Old 12-30-2011, 12:12 PM   #71
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
And the car is not heavy so the brakes are a tad bit overkill.
anyone know if these are subaru brakes btw? on the FR-S or are they toyota? if they are toyota i wonder if they used the celica GT-S brakes again.
Syldrin is offline   Reply With Quote
Old 12-30-2011, 12:18 PM   #72
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Wasn't the GT-S 5X114.3 .....
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-30-2011, 12:20 PM   #73
Syldrin
Troll Feeder
Syldrin's Avatar
i don't think so. the first gen tc has GT-S brakes and we roll 5x100
Old 12-30-2011, 12:21 PM   #74
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by [[|==86==|]] View Post
Opps I meant rotors. Well if you want to get specific, what about the lines, pins, and bolts? hahahah just kidding.
The lines work with the STI calipers, so should the caliper bolts. obviously the caliper pins/pad locking stuff is specific to the caliper and should come with the caliper :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-30-2011, 12:21 PM   #75
JDLM
JDLM's Avatar
That's right I had a friend try the wheels off my old IS and was getting frustrated
Old 12-30-2011, 12:21 PM   #76
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They are WRX front, Legacy GT rear.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-30-2011, 12:26 PM   #77
Syldrin
Troll Feeder
Syldrin's Avatar
with STI hard lines and forester flex lines? :P
Old 12-30-2011, 12:28 PM   #78
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Hard lines on brakes don't work that well past the wheel wells :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-30-2011, 12:29 PM   #79
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The brakes belong to a much heavier and powerful car eh? I love this news!!! My RSX have brakes that's more fitting for a yaris or a smart car. It's a pile of crap.
SUB-FT86 is offline   Reply With Quote
Old 12-30-2011, 12:47 PM   #80
delongedoug
Drives: 2.5 RS daily, Evo 8 track
Location: A little town called none of your goddamn business
Originally Posted by wcbjr View Post
I can see those brakes being useful when 2800 lbs is being stopped with 8.5" and 9.5" tires.
Then you don't know how brakes work.
delongedoug is offline   Reply With Quote
Old 12-30-2011, 12:50 PM   #81
Racecomp Engineering
More pistons does not necessarily mean more braking torque. Rotor diameter and total piston area are key for that. More pistons are used for better feel and pad wear, and sometimes to increase piston area, but not always. These brakes are huge, no doubt about that but this is clearly more of a show car so don't worry about it.
Again on the brakes...I would be wary of slapping on a set calipers designed for Subaru since they will be backwards and you'll have nasty uneven pad wear due to the differential bores. It may be possible to do it the right way and swap the hardlines and bleeders around but I have never needed to try.
This is a car put together in a limited amount of time and I wouldn't put too much thought into why they did what they did. 19 inch wheels and big ass brakes look good and they had some laying around....that's all. A wheel spacer/hub conversion for this particular car wouldn't surprise me. And honestly kudos to them for putting this car together in a week....that's pretty darn impressive.
What this car means is that off the shelf coilovers and camber plates "fit" which is helpful for development. It looks like the lengths might need to be adjusted but their set is adjusted a little low so maybe they're the same. Valving and spring rates should be changed obviously.
- Andrew
Old 12-30-2011, 01:24 PM   #82
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Exactly. Better feel translates to more ability to modulate, so I usually just say better modulation, but same difference
Rotor diameter at least will increase with any of the brake upgrades being discussed. I think one potential (and cheap) upgrade may be Legacy GT fronts (12.4" rotors) and an adapter to move the calipers out, or LGT caliper brackets using the BRZ calipers, or LGT calipers, I believe the piston sizes are the same on those so they should be L/R swappable sliders that way. Any upgrade may be pointless for anything besides looks though on any remotely stock power level track car.. and for every street car.
someone said the STI used internal transfer tubes so unless they have a provision for the bleeder on either end (some calipers do, some don't as I'm sure you know) then the STI "upgrade" may not be all that ideal.
- Andrew
Good and bad.. good in that it makes development easier, bad because some less-than-stellar companies will just slap a "BRZ" or "FRS" sticker over the "WRX" sticker and sell them as a "tuned system".
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-30-2011, 01:32 PM   #83
nixeighty6
nixeighty6's Avatar
Drives: Faster than you!
Originally Posted by KidWonder View Post
Why do the seats look like they're covered in leather/alacantra seat covers?
Originally Posted by JDLM View Post
looks like a factory seat w/ inserts sewn into leather and pulled over the factory seat cushion and frame
my bet is on factory..
why would greddy, which only had one week.. do seats, head rests, steering wheel, dash insert, shift boot, brake boot? .. that steering wheel really looks factory to me.. they are a performance company, why even touch the interior?
:57 to 1:07 in this vid
[u2b]Bx8w4Dxx7J4[/u2b]
nixeighty6 is offline   Reply With Quote
Old 12-30-2011, 02:35 PM   #84
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
the seats (and the seats only) are a custom upgrade done by GReddy. there's a video where Kenji Sumino (GReddy pres) talks about this.
btw, take the youtube code out of qoute to get the video to show.
poormans_LFA is offline   Reply With Quote
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
Greddy Scion FR-S Coverage from FR-S reveal night Harinjo Scion FR-S / Toyota 86 GT86 General Forum 90 01-14-2012 12:02 PM
Scion FR-S Reveal - Interview, GReddy & GT5 Data logger NikostC FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 12-05-2011 11:34 PM
Greddy Set to Build Scion FR-S for Ken Gushi in 2012 Kids Heart Scion FR-S / Toyota 86 GT86 General Forum 8 11-29-2011 09:22 AM
