Old 07-16-2013, 12:36 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
"click" sound only when throttle is engaged, and dis-engaged AT
After an Auto-X event, I noticed a "click" sound only when I take off in first (M mode) and when I take my foot off the pedal, another "click" sound. It seems like it is coming from the rear diff area, not from engine bay. Anyone here have similar issues? When I am free revving my engine in neutral, no click sound what so ever, so seems like it needs to be engaged in gear. Only on take off's, and a very slow take off, I don't hear the "click" sound.
Throttle on - "click" and it stops, even after I shift up, only at take off it makes the noise.
Throttle of - "click", once more, then no noise, even after going to a stop.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-16-2013, 12:40 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Throttle body maybe?
Old 07-16-2013, 03:28 PM   #3
BRZPDX
Boosted Member
BRZPDX's Avatar
I though about this too, but if it is the throttle body, it will "click" if I free rev the engine, but only when the car is in motion, which leads me to think it is coming from the tranny or the rear diff. I don't feel any difference other than the odd noise.
Only recent changes were changing my ATF to RedLine high temp fluid, and my diff oil was changed out like 2 months ago to Motul high temp fluid. And ofcourse a hard day at Auto-X.
Old 07-16-2013, 05:39 PM   #4
FRSBRZGT86FAN
Smile
I think it would be best to take it to the dealer under warranty they won't deny you for Auto-X as long as you don't have any aftermarket mods that affect the drive-line (fluids won't void it). Best of luck, I think you should head to the dealer.
Old 07-18-2013, 04:50 PM   #5
vgi
Drives: frs
could it be rear diff when you just apply gas
vgi is offline   Reply With Quote
Old 07-20-2013, 08:24 PM   #6
BRZPDX
Boosted Member
BRZPDX's Avatar
FIXED:
The noise was coming from the driver side (left) rear axle, and the axle bolt was slightly loose. Tightened it down a quarter of a circle, and voala, no more "click" sound when moving from a stop, and coming from a stop.
The tech is not sure what exactly was causing the noise, but maybe from axle bearing as well since auto-x is hard on them (more so than track I guess).
Old 07-20-2013, 10:02 PM   #7
Carwhisperer
Drives: A lot of supercars.
FIXED:
[ame="http://www.youtube.com/watch?v=OCyJ5-10QyE"]VID 20130616 175852 - YouTube[/ame] that the clicking noise you are reffering to? starts to make the noise at 0:13
This sound comes from the front right finder area.
Carwhisperer is offline   Reply With Quote
Old 07-23-2013, 03:14 PM   #8
BRZPDX
Boosted Member
BRZPDX's Avatar
OMG the same sound!! You need to tighten the axle nut, from the axle that is making the noise. That solved the issue for me for now.
Old 07-24-2013, 11:25 AM   #9
SkullWorks
Drives: SSM LT MT BRZ
I will be checking my left rear axle nut...I have similar noise on accel or decel
Old 07-24-2013, 06:00 PM   #10
Carwhisperer
Thanks, i'll check my front right one. That's where the sound is coming from.
Old 07-24-2013, 07:06 PM   #11
BRZPDX
Boosted Member
BRZPDX's Avatar
have you guys both been auto-Xing, drifting or drive hard a lot? Just curious since this noise started right after a Auto-X sesh for me.
Old 07-24-2013, 10:03 PM   #12
Carwhisperer
+1 for drifting/driving "hard"..
Old 08-06-2013, 07:12 PM   #13
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
FIXED:
I just started to get this last week. Been trying to figure out where the hell it came from. Do you have a picture of what was loose?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-06-2013, 07:13 PM   #14
feldy
feldy's Avatar
Same fucking sound lol glad I found this thread. what axle nut is there I have not been under the back that much to look at the axles. Is it where it goes into the diff or the hubs?
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
soft "clack" sound at 40km/h typericey Scion FR-S / Toyota 86 GT86 General Forum 1 07-06-2013 05:11 PM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
"blipping" the throttle takes more that a blip?! KSC BRZ First-Gen (2012+) — General Topics 49 02-27-2013 07:04 AM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
