Old 07-21-2013, 09:51 PM   #2913
Cameronghanson
Drives: n/a
after getting a bit more STI parts and made some custom brackets, threw up a badge
Cameronghanson is offline   Reply With Quote
Old 07-21-2013, 10:10 PM   #2914
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Great placement on the badge. Where'd you get it and how did you mount it? Just curious to hear your method.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-21-2013, 10:24 PM   #2915
Cameronghanson
Drives: n/a
Thank you! i made 2 brackets that surrounded that part of the grille and have to use clamps to pinch them tight. There is a flat lip underneath that trim piece that can slide part of the bracket on. Here is an extremely rough idea. I used alot of strong mounting tape and its holding incredible.
Oh and i got mounting brakets which came in a straight 2"x 9" bar from home depot
Old 07-21-2013, 10:57 PM   #2916
Scoobidude
Drives: DGM BRZ
Originally Posted by thill View Post
Installed my rear diffuser. This was $69.99 on EBay and looks no different to me than the Subaru one that sells for like $600.
I did reengineer the cheap plastic clips and used real metal hex bolts with locking nuts. Sorry for the bad iPhone pic, the sun is crazy intense today. I plan on adding aftermarket exhaust (I did upgrade the exhaust tips for now) at a later date:
when u did ur install. What did u do with the part on the diffuser the over hangs the bumper next to the end of the diffuser. I just over hung it and left it cause the bolt holes did go anywhere near the bumoer
Scoobidude is offline   Reply With Quote
Old 07-21-2013, 11:11 PM   #2917
thill
Unless you drill into the bumper there is nothing you really can do. So mine sounds similar to yours.
I did not take my bumper off for the install. It was a little crampt under the car, but pretty doable.
Old 07-21-2013, 11:25 PM   #2918
Scoobidude
Drives: DGM BRZ
I also didnt take off the bumper. Be outside brackets were the hardest. I had to pull the bumper down to get my hand threw to screw it down but yes. Very do able
Old 07-22-2013, 12:39 AM   #2919
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Originally Posted by tracerit View Post
where did you get that shift knob? tried looking but couldnt' find the leather one you posted.
i really like the look of the perrin shift knobs so i got one but because of the way i shift, it's too hard for me as I don't grab it open handed and my ring finger usually gets squished in there lol.
Probably from japanparts.com here: STI Shift Knob
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 07-22-2013, 09:47 AM   #2920
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Went to APM tuning in Chicago. Got my Valentine one hardwire'd in, Kartboy short shifter + bushings, DBA Rotors, Hawk HP Pads, lines, GrimmSpeed master cylinder and front plate adapter.
DoctorNick is offline   Reply With Quote
Old 07-22-2013, 11:58 AM   #2921
NIKDENG
Drives: RED BRZ
Got my frameless rear view mirror:
Installed my japan red aluminum air-con trim covers:
Completed my STI engine parts (strut bar, battery bar, oil cap, oil filter, radiator cap):
NIKDENG is offline   Reply With Quote
Old 07-22-2013, 12:49 PM   #2922
OoLong
#TeamAURA
OoLong's Avatar
Drives: BRZ Limited Lighting Red '13
Do you have a link to those air-con trim covers? That red is so awesome!
OoLong is offline   Reply With Quote
Old 07-22-2013, 01:17 PM   #2923
enwave
enwave's Avatar
Got my first speeding ticket in almost 10 years. Car in front of me was kicking up little rocks and I was nervous for my paint, so I got up a little over 50 in a 35 to get around him, then got back over in front of him and slowed back down to speed limit.
Cop saw me gun it past him, pulled me over. Was kind enough to downgrade to a six over, but wouldn't let me off with a warning.
Was very polite, called him sir, thanked him for doing his job, and asked him what I should do in the future in that situation, and he said "I don't know, slow down instead of speed up?"
Told him that the problem with slowing down is that I'm still behind those bouncing pebbles.
His response, "then just hope you get a happier officer than me next time."
Old 07-22-2013, 03:27 PM   #2924
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
I just curbed my wheel because some kid on a skateboard jumped out in front of me and I tried to avoid him and I got my back wheel.
ihaskrayon is offline   Reply With Quote
Old 07-22-2013, 05:29 PM   #2925
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Not sure what Utah laws are, but contest the ticket in court and if the cop shows up, claim mitigating circumstances. If the cop shows up to court, ask to have it kept off your record, pay a reduced fine, for traffic school, or any combination of the above. Also, demonstrate that you passing him was safe to do at the time.
There should be more information online about contesting a speeding ticket in Utah.
DoomsdayJesus is offline   Reply With Quote
Old 07-22-2013, 05:33 PM   #2926
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Too much clashing red with the STI button and shift knob and AC controls.
