Old 07-10-2013, 10:13 PM   #29
Bt216
Bt216's Avatar
Drives: Scion frs
1/13 only the chirping comes and goes
Bt216 is offline   Reply With Quote
Old 07-10-2013, 10:59 PM   #30
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Okay. At least the low rpm rattle with the flywheel trans is normal. That's pretty much the only thing that is odd so far about my car. Glad to know that it just isn't my car.
So far with about 550km of light break-in kms, everything is getting smoother with the more kms I put on the car. No crickets as of yet *knocks on wood*.
My car was built May 2013.
hmong337 is offline   Reply With Quote
Old 07-17-2013, 10:06 AM   #31
CyberCT
Drives: RSX
I test drove an FRS and really love the car. I'm 90% dead set on buying one but seeing all the issues that propped up in the first year, I'm pushing myself to hold off until the 2014s come out, and confirmations that numerous little fixes had been made.
CyberCT is offline   Reply With Quote
Old 07-17-2013, 10:49 AM   #32
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i have a mid 13 build date. I have experienced every issue reported.
Been to the dealer twice for crickets
rear deck popping
drivers window scratching
shifter rattling
ac compressor chirp
squeeking windows
5th gear syncro when down shifting
window switches rattling
supramkivtt2jz is offline   Reply With Quote
Old 07-17-2013, 11:30 AM   #33
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
My car has been very reliable! I bought mine in late June or early July of 2012... I forget... I know I was one of the first owners. :P The only issues I have had are crickets, chirps of the A/C, and low coolant level after 14k miles of driving... Which doesn't surprise me that it was low, I topped it off and it is still running strong. Maybe it's because I don't push it like a race car all the time... I only do it when it is needed or I feel it needs to get some exercise. Other than that... I get about 32mpg using Mobile1 0w-20 fuel economy. Works great. No major issues so far... Needless to say, I am very happy how this car has been behaving this past year. Now if I could only stop those cricket noises... lol
Surakusa is offline   Reply With Quote
Old 07-17-2013, 11:32 AM   #34
nalc
Drives: 13 BRZ Limited 6MT GBS
Jan 2013 build, a bit less than 1100 miles on it, VIN in the low 7000s (BRZ)
2nd gear can be a bit clunky occasionally, and I have some condensation in tails. It's only a little and it dries quickly, but it's definitely there. No crickets or package shelf or CEL issues though.
nalc is offline   Reply With Quote
Old 07-17-2013, 11:56 AM   #35
usdmnotjdm
Large Member
usdmnotjdm's Avatar
Drives: BRZenith
Just picked up mine on Saturday. May 2013 build date. I'll follow up with any issues. (Only 675 miles or so currently.)
usdmnotjdm is offline   Reply With Quote
Old 07-17-2013, 12:35 PM   #36
nalc
It'd be helpful to post the last 4 digits of your VIN, or at least the fourth-to-last and third-to-last digits if you want to keep some privacy. That gives a bit more info than the build date, because the TSBs list the VIN that they were cut into production on.
I have a BRZ #72xx.
The tail light condensation was fixed on #7611 per the TSB.
Chirp is #7798 per the TSB.
GPS is #3982 per the TSB.
I have had no chirp (but I have low miles), I do have condensation (which makes sense, because they fixed it at a higher VIN), and my GPS is mostly fine (I lost signal once but it was a wooded area, and it came back in a minute or two).
Old 07-17-2013, 05:07 PM   #37
CyberCT
Drives: RSX
hmm good to know. 2014 model is starting to look appealing in a few months. Were there anymore. Official documented fixes not mentioned here?
Old 07-17-2013, 08:16 PM   #38
nunonuna
nunonuna's Avatar
Originally Posted by jacobzking View Post
are you guys with later production date cars (like 2013) having better luck with your cars? or are you guys still having a lot of the same issues?
To be honest with you, it is not reliable yet.
Mine was built in April 13, but still has some issues.
Idle dip with cricket noise(this one has to be fixed since
TSB was listed before my car is built) It only has 800 miles on it.
I am very disappointed by Toyota and subaru, but
I'm taking it in to the dealer next Monday so hopefully
everything get fixed.
nunonuna is offline   Reply With Quote
Old 07-17-2013, 08:32 PM   #39
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
My VIN is over 10000 (4/13 production), and I have both condensation and chirp. Neither bothers me, but they're both present.
My previous car (1/13 production) had condensation, but no chirp (at least not noticed in the ~8300 miles I drove it).
Admiral Ballsy is offline   Reply With Quote
Old 07-18-2013, 09:41 PM   #40
chilejeep
Drives: DGM BRZ
Jan 13 build intermittently crickets and three times now hasn't started..won't even crank.
chilejeep is offline   Reply With Quote
Old 07-19-2013, 08:59 PM   #41
chuchutrain
Drives: Firestorm
Originally Posted by whaap View Post
The later the build date the more likely you are to not have as many problems as the earlier builds. Mine was August 2012 and the only (key word only) issue I've had in 10,000 miles was the rattle from the package shelf that has become so minor that I no longer am concerned about it.
package shelf... like the dashboard?
i just brought my car in since my driver side speaker housing was rattling. they ordered a new speaker just to make sure the existing one wasn't defective.
also, i had squeeking window, only when wet. and i have the chirp, but really, if the HFPF makes that noise, it makes that noise. it's only an issue if it actually causes issues right? at this point i just consider it part of the frs engine sound, much like porsches have that metallic crunching soda can sound. it's not endearing, but if no one pointed it out, most of us wouldn't have been listening for it.
chuchutrain is offline   Reply With Quote
Old 07-20-2013, 12:22 AM   #42
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
The package shelf is the shelf behind the rear seat that your third brake light is mounted on.
whaap is offline   Reply With Quote
Will the FR-S end up on the list of the "10 slowest sports cars of all time"? Davyator Scion FR-S / Toyota 86 GT86 General Forum 30 10-10-2014 08:59 AM
Jalopnik: "10 most desirable cars of 2012" - guess who is at #1? frsinpa Scion FR-S / Toyota 86 GT86 General Forum 3 12-26-2012 12:38 PM
Toyota's Slick "86" Interactive Origins-to-Production Website ShoGun Scion FR-S / Toyota 86 GT86 General Forum 10 07-13-2012 11:34 AM
New C&D production BRZ review... "Porsche-like Handling" Sport-Tech BRZ First-Gen (2012+) — General Topics 112 04-29-2012 01:10 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
