Old 07-10-2013, 02:07 PM   #15
yohan04
yohan04's Avatar
Drives: Your sister
Originally Posted by Draco-REX View Post
This is pretty much exactly the size/wheel/offset I'm looking at upgrading to when the SC goes on..
Are coilovers required for clearance up front?
Coilovers are recommended if you want aggressive alignment and/or planning to run wheels and tires larger than 9.5 and 255 respectively. I was only able to gain -0.6 front camber until the tire was rubbing inside the strut perch (only had camber bolts).
Now with camber plates, I am able to dial in more aggressive alignment without rubbing....but it's still damn close -- about 1-2mm clearance.
edit: Forgot to mention, any offset lower than et35 **should** be fine, depending how much negative camber you dial in.
yohan04 is offline   Reply With Quote
Old 07-11-2013, 09:33 AM   #16
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by swift996 View Post
i HATED mesh wheels on this car, until i saw this.
Jive Turkey is offline   Reply With Quote
Old 07-11-2013, 10:29 AM   #17
p00mba
p00mba's Avatar
Drives: FR-S :)
i'm getting a new set of wheels, and i'm thinking of running 225/40/18 or maybe 235/40/18 front and 255/35/18 rear hopefully i dont rub like im rubbing with my 265s in the rear... just worried with the 235/40/18 i'll rub with my drop...
this is awsome i love some meaty tires
p00mba is offline   Reply With Quote
Old 07-11-2013, 10:32 AM   #18
Jive Turkey
the tuna, no crust.
what are you wheel specs? i'm at a 265 in the front and even with a pro-am driver behind the wheel of my car i didn't rub, but i'm also not slammed.
Old 07-11-2013, 10:48 AM   #19
p00mba
p00mba's Avatar
Drives: FR-S :)
The following wheels specs on the new wheels i purchased and waiting to arrive:
Front-18x9 +38
Rear-18x10 +38
Current wheels:
Front - 18x8.5 +34
Rear - 18x9.5 + 40
Front - 225/40/18
Rear - 265 /40 /18
I'm dropped about 2 inches, basically no wheel gap, but i rub ever so slightly in the rear, the plastic tab where the bumper and body meets, it only rubs on hard turns or bumps in the road...
Old 07-11-2013, 11:18 AM   #20
Jive Turkey
the tuna, no crust.
those tabs will rub REGARDLESS. you either let them rub themselves out or do what king tut and i did and dremel them out. in the front on the new setup you'll be okay with atleast a 245/40 or a 255/35 in the rear though you'll be a bit more aggressive than i am now, so you'll need like 2.5 degrees of camber unless you wanna run a stretched tire... should look good though!
also 265/40 is HUGE. go to a 265/35
Old 07-11-2013, 11:33 AM   #21
p00mba
p00mba's Avatar
Drives: FR-S :)
Thanks for the input, i highly appreciate it!
Sorry i am running 265/35 lol i mistyped here and in my build thread... thanks for catching that.
So you think if i run 245/40 Front and 255/35 rear i should clear no problem with my up and coming new setup?
I'm running about -2.6 rear camber at the moment, it's not rubbing as much right now so it doesnt bother my as much.
if i continue to let it rub will that ruin anything aside from that tab itself?
Old 07-11-2013, 11:50 AM   #22
PRORICAN
PRORICAN's Avatar
Enkei NT03+M 265/35-18 all around!
PRORICAN is offline   Reply With Quote
Old 07-11-2013, 12:15 PM   #23
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Love those. I just wish they cleared big brakes..
Old 07-11-2013, 01:23 PM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
You know... after having someone straighten out my brain on something brake-wise, I might just go for the NT03s...
Old 07-11-2013, 02:20 PM   #25
humanshield
Drives: bucket
love all these cars! so bad ass.
humanshield is offline   Reply With Quote
Old 07-11-2013, 04:03 PM   #26
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Do you have any high rez shots?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 07-11-2013, 04:40 PM   #27
PRORICAN
PRORICAN's Avatar
I do but unfurtunately my laptop shit to bed and I had them saved on there. I'm working on trying to fix it to at least get some of those files back, so if I do I'll let you know. Should've saved them on my external hard drive but didn't do it in time.
Old 07-11-2013, 04:47 PM   #28
mrk1
Drives: Sterling BRZ Ltd
FT86SpeedFactory's silver car has a killer meaty setup.
Im waiting for my stockers to wear out a bit more before replacing
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
