Old 07-15-2013, 03:26 PM   #57
xwd
Originally Posted by Shit Luck View Post
that is because unlike ecutek they are actually selling a product... ecutek provides you nothing, the tuner does.
Well Ecutek is selling you the more advanced features they support with just reflashing. The ability to switch between four maps with the cruise, 2-step limiters, flat shifting, flexfuel support, the ability to do speed-density, custom logic, boost control via re-using the evap solenoid, etc. Those aren't things you find in the standard maps...
The Ecutek software provides fairly robust logging capability as well which you getting with the price of the license. I paid a decent price for the DeltaDash software back in the day because it was better than anything else out there. Of course you could buy this and then also buy a copy of BRZEdit personal and get the same thing.
To say Ecutek isn't doing anything would be incorrect, imho but I am looking forward to this product. Shiv is definitely a blast from the past, I still had one of his WRX uppipes until a few months ago!
Old 07-15-2013, 03:40 PM   #58
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
My problem is I don't have e85 a turbo or desire to flat foot shift or use launch control.
I want to log and flash my car. Features like deleting a cel or tpms would be nice.
This to me is not worth nearly a grand.
How tuners protect themsleves is easy. A base map is free. Revisions and custom maping is what you charge for. Less for na or just a stg1 and so forth
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-15-2013, 03:57 PM   #59
jamesm
I'm putting together a site that'll let us share/fork/modify/diff tunes. Also has pretty nice intelligent matching, so you can search by installed modifications and get a ranked result of tunes. It's pretty cool stuff, and I plan to use all the tunes and mod lists to do some cool machine learning experiments. Should be up soon.
Old 07-15-2013, 04:02 PM   #60
leon78
leon78's Avatar
Drives: 13 Whiteout
+++1^
Subbed!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 07-15-2013, 04:05 PM   #61
Rombinhood@OpenFlash
Drives: FRS
Rombinhood@OpenFlash is offline   Reply With Quote
Old 07-15-2013, 04:06 PM   #62
joop1987
Drives: 2013 FRS, Raven, Auto
Originally Posted by ATL BRZ View Post
Okay so I'm getting a better idea of how tunes are created and shared on this platform.
Will there be some kind of shared repository created eventually for everyone to share their tunes and collaborate to make edits on them?
Most Subaru forums are against trading open source tunes. I'm sure this one will be the same.
joop1987 is offline   Reply With Quote
Old 07-15-2013, 04:07 PM   #63
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Will this platform allow editing of the stock transient ignition retard tables?
Would be nice if this platform offered the same DI seal protection from transient detonation between quick high rpm WOT upshifts as EcuTek currently has available. As far as I know it's simply filling in the table above 5400rpms which is empty in the stock tune.
Old 07-15-2013, 04:11 PM   #64
jamesm
The defs are open, so you can find and define any tables you like (much like the pro version of brzedit)
Old 07-15-2013, 04:19 PM   #65
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
It's easy enough to set one up elsewhere.
Old 07-15-2013, 04:36 PM   #66
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Very interesting. Are there tools for injector and MAF scaling?
Old 07-15-2013, 04:41 PM   #67
jamesm
so you mean the folks that get their paychecks from vendors are against promoting a free alternative to their advertisers' services? stop the presses!
seriously though there's absolutely nothing at all wrong with sharing base configurations and then tweaking to suit as necessary. hell some people would be better off with a base map than some of the etuning that goes on around here. just recently a guy gained a ton of power (and lost a bunch of knock) by going from visconti's etuned (16 or so revisions) map to FA20Club's first-flash basemap (before revisions), then proceeded to gain a ton more with tweaks. i'd happily flash a well documented and reviewed map from a fellow enthusiast. it's no less of a crapshoot than paying for the same.
Old 07-15-2013, 04:43 PM   #68
jamesm
it uses tunerpro so you can get a look at the software ahead of time.
Old 07-15-2013, 04:46 PM   #69
Drives: FRS
All the transient ignition retard tables are already defined. Same with the MAF scaling, injection scaling table, min injector on-time, voltage compensations, etc,.
You will also have launch control and FFS. Right out of the gate
Old 07-15-2013, 04:48 PM   #70
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
That has not been confirmed as the problem. In fact, I highly doubt that it is. Pinging on "transient throttle", would not pose the same peak cylinder pressure as the motor would see at peak torque typically.Plus the table is not populated at low rpm and high load anyway, so it's not just the higher rpm regions.
And if a few degrees of timing over advance is the root cause, then high octane fuel should easily have prevented this, and yet we have seen the failure on cars running 100 octane fuel.
And just cause a knock sensors/processor "thinks" it sees knock, doesn't always mean it is knock. Lots of noisy shit occurs on a shift.
More R&D needs to happen before we can say "problem solved".
But anyway, I'm sure they will find all the tables they need.
To other posters:
As for the customs crap that no one really needs.... lol. It's mostly sales gimmicks that come and go, They had auto blip... got rid of it. had AF display, got rid of it, had SD support, coudln't get it right. Flat foot shift? Really? What's wrong with your rev limiter if you shift that slow?
This product is exciting, lets hope it delivers, great option to add to the FRS line-up, and any decent BRZ/Subaru tuner will be happy to tune it for you real time on the dyno. Shops charge $100 to $150 an hour, so for the price of a mail order tune, you are WELL on your way to a dyno tune.
Toma is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
