Old 05-10-2013, 08:43 PM   #85
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Originally Posted by Tama-Y View Post
Curious about your ......
No I'm not worried about burning a fuse, the harness that I'm using has a few built in. The fog lights are getting power from the battery. There connected to the side marker via a remote wire. That's what makes them come on with the parking lights.
Juanito08 is offline   Reply With Quote
Old 05-17-2013, 05:09 PM   #86
Willsonk
Drives: Scion FR-S Asphalt AT & XB
I just want to say thank you to everyone who put their research and worked together to get a DYI for fog lights. Mine came out great !!!! Thank you again!!!!!!
Willsonk is offline   Reply With Quote
Old 07-22-2013, 06:43 AM   #87
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
Originally Posted by nigel-jdmparts View Post
Not sure if I am correct, if you are using the glass housing fog light, you cannot use the toyota harness. The toyota 86 fog light do not use H11 application like the Subaru glass housing.
will this harness from your site work with the outback fogs that op used?
http://www.nigel-jdmparts.com/vehicl...h-onoff-switch
the description says the harness is for h11. the shopping page for the outback fog light does not mention what bulb is used with it however
mrlewistan is offline   Reply With Quote
Old 07-22-2013, 06:51 AM   #88
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Yes
Outback lights uses h11
The Following User Says Thank You to whitefrs For This Useful Post:
mrlewistan (07-22-2013)
Old 09-04-2013, 05:45 PM   #89
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
If anyone was trying to get the as close to OEM as possible when ordering the Fog Lights you can order the Nuts and bolts from Subaru as well.
Nut Part #902510034
Bolt Part #901000171
Diagram of the Nut and Bolt. Talking about number 2 & 3. Come in packs of 6 I believe.
Shneegle is offline   Reply With Quote
Old 09-04-2013, 06:13 PM   #90
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
Nuts and Bolts from Subaru - Still Have Them!
Did you actually finish your own installation using the part numbers you recommended?
Been there and tried to do that - did not work! Thicknesses and hole sizes did not match and I still have mine left over from the installation. Used Machine # 6 instead with minimal drilling to accommodate for exact size.
I realize that is what the Subaru parts diagram recommended for the Outback at the first place, but most certainly they did not work on my FR-S. Thought I'd let you know, thanks.
Zagmeister is offline   Reply With Quote
Old 09-04-2013, 07:17 PM   #91
Shneegle
Shneegle's Avatar
No I haven't gotten everything together to do the install yet. Was working on getting all the pieces together before I start. Well I guess a trip to Home Depot will have to work then.
Old 12-07-2013, 03:28 AM   #92
cooldandani
Drives:
What kind of hid lights do you have?
Sent from my SGH-T889 using Tapatalk
cooldandani is offline   Reply With Quote
Old 02-21-2014, 02:13 AM   #93
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
my fog lights were installed by the dealer
how easy is it to change out the bulbs?
and can the fog light assembly and wiring be able to handle 4300k fog lights? (to match the 4300k headlights)
subiestyle is offline   Reply With Quote
Old 02-21-2014, 02:24 PM   #94
jonzhuxD
Drives: Ultramarine FR-S
Bulbs are very easy to change out, remove the three clips by the fender, reach in and twist to pull the bulb out of the housing and then unplug the bulb from the harness. Here's a picture of the clips stolen from one of F1point4's DIY:
http://www.ft86club.com/forums/showthread.php?t=15560
The assembly's or wiring's ability to handle different bulbs has nothing to do with their color temperature but their wattage (power consumption) I have 55W Nokya 2500K bulbs in mine but I'm sure equivalent 55W 4300K bulbs would work just fine.
jonzhuxD is offline   Reply With Quote
The Following User Says Thank You to jonzhuxD For This Useful Post:
subiestyle (02-23-2014)
Old 02-23-2014, 06:13 PM   #95
subiestyle
subiestyle's Avatar
Now after turning off my fog lights they are not turning on after trying the switch?
When are they supposed to turn on?
With headlights off and fog light switch on should they turn on regardless of hand brake position?
With parking lights on do they turn on?
With lights all off do they turn on?
Old 02-24-2014, 09:43 AM   #96
jonzhuxD
Talking
I'm not sure what setup your dealer installed but if they were an OEM option like the Scion Foglight Kit, they should only be on when your headlights are on (low beam). You can check your connections to make sure the bulb is fully seated in the connector and if it still doesn't turn on, try plugging in one of the factory bulbs back in and see if they turn on. If the factory bulb turns on and the one you switch in doesn't, perhaps there's some incompatibility with your bulbs. Assuming your foglights are OEM, they should be H11 style connectors, maybe confirm this on your lighting package first? They should look like this on the right:
They should only turn on with the low beams, they will turn off with high beams on
They should not turn on with the headlights off regardless of switch position.
Their operation has nothing to do with the handbrake position, that's only for the DRL.
They will be off when your parking lights are on, only when your switch on your low beams and the foglight switch will they turn on.
They will not be on when all your lights are off, only when your low beams are on.
subiestyle (02-24-2014)
Old 02-25-2014, 02:17 AM   #97
subiestyle
subiestyle's Avatar
so is it possible to replace the oem bulbs with hid or led bulbs?
Old 04-21-2014, 12:31 PM   #98
EggsAreGood
EggsAreGood's Avatar
Drives:
Im about to do mine soon. Just wondering does your dash light for the lights come on?
Sent from my SM-G900P using Tapatalk
EggsAreGood is offline   Reply With Quote
Custom Shadow Led Lights Scion FR-S Precisionleds Cosmetic Modification (Interior/Exterior/Lighting) 84 07-14-2013 04:26 PM
