Old 07-17-2013, 12:12 PM   #295
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Dezoris View Post
If any innovate owner has pulls in 2nd from 3000RPM to redline and 3rd please post them.
I don't know about the variance in dynos but I just compared your clips side by side with cars showing 212HP and 190TQ on a dynojet and your 2nd gear pull is almost identical, certainly not 30HP more.
So keep that in mind you maybe at the limit based on those numbers but I think at least on dynojet and mustang you are under.
Once i'm done getting my map adjusted I will be happy to post up pulls. are you talking logs or in car video?
xxscaxx is offline   Reply With Quote
Old 07-17-2013, 12:22 PM   #296
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by djdnz View Post
AFR's are brutal, time for a tune.
that is a tune. that's the final tune I used. you should have seen the previous tunes. AFRs up to 18+ /shudder
wrxgoose is offline   Reply With Quote
Old 07-17-2013, 12:26 PM   #297
xxscaxx
isn't Tony tuning you? did you get remote tuned or something by him at the dyno?
Old 07-17-2013, 12:37 PM   #298
djdnz
1337
Drives: 2013 BRZ WRB S/C
Either they need to look at it again or the AFR reading is messed up or there is something else wrong with your car. You're going from overly lean to way rich.
18 AFR? Please say it wasn't full throttle.
This is what it should look like (NOT an innovate graph, I stole this from sportsguy's thread for reference):
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Sportsguy83 (07-17-2013)
Old 07-17-2013, 12:43 PM   #299
wrxgoose
WUB WUB
WOT, it was over 18. And tony was, but I really had to get to work, so I had to have someone else fine tune it, so I could go try and make some money to pay my bills.
Old 07-17-2013, 12:44 PM   #300
djdnz
1337
wow.
Pay the money for someone who knows what they are doing, otherwise you'll be looking at a hole in your engine and walking to work
xxscaxx (07-17-2013)
Old 07-17-2013, 12:47 PM   #301
xxscaxx
I'm not understanding - Even with the base map Tony gave me the car was ok to drive around. I've been driving around on it and treating it cautiously and giving data logs back and forth.
Even with the one or two revisions I had and I knew the car was acting up in certain spots, it was still ok to putz around on. My AFR's were never even close to that high through those spots either.
That AFR curve is scary man.. i'd get it looked at again or continue to have tony edit your previous tune with him.
Old 07-17-2013, 12:49 PM   #302
wrxgoose
WUB WUB
base map was good, but when I got the revised map, the AFR was that lean. that was the first run on the revised map.
Old 07-17-2013, 12:59 PM   #303
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
How many pulls did he do with that AFR being so lean? I am gonna go out on a limb and say that the reading is in accurate. That high of AFR and you WOT would have put a nice big hole in the block. Either way get the tune and car checked out. Best of luck.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-17-2013, 01:02 PM   #304
wrxgoose
WUB WUB
I did one pull with it that high, then refused to do anymore until we fixed it
Old 07-17-2013, 01:03 PM   #305
xxscaxx
Yeah I have to agree..it seems like something is up with that reading.
I'm looking through all of my data logs right now. I've been through 5 revisions and not one of them ever goes over 15, and thats partial throttle (cruising). WOT slopes right down to 11.02 where it holds steady.
Old 07-17-2013, 01:04 PM   #306
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
...it's amazing what these new motors take. The DI allows you to keep firing when it is super lean, and the timing retard works quite well. Sodium filled valves keep you from melting them, as does the late firing of the direct injection (more cooling vs fueling). So while long term it will be disaster, I think the car is likely fine if you're still running and pushing 240whp.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 07-17-2013, 01:05 PM   #307
xxscaxx
That's a breath of fresh air
Old 07-17-2013, 01:14 PM   #308
wrxgoose
WUB WUB
lol pun.
sorry, couldn't resist. I do have a final map to try, but I don't have access to the dyno to verify AFRs until later in the week. I'll try to get back out there on friday
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
