Old 07-12-2013, 10:13 AM   #29
sierra
Drives: Skoda Yeti DSG diesel 4x4
Perhaps back off where they fine tuned it, to a safe level, to allow for differences but still have a decent base map for the set up?
sierra is offline   Reply With Quote
Old 07-12-2013, 10:30 AM   #30
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
As far as I understand it, most tuners are leaving in that "safety margin" out of the gate. Some tunes remove the margin by making the advance multiplier 1, but the stock tune, Visconti's tune, etc leave the multi at 0.7. This means right after reflash, it's only utilizing 70% of the timing advance table. As high load events occur without detonation, it feeds in more advance over time. This is why the stock tune feels so "sloppy" after a reset, soft pedal, etc.
I could be totally wrong, so feel free to correct me here pro's... but if i'm understanding the multiplier right, that safety net should cover discrepancies in vehicle, local octane, etc.
Nightbringer is offline   Reply With Quote
The Following User Says Thank You to Nightbringer For This Useful Post:
sierra (07-12-2013)
Old 07-12-2013, 01:27 PM   #31
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by xjohnx View Post
The TRD intake comes with a new MAF?
MAF location isn't in the same stock position anymore...
Drift-Office is offline   Reply With Quote
Old 07-12-2013, 02:09 PM   #32
Slash
Slash's Avatar
Drives: 2013 FRS
I'm sure they'd prefer to back off timing a bit before they sent it over. Only other variable would be the Maf calibration for your local area(providing you're using the same exact intake in the first place).
Sent from my SGH-T999 using Tapatalk 2
Slash is offline   Reply With Quote
Old 07-12-2013, 05:12 PM   #33
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Originally Posted by wrxgoose View Post
Have you seen my build thread/dyno sheets?
still, that plot looks pretty nice. Especially since you're using 92 octane.
I just read it, it's impressive ! Too bad we are not running on the same dyno orelse we will have a pretty good comparison.
Bob at Drift office showed me quite of different setups which he dynoed so I think figures will be much realistic for comparison on the same dyno
AJ PwR is offline   Reply With Quote
Old 07-12-2013, 05:22 PM   #34
Deathreaper
Drives: 2013 Scion FRS
Originally Posted by Drift-Office View Post
All sorts of turbulence encountered and it was a BIATCH to tune out.
Bob @ Drift-Office, LLC
Do you think using a straight silicon intake tube as opposed to the wavy one would solve that issue? I assume it wouldn't as it is located after the MAF.
Deathreaper is offline   Reply With Quote
Old 07-12-2013, 05:30 PM   #35
wrxgoose
WUB WUB
Drives: 2013 Firestorm
wish there was a better way to make even comparisons on different dynos.
wrxgoose is offline   Reply With Quote
Old 07-12-2013, 05:40 PM   #36
buditjoenawan
Drives: Very very slowly
That's a great looking curve after the dip. Nice and smooth, just like all damned torque curves should be. Watch out for the jaggies!
budi
buditjoenawan is offline   Reply With Quote
Old 07-12-2013, 06:24 PM   #37
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by Nezz View Post
I wish I could use it! I have to retain cat, sadly. Been eyeballing pretty much any option that lets me keep the front one, even if the back one's going to end up in the bin.
HKS has headers with a cat option
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-12-2013, 07:32 PM   #38
AJ PwR
AJ PwR's Avatar
If there's enough interests, we can build a CATTED Front pipe
Old 07-14-2013, 10:22 AM   #39
Manilla
Drives: BRZ (Satin White Pearl)
So for warranty purposes, after a tune, is there anyway to switch the car back to normal when taking it to the dealership to make it seem as if no modifications were made?
Manilla is offline   Reply With Quote
Old 07-14-2013, 10:36 AM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
Yes, just reflash the stock rom. If the dealer REALLY wanted to check for a reflash, they would have to send the ECU back to Toyota or possibly even Denso to prove it. I have never seen them actually do this though.
Old 07-14-2013, 10:41 AM   #41
Mikem53
Drives: FR-S 6MT
Some ECUs retain an update count.. Just for guys like you..
Mikem53 is offline   Reply With Quote
Old 07-14-2013, 10:48 AM   #42
xjohnx
Grip>Slip
xjohnx's Avatar
Not sure if ECUtek pulls its flash counter from the same location, but I had a flash fail once and after re-installing the ecutek license on the ECU my flashcounter referenced in ProECU was reset as well.
Have you hit 200whp NA? empower-auto Engine, Exhaust, Transmission 323 11-26-2015 07:49 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Cheap Dyno? Sponsored Dyno? swift996 Mid-Atlantic 3 02-09-2013 12:29 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
