#15 | |
Drives: Your sister
Now with camber plates, I am able to dial in more aggressive alignment without rubbing....but it's still damn close -- about 1-2mm clearance. edit: Forgot to mention, any offset lower than et35 **should** be fine, depending how much negative camber you dial in. |
#16 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
| The Following User Says Thank You to Jive Turkey For This Useful Post: | swift996 (07-11-2013) |
#17 |
Drives: FR-S :)
i'm getting a new set of wheels, and i'm thinking of running 225/40/18 or maybe 235/40/18 front and 255/35/18 rear hopefully i dont rub like im rubbing with my 265s in the rear... just worried with the 235/40/18 i'll rub with my drop...
this is awsome i love some meaty tires
#18 |
the tuna, no crust.
what are you wheel specs? i'm at a 265 in the front and even with a pro-am driver behind the wheel of my car i didn't rub, but i'm also not slammed.
#19 |
Drives: FR-S :)
The following wheels specs on the new wheels i purchased and waiting to arrive:
Front-18x9 +38 Rear-18x10 +38 Current wheels: Front - 18x8.5 +34 Rear - 18x9.5 + 40 Front - 225/40/18 Rear - 265 /40 /18 I'm dropped about 2 inches, basically no wheel gap, but i rub ever so slightly in the rear, the plastic tab where the bumper and body meets, it only rubs on hard turns or bumps in the road...
#20 |
the tuna, no crust.
those tabs will rub REGARDLESS. you either let them rub themselves out or do what king tut and i did and dremel them out. in the front on the new setup you'll be okay with atleast a 245/40 or a 255/35 in the rear though you'll be a bit more aggressive than i am now, so you'll need like 2.5 degrees of camber unless you wanna run a stretched tire... should look good though!
also 265/40 is HUGE. go to a 265/35 |
#21 | |
Drives: FR-S :)
Sorry i am running 265/35 lol i mistyped here and in my build thread... thanks for catching that. So you think if i run 245/40 Front and 255/35 rear i should clear no problem with my up and coming new setup? I'm running about -2.6 rear camber at the moment, it's not rubbing as much right now so it doesnt bother my as much. if i continue to let it rub will that ruin anything aside from that tab itself?
#22 |
Enkei NT03+M 265/35-18 all around!
| The Following 41 Users Say Thank You to PRORICAN For This Useful Post: | 15limited (04-06-2017), 350zgoingFRS_lol (06-18-2014), adprokid (08-25-2013), armythug (07-13-2013), B L U E S L A T E (11-05-2013), Conundrum (12-06-2013), Creole (07-08-2014), Dadhawk (07-11-2013), Dalers08 (07-11-2013), Do Boy (08-12-2013), DocCola (04-24-2014), Egyptn (10-28-2013), GaN-MaN (10-22-2013), humanshield (07-11-2013), jbsali (05-06-2014), Jive Turkey (07-11-2013), John.Hong (07-12-2013), Kris86 (04-28-2019), Mr. (07-13-2013), Ndgreely (09-05-2013), nix (07-12-2013), No Brakes (07-11-2013), NWFRS (09-29-2014), p00mba (07-11-2013), raul (01-17-2014), Redlinedfrs86 (11-09-2013), rookie (08-10-2015), ShoGun (07-13-2013), Silver Ignition (05-03-2014), SkAsphalt (07-11-2013), spdfreak (07-11-2013), Superhatch (07-11-2013), tg_1981 (08-25-2013), TheWatchman (07-16-2013), TylerLieberman (07-12-2013), white_knight (07-12-2013), WRXGuy1 (04-22-2014), Wusaa (09-27-2013), YamahaR86 (12-02-2015), Zaku (03-31-2014), zc06_kisstherain (05-16-2017) |
#23 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
| The Following 8 Users Say Thank You to Draco-REX For This Useful Post: | adprokid (08-25-2013), B L U E S L A T E (11-05-2013), Creole (07-08-2014), ericvanderwoodsen (09-06-2013), John.Hong (07-12-2013), PRORICAN (07-11-2013), SkAsphalt (07-11-2013), Superhatch (07-11-2013) |
#24 |
Corner Junkie
You know... after having someone straighten out my brain on something brake-wise, I might just go for the NT03s...
#25 |
Drives: bucket
love all these cars! so bad ass.
| The Following User Says Thank You to humanshield For This Useful Post: | nix (07-12-2013) |
#26 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Do you have any high rez shots?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#27 |
I do but unfurtunately my laptop shit to bed and I had them saved on there. I'm working on trying to fix it to at least get some of those files back, so if I do I'll let you know. Should've saved them on my external hard drive but didn't do it in time.
| The Following User Says Thank You to PRORICAN For This Useful Post: | Superhatch (07-11-2013) |
#28 |
Drives: Sterling BRZ Ltd
FT86SpeedFactory's silver car has a killer meaty setup.
Im waiting for my stockers to wear out a bit more before replacing
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 06:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
