Old 06-08-2013, 03:11 PM   #43
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by afishl1 View Post
mine's always had a noticeably different tone around 4k - 4.5k with the injen, not 100% sure what it is, originally I thought it was the pipe resonating at that vibrational frequency at those rpms and thus hitting against the heat shield box as the hole was bigger than the pipe, but now that I've removed the box and the noise is still there, I'm not sure exactly what it is.
Definitely been and still am a little concerned about that.
I think I might try to see if Injen will take mine back(doubt it), worth a shot.
Btw, I think my maf wasn't on/seated/sealed/flat/flush lol properly last time with the CELs, I've reflashed and have been driving it relatively soft and there's still a lil bog, but haven't tripped any CELs yet. Gonna WOT once I get to 50 miles.
That tone at 4k is most like the cam phasing...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 06-08-2013, 06:37 PM   #44
afishl1
Drives: Raven FRS MT
it's that a normal thing, or a common issue?
afishl1 is offline   Reply With Quote
Old 06-08-2013, 07:45 PM   #45
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
VTEC YO
Old 06-09-2013, 10:14 AM   #46
Opposed
Its normal, and good. We have electronically controlled camshafts that are adjusted depending on RPM and throttle input to help with power, torque, and efficiency. Most modern engines use some type of variable camshaft design today.
Old 06-12-2013, 02:07 AM   #47
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
So... I was interested in this but after reading everyone's problems with this conversion do you guys think it is worth it? From what I am reading you have to deform the frame a little bit to fit the tubing and seems like a lot of people are having issues or CELs.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-12-2013, 08:13 AM   #48
ML
ML's Avatar
Drives: 13 White MT FR-S
yeah you have to bend some metal, but its not structural at all, and you can't notice it. One person has reported a cel, and can't confirm that its from this mod. 2 people have confirmed that it solved all/most issues with the intake...I won't go back to stock.
Old 07-20-2013, 11:14 PM   #49
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
@ML so you got two 90 degree pipes and two straight pipes, do you know the length of the two straight pipes?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-21-2013, 12:53 PM   #50
ML
ML's Avatar
6" I believe.
Old 07-22-2013, 02:17 AM   #51
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Just do it this way
buy this and use a hack saw and cut it to fit..
http://www.ebay.com/itm/3-5-89mm-Alu...a5b862&vxp=mtr
Then use your creativity and shop for another 3.5" 90 degree tube and two 3.5" silicone holders and everything else that you will need.
LeeMaster is offline   Reply With Quote
Old 07-27-2013, 08:09 PM   #52
WolfsFang
Scrape Master
WolfsFang's Avatar
Im having the hardest time trying to find a store that stocks 3" 90 degree pipe.
Old 07-27-2013, 08:42 PM   #53
ML
ML's Avatar
I had Advanced Auto order it for me. I got it cheap though, so maybe you could try online.
Old 01-12-2014, 03:05 AM   #54
buttface
Drives: Brz
I had this done today,I have to say it's work, we just to cut the pipe, and bring down that frame to make it fit, plus all that bumper fun, I don't want to discourage anyone but you need to have some skills for this. On that note, soooooooooo worth it!
buttface is offline   Reply With Quote
Old 01-12-2014, 03:34 AM   #55
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
It might be beneficial to put the plastic piece that you removed back on.
Perrin talks about it a bit in their blog on their CAI development.
http://blog.perrinperformance.com/br...design-part-2/
Old 03-10-2014, 08:32 PM   #56
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
So... what paint did you use for the yellow shit? And has it held up well?
FRSTRM is offline   Reply With Quote
WTB: Injen intake Obja Engine, Exhaust, Bolt-Ons 3 01-10-2014 09:20 PM
Injen Intake seven Engine, Exhaust, Bolt-Ons 4 03-09-2013 01:40 AM
Does anyone in NE have an Injen intake 2forme New England 2 10-28-2012 05:22 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
