Old 06-03-2013, 08:33 AM   #29
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by UbSaMrC View Post
Sent from my SPH-D710 using Tapatalk 4 Beta
That is interesting. You're running an android OS and seems to be Wi-Fi as well. Do you have to use a mouse or can you "touch?"
YamahaR86 is offline   Reply With Quote
Old 06-03-2013, 08:57 AM   #30
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I believe he is judt mirroring a tablet through the A/V port
lbroskee is offline   Reply With Quote
Old 06-03-2013, 02:55 PM   #31
UbSaMrC
UbSaMrC's Avatar
Drives: 13 FR-S Asphalt AT
I used a MK812 from miniandroidpc.com
UbSaMrC is offline   Reply With Quote
Old 06-03-2013, 02:57 PM   #32
UbSaMrC
UbSaMrC's Avatar
Next step is integrating mimics 2 until then I am using an air mouse
Old 06-04-2013, 01:37 AM   #33
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
In for more info
Old 06-20-2013, 11:52 PM   #34
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I'm super fed up with my BeSpoke, but if I could get A/V into it then I might like it again. I have a small media player (IOGEAR) that outputs to regular RCA cables (white, red yellow). Could I stash this in the glovebox and then actually use it to watch and hear the video?
Old 06-20-2013, 11:54 PM   #35
lbroskee
lbroskee's Avatar
seems like it. just get power from ur glovebox outlet and ur good to go. i kinda wanna hook up a video game to this lol
Old 07-16-2013, 07:03 PM   #36
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
For this step:
3) Cut the pink/green wire in slot 17 (VSS) and install a switch in between. This will allow you to continue watching the video while moving. Optional and I am not responsible if you get in an accident.
Can you just ground the wire instead?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-16-2013, 07:18 PM   #37
l0aded
Addicted
l0aded's Avatar
Shows the wiring attached to a 3contact 35mm connecter that will connect to a MK812
How are you connecting the MK812 since it takes mini-HDMI? Are you using a HDMI -> RCA convertor box or is there a non active way of doing it?
Old 07-16-2013, 09:13 PM   #38
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
just letting the other people know, for us zephyr bespoke it doesnt work. i tried it.... didnt work. unless i did it wrong. if so correct me if im wrong to whomever tried it too.
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
The Following User Says Thank You to Lanbaldo3 For This Useful Post:
lbroskee (07-16-2013)
Old 07-16-2013, 11:58 PM   #39
l0aded
Addicted
l0aded's Avatar
I'm going to give it a shot this weekend. Fingers crossed.
What happened when you tried it? Did anything change at all?
Old 07-17-2013, 01:36 AM   #40
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
@l0aded nothing, i dont have to come to a complete stop anymore to be able to scroll down anywhere in my song list, due to the vss was cut off. I was gonna do that anyways, thats why i gave it a shot. I also hoped bespoke icon would change or at least use the screen for it but nothing happened. So I am guessing someone has to come up a way to access the video monitor for bespoke, in order to use that screen.
Drift Specials.....
l0aded (07-17-2013)
Old 07-18-2013, 03:28 AM   #41
l0aded
Addicted
l0aded's Avatar
I read in another thread that the Zypr BeSpokes in the US don't have AUX input because they opted to have it output video with the aux line for ipod connectivity. If this is true would it work if we used a 30pin to 3 RCA cable to activate AV mode?
Something like this: [ame="http://www.amazon.com/Easily-connect-iPhone-composite-inputs/dp/B0072IHW6I"]Amazon.com: 5ft ILynk 30 PIN to 3RCA Audio/Video + USB A Type Cable, Easily connect your iPod, iPhone or iPad to the composite video inputs on a TV or stereo system: Computers & Accessories[/ame]
Old 07-18-2013, 12:39 PM   #42
DarrenDriven
NW Region Moderator
That is in line with what I was told by Scion.
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
FS: Pioneer Premium Upgraded Head Unit (Not-Bespoke, Canadian option) pheoxs Audio/Visual, Electronics, Infotainment, NAV 1 03-22-2013 05:47 AM
I suppose this is an option....for someone. Pscylo Cosmetic Modification (Interior/Exterior/Lighting) 11 06-21-2012 11:34 PM
