Old 04-19-2013, 03:20 AM   #1
scyzer
Drives: GTS 86
Removing the door handles
Has any one successfully removed the external door handles yet?
I know Grazio makes replacements:
http://i1108.photobucket.com/albums/..._door_02up.jpg
However, I haven't seen any guides on how to do it. On my 86, I've tried removing the rubber stopper directly opposite of the handle from the inside, thinking it might give access to a screw or a bolt, but no luck.
Any clues (hopefully without removing the entire inner door panel)?
scyzer is offline   Reply With Quote
Old 04-27-2013, 03:10 PM   #2
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
any clues or DIY for this kind of project would be great. I have seen plasti dip but I would prefer vinyl wrapping.
besides, Grazio prices though very nice, are so pricey.
thanks
j2digit is offline   Reply With Quote
Old 04-27-2013, 03:36 PM   #3
charged86
charged86's Avatar
That does not appear to be real carbon
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-27-2013, 04:04 PM   #4
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
just go and take the car apart, and work it out, its not rocket science.
get tools. take uphostery out and go from there, why do you guys need a DIY? i mean its not difficult, and about every car is the same.
njccmd2002 is offline   Reply With Quote
The Following User Says Thank You to njccmd2002 For This Useful Post:
nickmerronesucks (03-23-2016)
Old 05-11-2013, 10:39 AM   #5
Chaetagnath
In case you are still interested, its actually quite simple.
On the door, Remove this piece of trim (it pops right off).
Underneath there is a hole, if you look in there you will see a T-30 torque screw
Loosen this screw. It is held by clips so that it doesn't fall into your door. As you loosen it, the lock will drop out the other side. Pull it out completely.
Once this is done, the handle slides towards where the lock was.
You can now slide the new handle in place, put the lock back in, tighten the torque screw and you are done!
Chaetagnath is offline   Reply With Quote
The Following 13 Users Say Thank You to Chaetagnath For This Useful Post:
Books (05-11-2013), boonFRS (03-11-2015), cslntuee (07-18-2013), GaN-MaN (12-23-2013), hamzam (05-03-2015), j2digit (05-12-2013), JiB (07-17-2013), Norcalmav23 (11-26-2013), NYCsubaruBRZ (11-18-2013), scyzer (05-13-2013), SuperTom (10-17-2018), Tvo (06-26-2015), whataboutbob (03-20-2025)
Old 05-13-2013, 09:45 AM   #6
scyzer
Drives: GTS 86
Originally Posted by Chaetagnath View Post
In case you are still interested, its actually quite simple.!
Awesome! Thanks.
I'll try giving this a go this weekend.
Old 07-18-2013, 06:14 AM   #7
cslntuee
Drives: Subaru BRZ Limited
HI,
I did try.
However, I get the small out and thelarge handle shifts a little to rear but does not
come out.
Did I miss something? Please give me some guidance.
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 07-19-2013, 11:08 AM   #8
Chaetagnath
Originally Posted by cslntuee View Post
HI,
I did try.
come out.
Thanks a lot.
Once you pull the lock out the handle should slide pretty easily to the right then you can pull it out. It worked pretty simply for me, not really sure what else to say.
The Following User Says Thank You to Chaetagnath For This Useful Post:
cslntuee (07-19-2013)
Old 01-12-2014, 07:35 PM   #9
byt0316
Drives: Toyota 86
Hi,
I was able to removed the small out but not the large handle. i tried to slide it down toward the lock (small part), but It won't pull out. My 86 has the smart key with the sensor on the handle.
Please help. Tnx.
byt0316 is offline   Reply With Quote
Old 01-22-2014, 04:25 AM   #10
Dantical
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
any updates on this one ?? got the smart key too!?
Dantical is offline   Reply With Quote
Old 03-22-2016, 10:07 PM   #11
edigeek
Drives: 2014 White BRZ Limited
Can someone help me please ? I can't get it out either when I slide it to the right after the smaller part is out.
edigeek is offline   Reply With Quote
Old 03-22-2016, 10:14 PM   #12
Gunman
Drives: 2019 Mazda Miata RF
Shave the handles!!
The Following User Says Thank You to Gunman For This Useful Post:
8R6 (03-23-2016)
Old 03-23-2016, 02:36 PM   #13
Chaetagnath
If you have the smart key it has a screw on the inside holding a bracket. To get the handle off you will need to remove the interior door card, and carefully remove the screw from the other side first. Then it will slide out.
Old 03-25-2016, 01:03 PM   #14
edigeek
I figure it out, you also have to remove the sensor that's inside the handle which is a total head ache. Unless you remove the glass/regulator, you will spend quite sometime removing the sensor. here's how you do it
http://www.ft86club.com/forums/showthread.php?t=81509
CEL after removing cat? corvino26 Engine, Exhaust, Transmission 8 06-17-2013 09:15 AM
Removing the Spoiler? kmartt Scion FR-S / Toyota 86 GT86 General Forum 24 04-19-2013 05:10 AM
FS: Interior Door Handles (LH & RH) Skorov Australia Classifieds 6 04-14-2013 04:41 AM
Remove door handles? scyzer DIY (Do-It-Yourself) Guides 3 01-09-2013 03:08 PM
WTB Door Handles!!!!! jazztennor Interior Parts (Incl. Lighting) 0 12-29-2012 07:52 PM
