Old 07-18-2013, 05:09 AM   #15
mixcorp
Drives: brz
What is the torque spec for the alternator and water pump pulley ?
mixcorp is offline   Reply With Quote
Old 07-18-2013, 09:47 AM   #16
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
alternator nut: 108 Nm / 80 ft lbs
water pump bolts: 14 Nm / 10 ft lbs
then again, the service manual says 15 ft lbs + 90* for the crank pulley. assuming that equates to 94 ft lbs, the torque specs are correct
supramkivtt2jz is offline   Reply With Quote
Old 07-18-2013, 08:57 PM   #17
Turdinator
Señor Member
Turdinator's Avatar
I think you'll find that means torque to 15ft/lbs then turn the bolt a further 90 degrees from there. A lot of modern cars have bolts that are tightened by degrees instead of a torque i believe.
1974 TA22 Celica
2013 86 GT
Old 07-18-2013, 09:00 PM   #18
Hawk77FT
Drives: GTS 86
Originally Posted by VietnamPhenom View Post
Just lightweight.
Where did you get them from and how much they set you back?
Hawk77FT is offline   Reply With Quote
Old 07-18-2013, 10:12 PM   #19
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
yes...... thats why im saying if it equates to 94 ft lbs, then the other torque specs are to be trusted
Old 07-18-2013, 10:36 PM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
You can get them online from one of the most trusted websites for this car:http://ft86speedfactory.com/go-fast-...234b62f0a3a540
They cost $345 without shipping and handling, I don't know what he got them for, but there is also another kit that gets similar performance:
http://ft86speedfactory.com/tomioka-...234b62f0a3a540
but costs $316
The latter is 0.64 lbs heavier not that much weight still and won't make as much of a difference but it should be noted, also tomioka apparently dynoed them and gained 10 WHP which I'm not so sure about pulleys do free up horsepower but not that much, the gains from both of them will be similar and anything that lowers power loss and load on the motor is a good thing.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
FT-86 SpeedFactory (10-09-2013), Hawk77FT (07-18-2013)
Old 07-18-2013, 11:35 PM   #21
Hawk77FT
Drives: GTS 86
but costs $316
Much appreciated mate.
Old 07-18-2013, 11:39 PM   #22
FRSBRZGT86FAN
Smile
No problem its a good performance investment.
Old 07-18-2013, 11:47 PM   #23
Hawk77FT
Drives: GTS 86
Looks like it mate. Tomioka looks like they have the Alternator and Water pump much lighter than the competitors. hmmmmm I will investigate to see if they sell it separately.
Old 07-19-2013, 08:03 PM   #24
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
eBay and $250 shipped new.
VietnamPhenom is offline   Reply With Quote
any info or diy on the go fast bits pulley set fluffy-reindeer-slayer Engine, Exhaust, Transmission 2 07-17-2013 09:13 AM
FS: Kartboy Lightweight Crank Pulley OrbitalEllipses Engine, Exhaust, Bolt-Ons 6 03-21-2013 08:21 AM
Go Fast Bits Lightweight Pulley Kit on sale & Free Shipping @ Circuit Motorsports Circuit Motorsports Engine, Exhaust, Bolt-Ons 58 03-20-2013 02:07 PM
My lightweight crank pulley experience WolfsFang Engine, Exhaust, Transmission 22 11-29-2012 02:15 AM
Ralco RZ Lightweight Crank Pulley HELP! JERZgrl88 Engine, Exhaust, Transmission 11 10-10-2012 12:41 PM
