Old 07-17-2013, 01:15 PM   #309
xxscaxx
Drives: 2013 SWP BRZ
You can verify the AFR's by datalogging through EcuTek. I monitor mine as well with my P3 gauge.
xxscaxx is offline   Reply With Quote
Old 07-17-2013, 01:16 PM   #310
FA20Club.com
Drives: 2013 White Out FR-S
the base Mike had was run on the dyno i made 1 change to the map and sent it back to him and he ran it again and the entire thing was lean. i emailed him back told him to run the car at the same temps and conditions as the first really rich pass and he said it was even leaner no changes still. i reviewed his logs and told him to leave the car alone i found the issue and would work over his map today. this was honestly not cleared with me since we were still logging and he called to tell me he decided to go to the dyno and he was already strapped down. which i dont mind but require prior notice to make time to to scheduled dyno tunes. i didnt get another response for over 3 hours so i guess this was when he left to go to work.
FA20Club.com is offline   Reply With Quote
Old 07-17-2013, 01:17 PM   #311
FA20Club.com
correct the whole purpose is to do the preliminary via logging prior to going to the dyno. if you do decide to go to the dyno give me a heads up cause im not always in the office all day.
Old 07-18-2013, 12:18 PM   #312
xxscaxx
Posted this once but no one responded.
To those who have the kit installed - can you verify your BPV moves a little bit? Its held in place by two rivets on the backside but mine has some slight play in it.
Old 07-18-2013, 12:18 PM   #313
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
For those of you that bought the innovate from FA20Club and sent in the first set of data logs (1st thru 6th gear, and 3rd gear pull), have any of you received a revised tune yet (after the basemap)? I'm curious what the turn around time is but don't really want to bother Tony with more questions.
Sent from...somewhere?
Old 07-18-2013, 12:19 PM   #314
RedLeader
RedLeader's Avatar
Mine wiggles a bit. I'm not worried about it coming off, but I was more careful with it during the install.
The Following User Says Thank You to RedLeader For This Useful Post:
xxscaxx (07-18-2013)
Old 07-18-2013, 12:25 PM   #315
xxscaxx
I wasn't worried it would come off, just that it was normal. Thanks for posting.
Old 07-18-2013, 12:28 PM   #316
xxscaxx
by the way, from the looks of it, it seems the only two intakes that could work for us are the perrin intake and Airraids intake box.
I'm trying to source a used airraid box to test. I like perrin's but its too much tube if mated to the Innnovate tube (to me at least anyways)
Old 07-18-2013, 12:53 PM   #317
s2d4
s2d4's Avatar
Please give me the money? at least it will save you from losing power
Old 07-18-2013, 01:01 PM   #318
xxscaxx
I want to test it....but honestly will probably just keep the stock air box. I would not buy a brand new intake because I know they do nothing for power.
I'm pretty sure i've seen posts from you slaying intakes and their power gains, and thats not what I was after - Yes I wanted to see if the sound would increase but also just trying to do the community a favor and find out what fits or not lol.
There is a reason I haven't put an intake on my car in the 9 months i've owned it. I'm well aware.
Old 07-18-2013, 01:03 PM   #319
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Hey guys, the serial number of your specific kit is listed on your instruction manual. I think for the sake of future troubleshooting it would be nice to match each owner with their serial number. Shout yours out and I will add it to the first page.
Old 07-18-2013, 01:19 PM   #320
xxscaxx
Will do, once I get home. Isn't it stamped on the charger as well?
Old 07-18-2013, 01:29 PM   #321
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
I am still waiting on my base tune.. filled out the form tuesday night.. It is making me a little worries about the turn around time for a revised tune though.
MattF is offline   Reply With Quote
Old 07-18-2013, 01:33 PM   #322
DarrenDriven
NW Region Moderator
Yeah, it is engraved on top.
Mine is S5-210-180213-0012
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
