Old 07-18-2013, 08:39 PM   #85
Dezoris
Dezoris's Avatar
My cooler has been solid works better than expected.
@PERRIN_Mladen
My aeroquip hoses are too tight for my application can you have Jeff fab up some custom stainless lines with black fittings from BAT? Also with additional abrasion protection included?
Old 07-18-2013, 09:41 PM   #86
deange
Drives: Black 2013 BRZ Limited Automatic
Dezoris,
Is the tightness of the hoses the result of the different headlight shape between the FRS / BRZ (I'm assuming it was prototype'd on a BRZ given the review in your build thread)? I can see how / where it would rub and your issue makes me think it might be better to go with SS lines as well.
deange is offline   Reply With Quote
Old 07-21-2013, 07:44 PM   #87
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I'm just going to drop this here since I'm not getting help from nobody. I noticed oil leaking through the bottom piece of the Perrin spacer. So I took it out and noticed that the gasket is worn out after 4,000 miles.
Oil is sneaking through these holes..
Leaking through the piece on the top circle, initial damage through the bottom circle(maybe)
@PERRIN, can SOMEBODY help diagnose this issue!?
LeeMaster is offline   Reply With Quote
Old 07-21-2013, 09:48 PM   #88
deange
Any chance it could have been torqued down too hard? Did you already call Perrin?
Old 07-22-2013, 01:35 AM   #89
LeeMaster
Red wine
^ The instructions didnt even state the torque specs. I torqued it down enough so there wont be any free play with the system.
Old 07-22-2013, 02:00 AM   #90
deange
Did you try and get a hold of Perrin? I appreciate you letting the rest of us know about the issue, but I'd give them a chance to fix it first. I am interested to see what they say though.
I know the spacer in the Perrin kit is different from the standard Mocal one (Perrin one is black, and the Mocal one is silver) but I don't see much actual physical difference between the two.
The picture below is the Mocal one. The original poster of the picture did say he was non-plussed about the appearance of the Mocal one though. Link to the original post here
Old 07-22-2013, 08:46 AM   #91
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
In Perrin's instructions step 15g: Fully tighten thermostat housing adapter. Using a 27mm socket, tighten to roughly 25ft-lbs.
BatStig is offline   Reply With Quote
Old 07-22-2013, 10:14 AM   #92
LeeMaster
Red wine
It's Monday, I'll give them a call today and see what they have to say, it's been so quiet on the forums lately though...
They must've updated it, the instructions I have didn't even have what size socket to use, I remember running to autozone a couple of times because the instructions didn't list it(I bought the Oil cooler in the first month of release).
Thanks!
Old 07-22-2013, 11:20 AM   #93
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
LeeMaster, sorry about the O ring! We have updated the seal a while back to use two smaller O rings that should hold up better. PM me your info and we will get the new seals out ASAP!
PERRIN_Chris is offline   Reply With Quote
Old 07-22-2013, 12:26 PM   #94
Dezoris
Dezoris's Avatar
Dezoris,
Yes the prototype was built with Jeff's BRZ. When Chris sent me pics of the car with the Vortech kit, the lines were run differently because the BRZ headlamp design allows more clearance than the FRS.
So on the FRS with Vortech the lines are basically pinched going down the next to the intercooler pipes.
@PERRIN_Chris
Chris I know we discussed this before but any chance Jeff can fab up some actual stainless lines from BAT? (Black with Black Fittings)
Or are you guys still too buried?
Old 07-22-2013, 12:29 PM   #95
deange
Thanks for responding. I thought that might be the difference. There was plenty of room for the lines on my BRZ but I don't have a Vortech on there... yet.
Old 07-22-2013, 02:04 PM   #96
swift996
swift996's Avatar
@PERRIN_Chris
Sorry if I missed it but when is the re-released version going to be available? I got some hot oil!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-22-2013, 02:16 PM   #97
PERRIN_Chris
@PERRIN_Chris
I'll talk to Jeff and see if that is something that he's working on, or if we can do.
Originally Posted by swift996 View Post
@PERRIN_Chris
The new oil cooler kits are ready to go right now! We've shipped out a few kits late last week, and we will be shipping more very soon.
Old 07-25-2013, 01:53 PM   #98
swift996
swift996's Avatar
I ordered mine the other day in black
I can't wait because I'm dying to get back out to the track!
DIY- Perrin Oil Cooler/ Bumper removal notes Splat DIY (Do-It-Yourself) Guides 30 08-27-2014 01:12 PM
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
Perrin oil cooler trouble ft86me Engine, Exhaust, Transmission 9 04-29-2013 07:56 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 10:41 PM
Perrin oil cooler group buy? white devil Engine, Exhaust, Transmission 6 02-10-2013 03:17 AM
