Old 05-13-2013, 07:51 PM   #29
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
I'm at the Toyota dealership right now and the service tech said that's the wrong part number. Did I miss something about this being brz only
Edit shit. Is there a different number for the frs? Cuz I have the shit in my frs as well and the techs here are dumb :-(
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
bdanisi is offline   Reply With Quote
Old 05-21-2013, 02:58 PM   #30
fledonfoot
Drives: Asphalt FR-S
The correct Toyota part number is SU003-04628 according to the part I just ordered for myself at work.
fledonfoot is offline   Reply With Quote
The Following User Says Thank You to fledonfoot For This Useful Post:
captainzib (02-11-2014)
Old 05-21-2013, 03:12 PM   #31
Hanakuso
I wish they made this a recall instead of the TSB. I rarely use my windows so by the time this problem arises I might be out of warranty
Hanakuso is offline   Reply With Quote
Old 05-21-2013, 08:19 PM   #32
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
As long as you can duplicate it I'd go ahead and get it fixed. Recalls are significantly more costly than TSBs which is why that won't ever happen.
Subie is offline   Reply With Quote
Old 07-10-2013, 08:07 PM   #33
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
TSB Document
Here's the actual TSB.
michaelahess is offline   Reply With Quote
The Following 3 Users Say Thank You to michaelahess For This Useful Post:
Ammonia (07-18-2013), B L U E S L A T E (07-13-2013), Chee-Hu (07-10-2013)
Old 07-13-2013, 08:35 PM   #34
michaelahess
I just got mine replaced and so far it seems to be working consistently.
Old 07-13-2013, 09:11 PM   #35
ftc~brz
Done
Drives: WRB BRZ
Jealous! I tried multiple times to get the dealer to fix this and they told me they could not duplicate it. Funny I can get it to do it every time. I'm done with the the dealers here.
ftc~brz is offline   Reply With Quote
Old 07-15-2013, 08:41 PM   #36
michaelahess
I had a nasty argument with Subaru Corp trying to get a dealer 200 miles away to do the work in two days. Needed a few other TSB issues resolved like GPS, rear taillights etc.
Told them I only had those two days to get this done and it would be over a year before I could get the car back to a city with a Subaru dealer. It was the truth. And it worked.
Actually I think the dealer may have broken the rules by ordering my parts ahead of them "verifying" the issues. But I put enough pressure on them and hounded Corporate enough I guess. Also complained about the crappy HU, not sure that went anywhere though.
They ended up only taking about 4 hours to do all the work as well!
Old 07-18-2013, 10:03 AM   #37
STV3
Señor Member
STV3's Avatar
Just got my switch changed at toyota (or atleast they said they changed it) and same problem
They told me that this is a known problem and they should be releasing a reflash...
STV3 is offline   Reply With Quote
Old 07-18-2013, 12:18 PM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
A reflash, haha. Ask them to show you the old switch if you don't trust them. A reflash will definitely not fix it. The logic is not in the ECU or anything that is "flashable".
Old 07-18-2013, 12:56 PM   #39
michaelahess
Did the paperwork they gave you show the new part number? If they did it right it should, assuming they didn't just throw out the new switch and take their warranty money and run.
Old 07-18-2013, 01:39 PM   #40
STV3
Señor Member
STV3's Avatar
Yeah I've never heard of anything like that before. He said he had one guy come in that had his pass window going up and down randomly, even with the car off. He said he came out one morning and the pass window was down. Im guessing the real story was that the auto up didnt work and he thought it did so when he came back out the pass window was still down. Thats def happened to me before I realized there was a problem.
You know what I honestly didnt really look at the paper work because I was pretty annoyed. I also asked them to program the auto off feat for the headlights to 30 secs instead of the full 20 mins that it comes with from factory and they told me they were going to do it, it was on the work order and they didnt do it. So when I decide to go back I'll have them do it for me right on the spot since it only takes a min or so.
When I get off of work Ill check the paperwork and see what it says. I also am probably going to pop off the door panel myself and see if the switch has the new part #.
Old 10-15-2013, 02:49 PM   #41
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
Tried getting this done at my local Toyota dealership and they wouldnt do it =T
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 11-03-2013, 03:14 PM   #42
Garstang
Garstang's Avatar
Drives: FRS
Okay I am really confused. I have a FRS what exactly is the problem with the window switch. I have having a brain fart.Help
Garstang is offline   Reply With Quote
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 02:25 AM
BRZ jammed window issue/blinking auto light? Superhatch Issues | Warranty | Recalls / TSB 28 02-15-2015 06:45 AM
Passenger window stuck. Marshman Issues | Warranty | Recalls / TSB 6 03-08-2013 08:39 AM
Passenger Window Switchs Out LarryGP Issues | Warranty | Recalls / TSB 10 11-13-2012 07:04 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 01:32 AM
