can you have a friend rev the engine while you feel for exhaust flow with your hand? I would suspect that having exhaust gas exit out of only one of the 4 outlets would be restrictive. Looking at the design, I don't know how its possible to only have flow through the one outlet/tip unless something is stopped up along the way.
Anyway, I love the sound from the clips i've seen.
Old 07-22-2013, 06:44 PM   #193
troek
troek's Avatar
it does favor the right side under low rpms, but when you give it some gas it flows more evenly.
Old 08-31-2013, 02:11 AM   #194
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
Originally Posted by troek View Post
longer rubber hangers. about 1/2" longer. doesn't need to be quite that long but i wanted to give plenty of clearance. now the ONLY downside to this exhaust is that raspy noise when the car struggles in low rpms. hopefully its the heat shield. it sounds amazing in every other part of the rev range.
EDIT: i would recommend the ones with multiple holes so you can get it perfect.
Did you replace just the hangers holding the axleback, orthe one holding the midpipe as well? Also, were you able to reuse the stock exhaust bolts/nuts? The box my catback was shipped in had a decent sized hole in it and I think a few of the bits were lost.
Ocean-Grown 86 is offline   Reply With Quote
Old 08-31-2013, 04:10 AM   #195
Nightbringer
Drives: Scion FR-S
I personally didn't have to replace anything in the end, though aftermarket hangers are always a plus. I ended up using the new hardware, but the OEM bolts appear to be the same. Mine also had a massive hole in the box, but the little hardware baggy was intact haha.
Ocean-Grown 86 (09-07-2013)
Old 08-31-2013, 07:27 AM   #196
troek
troek's Avatar
replaced just the muffler hangers. the stock ones were just too short, no way around it. maybe some of their mufflers have the hangers extended a bit.
The Following User Says Thank You to troek For This Useful Post:
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-24-2020 12:45 AM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 04:43 AM
TRD Style Quad exhaust Nafe AUSTRALIA 17 05-11-2013 03:13 AM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 09:49 PM
Stacked Quad Exhaust quik1987 Engine, Exhaust, Transmission 43 08-16-2012 04:34 PM
