Old 07-18-2013, 08:27 PM   #1
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Which brake package is the better value
I am looking to upgrade the stock braking system, but on a budget so no bbk at moment. I am thinking maybe brake lines and better rotars would go a long way to improving the stock braking system
Cant decided between these two though
http://ft86speedfactory.com/stoptech...grade-216.html
http://ft86speedfactory.com/ft-86-sf-stage-427.html
vignesh is offline   Reply With Quote
Old 07-18-2013, 09:19 PM   #2
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
If you are really on a budget. Lines (change the brake fluid when you do this), pads and master brake cylinder.
Given your the two choices, I would go with the Stage 2 kit.
andrewFT86 is offline   Reply With Quote
Old 07-18-2013, 09:22 PM   #3
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
If you track --> Project Mu Club Racer F/R pads and Motul RBF600 fluids are all u need
If you dont track --> keep it stock, dont bother wasting money, OEM systemt is very well built and last long long time
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following 5 Users Say Thank You to RehabJeff86 For This Useful Post:
Anthonytpt (07-19-2013), B L U E S L A T E (07-20-2013), CSG Mike (07-19-2013), GTM_Challenge (07-19-2013), Sportsguy83 (07-19-2013)
Old 07-19-2013, 07:49 AM   #4
mrk1
Drives: Sterling BRZ Ltd
What kind of driving do you do? If you have never over heated your stock pads then save your money.
The pad selection is pretty different in those options. The Hawk/DBA is more aggressive then the StopTech.
I run a Stoptech BBK just because I love brakes not because I need them and I have the Stoptech pads. They are great for street use.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-19-2013, 08:17 AM   #5
wparsons
wparsons's Avatar
IMO, all you NEED are pads and fluid for track use. Unless you're REALLY serious about time attack the stock rotors are plenty good. If you're into endurance racing then you'll need a BBK, but I doubt that's the case here.
I personally also added a MC brace and stainless lines, but those are for feel not braking power or fade resistance.
What specifically do you feel needs improving?
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Burrcold (07-20-2013), CSG Mike (07-19-2013)
Old 07-19-2013, 10:58 AM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Sticky tires and better brakes/fluid is all you need. Bbk is just a waste of money.
Sent from my HTC One using Tapatalk 4 Beta
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-19-2013, 10:59 AM   #7
celica73
My car stops just fine with upgraded pads and a good high temp fluid. No overpriced slotted rotors needed, no braided steel lines needed, no MC brace needed.
I regularly autocross and occasionally track (2-3 events/year) the car.
Old 07-19-2013, 11:34 AM   #8
CSG Mike
CSG Mike's Avatar
I dunno about that... this is WITH a BBK, and no power adders, and street tires.
Old 07-19-2013, 01:16 PM   #9
wparsons
wparsons's Avatar
To be fair, what sort of event were you running when they were that hot? Was it a time attack (~3 hot laps max) or more of an endurance format?
flickr
Old 07-19-2013, 01:18 PM   #10
wparsons
wparsons's Avatar
Lines and MC brace won't do a single thing for stopping power/distance, but they do make the pedal feel a lot better. Definitely not needed, but for the ~$100 on lines I figured I might as well do them when I was flushing out the OEM fluid anyway.
flickr
Old 07-19-2013, 01:30 PM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
What I'm saying is you won't see a big difference going to Bbk. You will probably stop 6 feet less. If you have the means to blow a few grand to stop 6 feet less go right ahead. Also that pic can be done with better pads/rotors and will run you less than 600.
Old 07-19-2013, 01:47 PM   #12
vignesh
Engineer
vignesh's Avatar
I am talking about canyon driving. While driving downhill specially . I noticed a huge difference ce and the brakes fade way too fast for my liking. BBK I think is am overkill in my opinion. I was thinking more in the route of just better rotors and pads. My question was that the stop tech replaces all 4 discs while the stage 2 gives u Dba rotors in the front and some motul brake fluid. Which would yield better breaking and less fade. Uphill and downhill driving in the canyon an hour puts a lot of stress on the breaks much more than say a typical auto cross run.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
Old 07-19-2013, 01:58 PM   #13
swift996
swift996's Avatar
Pads + Fluid...stainless lines are cheap too
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-19-2013, 02:00 PM   #14
CSG Mike
CSG Mike's Avatar
Just a ride-along at the last FT86CUP event (HPDE). This picture is from the end of the first (and only) hot lap.
Here's another picture at the beginning of the hot lap. The temperature gradient is much more obvious here because the rotors haven't soaked as much heat yet.
Even with the BBK, I can (and will) fade the brakes, with a BBK, with 2000+F MOT pads when canyoning. Canyoning is often harder on brakes, since you don't see high enough speeds to really get a lot of cooling on the brakes, and you're constantly braking back to back.
It really comes down to what each person needs at their level of comfort and experience.
In our case, the BBK's ultimate purpose is to reduce long term operating cost; the extra fade resistance is just a perk.
The BBK doesn't reduce stopping distance in any way. See this post: http://www.ft86club.com/forums/showp...54&postcount=2
On a side note, 6 feet, when braking with ABS, is the difference between impacting the car in front of you at ~10mph (and taking out your bumper, impact beam, as well as theirs, and other misc damage), or stopping right at their bumper.
Anthonytpt (07-19-2013), InvalidJohnny5 (07-19-2013)
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 04:57 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
