#43 | |
Thupercharged
When you start to make assumptions, you set yourself up for a bad time. This is not a widely purchased consumer device like a TV. This is a very niche market item. Its unreasonable to compare the two. The "American Way" means that if you don't like it, don't buy it and instead research alternatives. Do you know how many people realize that Vortech does not warranty a compressor if you start it below 25F ambient temperature? Not a lot, because they didn't care to read/ask about the specific warranty information before buying.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#44 | |
Drives: '13 DGM BRZ Limited
You're right. We are in North America. . .where every year people get lazier and lazier and expect others to bear the responsibility for their decisions when things don't work out the way they expected. It's one thing if something was hidden from you prior to purchase, but it's not. All it takes is a few minutes of research. If you can't even do that before you decide to drop your cash on something, then the only one to blame is yourself. |
#45 | |
#46 |
What I think you are confusing is the difference between tangible and intangible products. Software, by it's nature, is intangible. You cannot hold software. You cannot see software. It's simply electronic imprints. Businesses need a reasonable way to protect the investment put into their products. When dealing with tangible products, like the Cobb Accessport, they factor in the cost or production of the unit and the initial up front cost of developing the software, then sell the product as a one off. Cobb makes their profit of the initial sale of the device.
With software, especially software like EcuTek, where this is no tangible object associated with the product, companies will "license" the software. When you purchase a product like this, the company is granting you permission to use their work product. EcuTek is still the owner of the software, so you, as the licensee, have no right of first sale. The Windows analogy another person mentioned here is the same. When you purchase a copy of Windows, you purchase a license to use that software on one PC. Sure, you can sell the physical CD the product came on, but in order for that person to install and use it, you must "deactivate" your installation or Microsoft will force that user to buy a new license. As it stands right now, this is the standard business model for software companies. |
| The Following User Says Thank You to davisk6 For This Useful Post: | Nightbringer (07-12-2013) |
#47 | |
Thupercharged
They were the first names in the game, and they charge what they charge because they have the freedom to do that. When a different company comes along and does it for cheaper with a difference licensing scheme, then go with them. Now THAT is the "American Way"
2013 FRS
| The Following User Says Thank You to DJCarbine For This Useful Post: | Nightbringer (07-12-2013) |
#48 | |
And for a while they didn't have end-user cables..which sucked for everyone. If someone wants features, they get Cobb.. if someone wants to be cheap - they go open source. That being said I sell several WRX/STI licenses without any problems... Tuned a 2013 WRX last night.. guy didn't want the expensive of Cobb but wanted Launch Control, Flat Foot Shifting. If he went open source you have to pay someone to patch the rom for those features.. by the time you done paying for everything you might has well gone with EcuTek that has A LOT more features than just Launch Control and Flat Foot shifting... that and the fact you have to search for the patches. it's not worth MY time to do that. It's certainly not for everyone.. but will once again become a another great option for the WRX/STI.. why? because EcuTek is currently in the process of updating most of their Subaru stuff. I'm looking forward to installing a flex fuel kit on my 05 STi.. Finally I can just pump and go John |
#49 |
In this case, other products came out that were simply better. It's quite possible that EcuTek's business model hurt them in that market, but I think Cobb and the Open Source options simply had more to offer at a better price.
#50 | |
Thupercharged
2013 FRS
#51 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
So when something does not adhere to the status quo, the onus is on them and not the consumer. Alright. Points been made over and over. |
#52 | |
Both companies must be doing something right to be this successful, right? Personally, I prefer the Cobb model. On a side note, Hondata uses the Cobb model, but the number of ECU marriages is limited. After so many "transfers", the unit bricks and can only be locked by Hondata. Not sure if Cobb does this. I also believe that it's up to you, as the tuner, to educate your clientele on why they should not be sharing their tunes. We both know how even the smallest deviation in a tune can have devastating effects. |
#53 | |
I personally like the Cobb model as well.. makes customers happy.. EcuTek model right now is older, and honestly they thought about changing it.. but the way the software is setup with the dongle and license doesn't allow this to easily happen with A LOT of new work. Everything they have is integrated with everything.. databases - everything is streamlined a certain way.. They rather work on more pressing things like on-going dev work on cars... and idk maybe a handheld programmer which wouldn't have this issue to begin with. But as a business owner, I think EcuTek's model allows them to generate more money , which powers their development team. I've worked with several company's and EcuTek is absolutely the ONLY company that listens to a request and then acts on it. Two weeks ago I told EcuTek their SD sucked.. btw, not for the first time.. Told them I wanted them to implement the the same stuff we have on the GTR now.. and that I needed it for a upcomign trip that coudn't be delayed. So Monday comes around and what's happening.. GT86 on the dyno testing out the new VE Based SD... Friday rolls around.. guess what's in my inbox. No matter if your a tuner, mechanic, top chief - we all have tools and we all have preferences. I continue to support platforms EcuTek can support because IMO they have some really awesome tools. And very much like BRZ, EcuTek will be first to market with Subaru DIT... why? because they've been working on it for over a year now and it's ready TO-GO. John |
| The Following User Says Thank You to Visconti For This Useful Post: | King Tut (07-15-2013) |
#54 |
I'm not trying to justify anyone's business model. You're missing the point. My point is that if you buy something without fully understanding what you're getting and whether or not that fits into your plans or not, then it's your fault/responsibility. There are other choices out there for the twins besides Ecutek. It's up to the consumer to do the research and base their decision on what fits their needs and plans.
#55 | |
That certain expectation for consumer protection does not include what you are trying to depict. That expectation is that the product will be safe for use for it's intended purpose and that the product will do what it states it will do. Status quo does not alleviate your responsibility as a consumer and as an adult to know what you're purchasing. Or is what you're saying that since everyone in town buys drugs from person X that it's OK for you to do the same because if the cops arrest you, it's not your fault and the onus was on the drug dealer to tell you it was illegal? |
| The Following 3 Users Say Thank You to cnk For This Useful Post: |
#56 | |
Drives: Scion FR-S
As another poster stated, comparing this to a TV is missing the fundamental concept entirely. Tangible vs intangible. Like trying to resell, if you have to leave halfway through a concert, you don't get your money back. It's on you if you decide to leave. You paid for a service. As you state, this is America. If their model was unacceptable, consumers and tuners wouldn't be buying in. The market has spoken. In ten years will there be a more affordable option? Almost always. If I have a $1000 IROC I'm not going to pay $1500 for a tune. If the market demand for what EcuTEK offers wasn't present, they wouldn't still be in business, much less expanding. We all have our preferences here. I'm just pleased that we HAVE options from multiple sources dedicated to providing the best service they can for this community. |
| Ecutek's 86 | jpit | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 07-12-2013 12:35 PM |
| Will the new Subaru WRX kill resale value of the 3rd gen WRX's? | CSI:86 | Other Vehicles & General Automotive Discussions | 20 | 06-05-2013 09:31 PM |
| resale value kbb available | Celica00 | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 05-24-2013 12:03 PM |
| resale value | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 10-08-2012 09:58 PM |
| ECUTEK????? | 20valvewynn83 | Engine, Exhaust, Transmission | 4 | 10-03-2012 09:34 PM |
