Old 06-22-2013, 11:38 PM   #351
Lytheum
Drives: 2013 BRZ Premium 6MT
Originally Posted by Sensisnow View Post
Do you have a tune, or are you running a stock ECU?
Unichip and fa20club cai
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 06-23-2013, 12:43 AM   #352
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by Lytheum View Post
Just started trying this app. My Afr drops to 11.63 at wot and stays there. Also my idle is reading 14.05...shouldn't it be 14.7? Not sure what's going on
The idle should be around 14.7. Also I believe the limit of the factory o2 sensor is approximately 12.15 on the rich side so it appears something is up with your setup.
Maybe unichip is messing with the torque readings?
vtmike is offline   Reply With Quote
Old 06-23-2013, 06:49 AM   #353
Lytheum
Maybe I'll try unplugging it and see what it is reading
The Following User Says Thank You to Lytheum For This Useful Post:
ML (06-23-2013)
Old 06-24-2013, 12:12 PM   #354
Lytheum
ok.....took a few minutes and unhooked the unichip and my idle afr is still showing 14.05 command and actual is floating right around there. unhooked the battery to reset the ecu. think im getting a bad reading or is something else off somewhere?
Old 06-24-2013, 01:32 PM   #355
Lytheum
figured it out! selected e10 as my fuel since thats what we have here. torque then adjusts the reading since i guess stoich for e10 is 14.0-14.1. changed back to petrol and it shows 14.67 command now and actual hovering around there!
Old 06-24-2013, 09:29 PM   #356
Lytheum
Originally Posted by markitect View Post
With the DI seal failures being reported, and a track day coming up in a few weeks I downloaded the knock detector. A good pull in third picked up 11 out of 27 "possible detonations" occuring between 46 and 76 mph. It says the correlation is -.5(whatever that means).
Either My car is going to fail massively any time now, or these are false positives.
It would be nice to find out the knock correction PID, but it won't be easy to monitor for.
Anyone else try the knock plug in? I know the dash hawk had a pid for knock retard that worked on my mazdaspeed 3
Old 06-24-2013, 09:35 PM   #357
DriftEm
DriftEm's Avatar
Yeah, with stock tune and 91oct here in socal, I also get 3-5 possible detonations out of 40 sampling.
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
WillRacer1jz (06-25-2013)
Old 07-11-2013, 05:00 PM   #358
Hanakuso
I just bought the mini adapter and a prepaid HTC One V at Walmart. Total for both came out to be $100 or so. I'll find out soon if this combo was worth it. I was thinking about going the Nexus 7 route but I don't want a huge theft magnet and it kinda looks silly IMO.
Regretting I have an iPhone..
Hanakuso is offline   Reply With Quote
Old 07-11-2013, 05:13 PM   #359
swift996
swift996's Avatar
Hmmm...not a bad idea
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-11-2013, 05:24 PM   #360
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Out of curiosity, does Torque require an internet connection to run? I have an old android phone that doesn't currently have a purpose (or carrier) at the moment....
Old 07-11-2013, 05:26 PM   #361
Yruyur
Yruyur's Avatar
No
Sent from a Motorola DynaTAC 8000X
The Following User Says Thank You to Yruyur For This Useful Post:
Draco-REX (07-11-2013)
Old 07-12-2013, 01:28 PM   #362
regal
Drives: Scion FR-S/Toyota Yaris
Are there any 7" tablets that can run torque and double duty as GPS without Wifi (ie a SD card map) ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-12-2013, 02:45 PM   #363
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
Yes, Nexus 7:
http://www.staples.com/Nexus-7-16GB-...product_949231
Use coupon code 20098 for another $30 off total is $149. Doesn't get better than that.
For GPS there a few offline Navigation softwares out there...
--yamsta
yamsta is offline   Reply With Quote
The Following User Says Thank You to yamsta For This Useful Post:
swift996 (07-12-2013)
Old 07-12-2013, 03:03 PM   #364
regal
Originally Posted by yamsta View Post
Yes, Nexus 7:
--yamsta
I don't think the Nexus runs ICS only Jelly Bean which is a problem connecting to the work email. What about the Samsung Galaxy 2 ?
Thanks
Mods:
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
