Old 07-15-2013, 03:18 AM   #29
Fast_Freddy
Drives: Passat
Originally Posted by Drift-Office View Post
I'm curious - why is that hard to believe? And UELs are supposed to make more rumble AND power? The prototype T1R setup is an EL too, and that was 198WHP...
I can only tell you what both cars in the same environment did with the same calibration...
Cheers!
Bob @ Drift-Office, LLC
The numbers don't add up, but they never do with the 86 triplets. I keep reading the following BS:
Header = +10whp
header-back = +15whp
ECUTek Tune = +15whp
Intake = +10whp
But in reality all those mods typically equal +30whp and you're telling me that a 4-2-1 HKS EL is worth +20whp by itself? That's my issue with these numbers. No offense meant.
Fast_Freddy is offline   Reply With Quote
Old 07-15-2013, 03:25 AM   #30
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
None taken, I'm not the guy who built it. I only work the calibration to get the best gains I can get and those are the results of our work! Have you seen our 100% stock calibrations? I get 18+WHP with no mods other than our Stage 1 NA tune...
Cheers!
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
stevo_12v (07-15-2013)
Old 07-15-2013, 03:37 AM   #31
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Cheers!
hmmm serious? I was having my doubt's about this tune from a local garage here. +20hp gain from just a tune..
FB Linky here: https://www.facebook.com/photo.php?fbid=631369983541497
stevo_12v is offline   Reply With Quote
Old 07-15-2013, 03:40 AM   #32
Drift-Office
If I'm able to quantify 18WHP on 92 octane, I don't see why 20 isn't possible on a higher octane that you guys generally use right? I will note that his baseline is about 10 WHP higher though, so even @ 180, that's not an uncommon number now, on any dyno.
My 2 cents!
Old 07-15-2013, 03:41 AM   #33
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Header = +10whp
Intake = +10whp
I think many parts manufacturers and companies like to tack on +hp numbers with their products, but I think the most important thing here is the tuning/calibration. What I get from this thread is that the +hp ceiling is definitely higher for the EL HKS header than the UEL Borla header. The tune is the key to a lot of the power gained, but a good and well designed product allows for a higher potential of power to be achieved.
The Following User Says Thank You to m.box.design For This Useful Post:
Drift-Office (07-15-2013)
Old 07-15-2013, 03:44 AM   #34
Fast_Freddy
Drives: Passat
Cheers!
I see. Those are very impressive results but I won't waste any more of your time because I wouldn't use a tuner so far away that I couldn't easily drive to his shop to sort out any potential issues.
Perhaps you could indulge me a tuning question if you're feeling generous. How much higher is the max EGT for your tune vs oem after leaning out the 6500-7400rpm range? I can't quite understand why Toyobaru would dump so much fuel there if not to keep EGT in check for long term engine health. TIA.
Old 07-15-2013, 03:53 AM   #35
Drift-Office
Understood - for the most part, you have Tony @FA20Club for your needs in the East Coast. I'm sure he's more than capable of taking care of your needs remotely if need be. This isn't a waste of my time - I choose to be here to answer questions and help out - no one's pointing a gun to my head.
I'll have to refer to the logs on that one, but Subaru has always been a proponent of keeping everything rich, force inducted or not simply because they have to offer a x year x mile warranty. With the FA20 being a high compression motor, I'm sure their tuning strategy isn't any different for that same reason.
My 2 cents on that last...
Fast_Freddy (07-16-2013)
Old 07-15-2013, 06:00 PM   #36
BryanGT
Drives: WRD BRZ Limited
Hey Bob, what's your R&R rate on a set of headers? I was thinking of getting a tune from you, but I think I would also probably want headers right away and it would be nice to have a stock dyno and then headers and tune.
BryanGT is offline   Reply With Quote
Old 07-15-2013, 06:16 PM   #37
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
From the pictures I've seen of the borla headers I wouldn't be surprised if a port and polish with a cat delete netted more power.... They are simply hideous and poorly welded. I wouldn't pay $200 for the borla headers.
Also HP from bolt ons don't stack much if at all. Especially the header back stuff and intake stuff. Most intakes from what the tuners say make little to no power after you tune them vs stock.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-15-2013, 07:37 PM   #38
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
So does this mean with stock intake, it will produce more power?
shu5892001 is offline   Reply With Quote
Old 07-15-2013, 08:48 PM   #39
Drift-Office
I'm willing to be less disruption in flow would mean better results generally.
Cheers!
shu5892001 (07-15-2013)
Old 07-16-2013, 12:56 AM   #40
Fast_Freddy
Drives: Passat
I would agree that the indication here is that the HKS EL with Perrin OP, Motive front, Perrin cat-back, aFe intake and Drift-Office tune does produce more power than a Borla UEL with unknown cat-less exhaust and intake with a Drift-Office tune.
I forgot his name but there's another guy here with a Borla UEL, header-back exhaust and a different tune making 200.5whp on pump gas. This is why I dislike comparing dyno results but that's usually all we have to go by.
Thank you very much. It's been a pleasure talking to you.
Old 07-16-2013, 01:10 AM   #41
StormTrooper
Just search and you'll see what I mean.... If you want less expensive options look at Revworks. Or maybe nameless when they come out.
GR86 MT premium
Old 07-16-2013, 01:50 AM   #42
Fast_Freddy
Drives: Passat
I've seen exactly what you're talking about but still don't agree with your incredibly harsh assessment of the Borla header. It's definitely not as pretty as headers costing twice as much but you might be surprised at just how little hp is gained from a pretty collector vs an ugly one like Borla's. Also, welds don't have to be pretty to be strong. What do you think of this downpipe? A buddy and I fabbed and MIG welded it using a mixture of 304 and 409 pipe with a nickel plated mild steel flange!
It may look like shit but it made great power and held up for 5 years and 50k miles without a problem. I'm sure it's still fine but I sold the car. HKS and JDL are grossly over-priced IMO, Nameless is a pipe-dream and RevWorks has a crappy 1 year warranty and a forum member has already sent his back because it cracked within months. Agency Power is Chinese eBay crap and I won't run a "turbo header" since I know I'll never be adding a turbo so that rules out FA20Club and P&L. There is that new "Hotpipes" header from the Phillipines but they're asking almost $500 for a true $200 header with a 1 year "good-luck using-it" warranty.
I wish I had better options but the Borla looks pretty good for $550 ($435 in my case).
Drift-Office : Borla UEL Header... TUNED. Drift-Office Engine, Exhaust, Transmission 41 10-26-2013 12:54 PM
Drift-Office N/A tune zuldajin Engine, Exhaust, Transmission 14 07-09-2013 09:38 PM
Got my stock BRZ tuned at Drift Office over the weekend... edocura Engine, Exhaust, Transmission 46 05-23-2013 09:05 AM
Drift-Office : EcuTek Calibrations Drift-Office Engine, Exhaust, Bolt-Ons 24 05-21-2013 05:33 AM
Got my EcuTek reflash from Drift Office truenosan CANADA 7 01-29-2013 05:30 PM
