#113 | |
Drives: Ultramarine FR-S 6MT
More than I'm linking, but the one I'm linking is the beefy one I found with a quick search. I have zero idea what the RPM requirement is for the compressor though ![]() http://www.digikey.com/product-detai...002-ND/2466699 |
#114 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
#115 | |
Drives: '13 GBS Subaru BRZ
It's easy to find compressor maps online which will give you an idea of what sort of RPM you'll need for a given compressor. Keep in mind that we're only going to be shooting for the extreme low end of the map for any given compressor. Another issue will be mating the motor shaft to the compressor wheel so shaft diameter needs to be a consideration. I think TD05/06 wheels are 6.5mm shaft diameter.
#116 | |
Drives: FR-S 10 #103 AT
Another problem is the environment. You need a motor capable of working/surviving in the environment under the hood of a car. Temperature extremes, moisture, I question whether an R/C motor would be up to the task. Even if it has the power, they are used in pretty controlled conditions (you don't fly an expensive heli in the rain, do you?) so might not do well under a hood.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#117 | |
Although our engine bays are pretty good at keeping weather out it is still a concern. I probably won't be leaving this installed in the winter here in Minnesota. Another possibility is to go with sealed water cooled RC motors which would fix most or all of these problems. It does add complexity to the system though which I don't like.
#118 | ||
#119 | |
Kv: 3180rpm/v Diameter: 36mm Length: 60mm Shaft diameter: 5mm Max voltage: 18V Max current: 94A Idle current: 2.7A Weight: 280g Thats a max 57240 RPM! That would do very nicely.
| The Following User Says Thank You to neutron256 For This Useful Post: | cobrabyte (07-11-2013) |
#120 | |
Drives: Raven Fr-S
Isn't the slow charging during driving taken from the alternator and ultimately from the engine? I just meant for the alternator to have a high capacity to charge the battery much faster (only Lead acid battery though) and have juice left over to drive the SC when need be. Unless you have a braking regenerative system, there is no hybrid functionality, is there?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#121 |
Drives: Raven FRS
Here some BL motor with, I think with higher power. Price wise, it seem good.
http://goldenmotorcz.en.made-in-chin...catalog-1.html Looking more closely,max rpm might not be there. |
#122 | |
#123 | |
When I use the term hybrid I don't mean in the Prius sense. I'm talking in more general terms of storing energy up in the battery during a low demand time, and then using it to get an extra boost of power at a high demand time. No efficency gain, just changing how/when the power is used.
#124 |
How are you calculating the required power?
#125 |
Drives: Raven FRS
It a paper on what you want to do, atleast in the supercharger.
http://www.movingmagnet.com/medias/d.../m12-12-16.pdf |
#126 |
Drives: White FR-S
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 06:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 03:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
