Old 07-19-2013, 11:06 AM   #99
qoncept
qoncept's Avatar
Not familiar with the automatic but with the few I've driven I would guess it would just ignore you and use a more reasonable gear. It'll probably let you in 6th at 25mph, probably not any slower.
I filled up yesterday, my worst tank at 29.7mpg
qoncept is offline   Reply With Quote
Old 07-19-2013, 11:24 AM   #100
BRZ-OwnzJo0
BRZ-OwnzJo0's Avatar
Drives: 2016 WRX Limited
Originally Posted by qoncept View Post
I almost never use 5th unless I'm going up a hill at 30mph. It's seemed to me the lower the rpm the better. Anything over 60mph and you're definitely losing though.
Going up a hill at 30 MPH in 5th isnt giving you way worse gas mileage than going up that hill in 3rd or 4th at 30? I'm not sure about that. Yea, anytime I'm at 60+ I'm putting it into 6th for sure.
I need to do a lot more driving before I can really figure out the gearing and whats best MPG wise. I've only put 500 miles on it so far.
BRZ-OwnzJo0 is offline   Reply With Quote
Old 07-19-2013, 11:29 AM   #101
qoncept
qoncept's Avatar
Well, I'm probably at 15% throttle and losing speed. Once it starts bog I'll downshift. The hills aren't steep and aren't very long. I live in Iowa :P If you aren't trying to accelerate fast you can be in a higher gear than most people would even consider.
Old 07-19-2013, 11:31 AM   #102
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Do you guys throw it into 6th asap or keep it in 5th a lot of the time? I find that outside of the highway I usually get better gas mileage in 5th. I try to keep it between 2k and 2.5k when cruising in the city because that seems to be the sweet spot for gas mileage.
Try droppping it into one gear higher and between 1.5k and 2k, I'm seeing 30-40+ mpg on the instant display when I do that over the past month or so.
But your right, it's "happiest" and seems to run best above 2k.
ineedyourdiddly
Old 07-19-2013, 11:35 AM   #103
Chee-Hu
Chee-Hu's Avatar
I got 32 on my last fill up. I changed my speed on my morning commute from 75mph to 70-71mph. The afternoon is still stop and go until I find a better route.
Chee-Hu is offline   Reply With Quote
Old 07-19-2013, 12:19 PM   #104
With the 86 in manual mode, you have full control. Only thing it won't do is let you over-rev or stall the engine (around 800RPM it will drop the gear down).
If you have it in D you can shift it, but it will, after a short time, switch back to what it thinks is best.
Old 07-19-2013, 12:35 PM   #105
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Im averaging 28-30 mpg. And this is city driving but i guess driving on PCH helps will the long straights majority of the time. But i do keep the car in 5th gear and go into 6th when i past 60mph or above 3500rpm.
Lakers86 is offline   Reply With Quote
Old 07-27-2013, 09:55 PM   #106
FnFast
Doctor
FnFast's Avatar
Drives: Fast
See below, That is combined and imagine Philadelphia traffic. I do get about 33mpg when cruising on highways with the AC on.
Jeremy Clarkson "If you go though the Pearly Gates, backwards, in a fireball, that's a cool way to die!"
2013 White Pearl BRZ Limited 6MT - 15% Tint, Debadged, HIDPowerhouse LED Interiors and Dome
FnFast is offline   Reply With Quote
Old 07-28-2013, 11:01 AM   #107
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
4500 miles, 1 year old now. Averaging 29 mpg calculated consistently on 91 octane, and original tires. BRZ Limited 6MT. I wring it out to 4-5k rpm for most low gear shifts, cruise in 5th gear at 45-55mph, then 6th gear for 55+. I take it up to 6-7k rpm now and then.
Not much highway miles, but my commute is a 55mph single lane road with lights - so if I make the lights, it's a straight 6th gear, low rpm cruise. But that's 50% of my driving - and my commute home has a lot of stop & go traffic. The rest of my driving is in town.
My WRX (stage 2) has dipped into the 16-17mpg range doing similar driving.
ashtray is offline   Reply With Quote
Old 07-29-2013, 11:43 PM   #108
Gintsuki
Drives: Subaru BRZ Limited '13
I have an automatic and play with the paddle shifting whenever I'm not in traffic. Take corners like a crazy person. Accelerate like every light is a race. And use my car mostly for commuting.
I'm getting avg 27.2 mpg
Gintsuki is offline   Reply With Quote
Old 07-30-2013, 12:02 AM   #109
ericmpena
ericmpena's Avatar
My normal driving gets me 27 MPG on a 6 speed MT. If I have my dash display showing the Avg. MPG I tend to be more cautious about my driving and will stick around 31 MPG.
ericmpena is offline   Reply With Quote
Old 07-30-2013, 12:07 AM   #110
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Originally Posted by shiumai View Post
I'm between 20-21 mpg, AT based on fillups/mileage. street driving only in traffic, and not driving to conserve gas.
@shiumai, Being you and I probably cover similar distance in a typical day, I'm glad to hear somebody else is getting MPG on the lower end of the EPA estimate like I am.
mit_peid is offline   Reply With Quote
Old 07-30-2013, 09:27 AM   #111
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
LOL - must be a redondo beach thing for us. i'm 4.5 miles from work; i usually take aviation. if i took sepulveda i bet my MPG would drop to 10, LOL.
shiumai is offline   Reply With Quote
Old 08-04-2013, 09:33 AM   #112
OakmanSmalls
I have a premium MT. And after 3500 miles I'm averaging 32 mpg. A lot of that is the road trip but its always 30+ even around town. I don't drive very hard (often) and have a drop in k&n filter and invidia q300 catback
OakmanSmalls is offline   Reply With Quote
real world mpg frs/brz muffinman Scion FR-S / Toyota 86 GT86 General Forum 131 07-13-2017 02:26 AM
Perrin oil cooler real world review. Impressions. Racecomp Engineering Engine, Exhaust, Transmission 40 03-18-2013 02:31 PM
Any Real World 1/4 Mile Traps? bimmerboy Scion FR-S / Toyota 86 GT86 General Forum 11 03-03-2013 03:48 PM
Real-World Data importing into GT5 SnapOv3st3r Other Vehicles & General Automotive Discussions 0 09-07-2012 06:25 PM
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
