Old 07-10-2013, 10:51 PM   #1
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Stage 7 Complete!
Just thought I'd jump on the badwagon and let everyone know I just installed my shift knob and now my Stage 7 mods are complete.
Figure I'll get to FI around Stage 26.
Anyone else?
Chewie4299 is offline   Reply With Quote
The Following 7 Users Say Thank You to Chewie4299 For This Useful Post:
Calum (07-11-2013), Grip Ronin (07-12-2013), ngabdala (07-12-2013), ramiram1984 (07-11-2013), SkAsphalt (07-11-2013), Sportsguy83 (07-11-2013), wparsons (07-11-2013)
Old 07-10-2013, 10:57 PM   #2
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Haha I dislike when people use "stages" to describe the mods they've done to their cars as well.
Intake = stage 1? Intake + cat-back exhaust = stage 2? What if it's an axle-back? Stage 1.5?
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following 2 Users Say Thank You to SportInjected For This Useful Post:
clayrush (07-11-2013), Sportsguy83 (07-11-2013)
Old 07-10-2013, 11:01 PM   #3
CBR600RR
Drives: Raven Black
Ba dum dum tssss��
Old 07-10-2013, 11:09 PM   #4
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Since when do mods go in order?
If at any common sense is post to be used in modding, if your going to add power then upgrade the brakes. Its annoying to see VW running more boost and using stock brakes...and then they wonder why their torque steer wrapped them around the tree.
Old 07-10-2013, 11:14 PM   #5
Chewie4299
Spaceman
Chewie4299's Avatar
My thoughts exactly.... who determines the appropriate arbitrary number?
How can Stage 1 be a catback and drop in but then also be a turbo kit.
As for the brake argument. I'm a proponent of upgrading brakes, don't get me wrong, but I've never understood the point of view that upgrading power also needs to mean upgrading brakes...
I mean, in my mind, let's say I go with the AVO turbo. A solid power increase. But it's a DD, I'd like to track it but I don't have any experience and, at the moment, time. So I may accelerate faster when I feel 'frisky' but I haven't added any significant weight to the car and I've not increased my top speed nor am I spending any time near the current top speed. I'd like to also upgrade my brakes but for the purposes of tracking my car NOT because at 250whp my current brakes are all of the sudden made of paper mache.
Old 07-10-2013, 11:20 PM   #6
dem00n
dem00n's Avatar
Drives: Scion FRS
You're still accelerating faster, if you had a 0-60 time of 6.0 secs and then you added power and its at 5.0 secs then you have increased the power quite a lot in a small car, even a small increase of 50 WHP is a lot is a "light" weight car like this. Stock brakes won't be as adequate with increased power, even if your not going to track your car. Not saying anyone has to go with a full brake kit and etc, but upgrades pads and tires can go a long way.
Also if i'm doing the same sort of autocrossing and i'm getting to the corner faster then i did stock, the brakes will take more of a beating, so they should be upgraded.
Old 07-10-2013, 11:56 PM   #7
Chewie4299
Spaceman
Chewie4299's Avatar
Valid point
Old 07-11-2013, 02:27 AM   #8
PSJohnDoe
You should upgrade the brakes if you're driving significantly faster, you've made it significantly heavier, or you're braking much more often (spending time tracking your car where brake fade is likely). It doesn't matter how fast you got to 60, if you're not braking more frequently and the car is relatively the same weight it's not a change to braking conditions.
PSJohnDoe is offline   Reply With Quote
Old 07-11-2013, 02:31 AM   #9
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I'm working on stage left right now, just a few more bolts and crush washers needed
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 07-11-2013, 05:38 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
Three drums and a cymbal fall off a cliff.
Ba dum dum tssss.
The Following User Says Thank You to Calum For This Useful Post:
akuhei (07-12-2013)
Old 07-11-2013, 07:51 AM   #11
FR-S Matt
Stickers are the key to moving up stages quickly. You're all doing it wrong.
The Following 3 Users Say Thank You to FR-S Matt For This Useful Post:
Chewie4299 (07-11-2013), Mike86 (07-11-2013), SkAsphalt (07-11-2013)
Old 07-11-2013, 08:05 AM   #12
nalc
Drives: 13 BRZ Limited 6MT GBS
Why? Do you floor the gas pedal with the car in gear every time you are braking? How does power have anything to do with braking performance?
When you've pushed the clutch in and you're braking, it doesn't matter if your engine has 50 horsepower or 500 horsepower, the engine is doing anything.
Sure, if you're racing, you will have your brakes fade sooner simply because more power means that you're reaching higher speeds before the onset of braking, but that's a situation that's only going to happen on a track.
Grippier tires, if anything, are going to do a whole lot more for braking performance in street driving than any big brake upgrades. Stock brakes are capable of locking up the stock tires, you think that bigger brakes could somehow do anything better than that? Only reason for them is that they'll laste longer before fading due to heat, and that's a track problem.
nalc is offline   Reply With Quote
The Following User Says Thank You to nalc For This Useful Post:
Old 07-11-2013, 08:32 AM   #13
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Shit. I knew I was missing something!
Vendors: Please acquire me a sticker group buy.
Nightbringer is offline   Reply With Quote
Old 07-11-2013, 08:46 AM   #14
leon78
leon78's Avatar
Drives: 13 Whiteout
Im stage TFA....Total Fucking Awesomeness!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Racecomp BRZ after 120 days. STAGE 1 complete. Racecomp Engineering BRZ Photos, Videos, Wallpapers, Gallery Forum 35 10-23-2015 05:45 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 04:57 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
Complete Front Stage Upgrade for FR-S/BRZ JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 03-22-2013 12:06 AM
