Old 07-13-2013, 07:37 PM   #1
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
Door speakers not working after new head unit install
Searched the archives with no results. I just installed an Alpine INE-S920HD using a Metra 70-1761. Everything is functioning except I have no sound to either door speaker.
Looks like these may be run of the amp in the rear according to wiring diagrams. Has anyone experiernced this? Solutions?
Not a huge issue as I will be replacing everything soon, but it's frustrating at the moment.
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01
18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit
H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune
Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits
lsr78 is offline   Reply With Quote
Old 07-13-2013, 07:46 PM   #2
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Check the fuse. Its the 15 amp fuse all by itself in a corner (i think its the one nearest to the pedals/engine..but it is definitely all by itself in a corner). It isnt really labled, but I found through trial and error that it is the fuse that goes to the door speakers.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 07-13-2013, 11:11 PM   #3
M_Dubbs
Drives: My lil bro has a white BRZ limited
Blue/white from the Alpine to the blue or blue/white on the 1761? If it's amped, the door speakers are the only things running off of the amp. The dash tweets and rears run off the deck...
M_Dubbs is offline   Reply With Quote
Old 07-14-2013, 12:56 PM   #4
lsr78
This was the issue. The Metra kit labels the blue wire as the power antenna lead and blue/white as remote turn on. However there is not a blue/white just a blue. Swapped the blue from power antenna to remote and it works now.
Enkei PF01
Old 07-16-2013, 01:28 AM   #5
bodayguy
Drives: 2016 MX-5 Club
Wow, thanks! I had this exact same issue. That was a 5-minute fix! Door speakers work now.
Now, I still am not getting AM radio reception. I thought that was what the blue wire was powering, but no, that still doesn't work. Hmmm ...
bodayguy is offline   Reply With Quote
Old 07-31-2013, 12:17 AM   #6
M_Dubbs
Sometimes the antenna adaptor doesn't insert all the way in. Sometimes the tiny pin gets bent.
One bummer is a lot of aftermarket radios do not get AM reception nearly as well as factory radios. To get none makes me think there is another issue. I assume you were getting reception before...
Old 02-17-2014, 02:28 PM   #7
cooldandani
Drives:
Hey guys I'm having the same issue here I'm using the scoche wiring harness and can't find remote turn on wire any help please??
Sent from my SGH-T889 using Tapatalk
cooldandani is offline   Reply With Quote
Old 11-09-2019, 12:56 PM   #8
zeppy
Drives: subaru brz-limited
Cod you elaborate on this. I just installed pioneer head unit and my door speakers stopped working, switch the stock headunit in and they work. I dont understand which wires you switched to make it work
zeppy is offline   Reply With Quote
Old 11-09-2019, 01:09 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
connect all the blues in the harnesses together. it's the amp turn-on signal
Old 11-09-2019, 01:42 PM   #10
zeppy
I'm sorry I'm still lost. On the pioneer harness I have a blue/white and then a soiled blue looping into it again?
Old 11-09-2019, 01:49 PM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Clean it.. I think it being 'soiled' can lead to issues as you can't get a clean connection...
Old 11-09-2019, 03:28 PM   #12
soundman98
soundman98's Avatar
and what do you have on the metra harness?
Old 08-01-2020, 11:46 PM   #13
Hrod530
Drives: 2015 BRZ
I just installed a Pioneer head unit in my BRZ. I also had the same problem of the door speakers not working. I tried to connect the white/blue (remote) wire from the stereo harness to the blue (power antena) wire on the metra harness as advised to do so for the comments above. Although I do get some sound coming out now, the volume is no where near the volume coming from dash and back speakers. Anybody know why that is?
Hrod530 is offline   Reply With Quote
Old 08-05-2020, 12:50 AM   #14
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
It's most likely due to the fact that the factory amplifier in the trunk is being fed by the front speaker level inputs of your new Pioneer head unit. Unfortunately there is no way to level match the amp to the input because the factory amp has a fixed gain.
The factory head unit is matched to the factory amplifier, while your new Pioneer deck is not.
FR-S2GT86 is offline   Reply With Quote
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 23 04-03-2022 07:03 PM
MD: BRZ Head Unit + Speakers itsfun Audio/Visual, Electronics, Infotainment, NAV 2 04-06-2013 09:03 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 03:01 PM
