FI Dyno thread
I wanted to make an archive of people's best dyno run with their configuration.
Please ONLY POST a DYNO (there is no need to comment) Format: - Name/Screen Name - Force Inducted Kit - Fuel Type - Max Boost - Other Mods - Other Notes/Conditions, Tuner, etc. (include link to other thread where people can go comment/ask questions if desired) - PIC OF DYNO If you have any comments or suggestions feel free to PM me, let's try and keep this clean and a valuable resource.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() Last edited by swift996; 07-23-2013 at 09:09 AM. |
#2 |
- Jon Swift/Swift996
- Innovate Supercharger (Tuner Kit - Stage 1) Tuned by Moto-East - E50 - Provided Pulley ~7PSI - K&N Drop-In Filter, FA20Club Catted Header, FA20Club Resonated Front Pipe, 700CC Injectors - 4th gear pulls, 102F degree ambient temps (ran 180whp on different DynoJet prior to supercharger)
#3 |
NASA SpecE30 Racer
- Chris Tuttell / King Tut
- Full Blown Motorsports Stage 1 Base Turbo Kit - 93 Octane/Bosch 550cc Port Injectors/Full Blown Fuel Pump - 12.5 psi - Garrett GT2871R Oil/Water Cooled Ball Bearing Turbo, Precision Turbo 39 mm External Wastegate, Tial 50 mm Q Blow Off Valve, Go Fast Bits G-Force II Electronic Boost Controller, JDL Auto Design 2.5" Overpipe, JDL Auto Design 2.5" Frontpipe, GReddy Evo3 Exhaust, ACT Heavy Duty Pressure Plate/6 Pad Sprung Race Disc Clutch, ACT XACT Prolite Flywheel, D3 Performance Engineering Catch Can - 90F+ Temps, Rain, 4th Gear Pull
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z Last edited by King Tut; 07-22-2013 at 10:51 AM. |
#4 |
I Love custom Turbo kits
Drives: Limited BRZ
Dave / Sportsguy83
- AVO Stage 2+ Turbo Kit - 93 Octane/SIR 500cc Port Injectors/DW 65c Fuel Pump - 14 psi - AVO 18/49 Oil/Water Cooled Turbo (TD05 18g) internally gated, AVO 50/50 BOV, Perrin Manual Boost Controller, Nameless 3" OP/DP, Midpipe and Axleback, Clutchmasters FX350 Clutch Kit, D3 Performance Engineering Catch Can - 90F+ Temps and Rain, 4th Gear Pulls. - Will be doing E85 Dyno tune soon, will update post with new numbers ASAP. - Turbo Experience Thread - Member Car Journal
#5 |
Drives: FRS
Brandon/lexusb3
Fa20club.com kit e85 16psi 3inch exhaust custom, fuel pump, 550 injectors ![]() 90degrees 29 humidity -_- Signature has my build ( just click it) |
#6 |
Drives: AVO BRZ
- nix
- AVO turbo kit - Flex fuel (98 RON to e85) - 14.7 psi - Stage 1: AVO air filter, AVO oil breather tank, Perrin 2.5" catted unresonated exhaust, Perrin crank pulley. - Stage 2: + Omni map sensor, Spray it Racing 500cc port injectors, SPD290 Fuel pump, Zeitronix flex sensor. - Driveline: ACS chromoly flywheel & 830kg DCB clutch kit, STI engine & trans mounts, whiteline diff & outrigger inserts. - Journal thread -Baseline of 108kw = 145 hp. Dyno reads ~15% lower than dynojet. Original & converted dynojet numbers below for comparison. Stage 1 AVO base map (98 RON, 4.5 psi) vs stock baseline (98 RON). 140 rwkw / 188 whp / 215whp. *This was from Ross Wilson @ AVO JDM. ![]() Morpowa flex tune E78% - AVO stage 2 actuator - 8.5 psi. 217 rwkw / 291 whp / 335 whp. ![]() Power starting to top out on e70 and 14.7 psi. 247 rwkw / 331 whp / 380 whp.
#7 |
WUB WUB
Drives: 2013 Firestorm
Michael/WRXgoose
Innovate SC 93 oct 7.5psi iirc Borla UEL headers, Perrin 3" header back exhaust note: this is not a finalized tune, I need to get back and have it fine tuned to where I want it.
#8 |
- Paul Hansen/AVOturboworld
- AVO Turbocharger Kit Stage 1.8.2 - 92 octane (10% ethanol) - 10.92 - AVO header-back exhaust, AVO high-flow Panel Filter - http://www.ft86club.com/forums/showthread.php?t=13156 Note: This is an old chart, currently working on the bigger/better/faster version.
#9 |
- fenton
- Phantom Electric supercharger - 94oct(10% ethanol) - 4psi - 1.6psi at peak power - Otherwise stock - First designed kit, new compressor in development. - Build thread - http://www.ft86club.com/forums/showthread.php?t=39719
#10 |
Drives: 2013 Firestorm FR-S
-Chris/mack4477
-FBM Stage 1 Base Kit with GTX2867 upgrade -E85 @ 16 psi -93 pump @ 10 psi -Dyno tuned by LJ @FullBlown -FBM 3" exhaust, 1000cc injectors, upgraded fuel pump
#11 |
Drives: 85 corolla gts
Owners name: Fabron / Fabron757
Kit: Custom kit built by Trust Automotive using efr 7064 Fuel: e85 Other mods: fuel pump, injectors, catch can with drain back to oil pan, full 3" turbo back exhaust w/ no muffler only cat and resonator, all hot parts coated, Koyo Radiator, Spal fans, remote mount oil filter and large oil cooler, aem wideband fail safe, CLutch Masters FX400 Tuned by: Trust Automotive using EcuTek Race Rom, tuned on 16 psi http://www.ft86club.com/forums/showthread.php?t=31807
#12 |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Vortech supercharger, 8.5psi pully moto-east tuned
92 WAWA gas Borla header, perrin cat back Stock injectors/pump Terminated dyno tuning early, upgrades were on the way, needed something that ran.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback Last edited by Adeets; 07-25-2013 at 12:28 PM. |
#13 |
OEDC
No more?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
#14 |
Drives: 22 BRZ
- Pete
- Vortech Kit - 93 octane - 9 PSI - Borla UEL headers, Perrin Headerback - Perrin Tune - Blue line is old 7 PSI blower, not sold anymore
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
