#85 | |
Drives: Raven FRS
So in that case, I would over simplify thing by using a blowoff valve connect back to the intake and then you go full current on the motor depending on the throttle position(70-100%), with enought charge capacity, you should be able to do short acceleration when passing. That simply thing a lot as no real control is needed and you sure not to over or under pressurized the intake. |
#86 | |
Drives: Raven FRS
#87 |
we want the end user to decide that. we just provide a way to indicate what he wants, via a boost target map. he's free to set it up any way he chooses.
#88 | |
Drives: Raven FRS
, but if you want useful info from other, it need to be clear to other what the goal are, if not, it start to be a mix up useful and not so useful info that can cloud solution.Sorry if I am to strait forward to what can done to reach goal, its because of the type of work I do, project managing and design. |
#89 | |
| The Following User Says Thank You to jamesm For This Useful Post: | solma (07-10-2013) |
#90 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
But I've only been doing this ~20 years, so maybe they are out there. My first supercharger was the old ball drive paxton. Made 5 psi., and I wanted every single bit of it lol. I bet that say you got the controls down, and the blower was capable of 4 psi at bottom, 2 psi at top, and you spent hundreds of extra dollars on limiting boost, 99% of guys would just end up running it full on anyway. Once you drive it, you will understand. This control stuff would be cool if this thing could make 20 psi, then you can tailor a boost curve to deliver a cylinder pressure curve that the motor would be happy with.... So the control is actually the very very easy part. Even if it was a simple open loop duty cycle table with rpm and tps or mph as the axis. There are ecu boost control devices on the market that can be mapped on a laptop to do it, for like $250. The hard part is generating enough boost to where someone would actually want it tapered down. ie, the mechanical and electrical parts. |
| The Following User Says Thank You to Toma For This Useful Post: | neutron256 (07-10-2013) |
#91 | |
it's never a good idea to start a project without considering future advancements in the domain. this is why game developers write game engines to exploit hardware that won't be available for years to come. i believe it is important not to presume that the state of affairs today will be the state of affairs 5 years, or even one year from now. it's quite possible that you'll have your 20psi within a reasonable timeframe, with all of the money being dumped into battery research these days. in any case you'd want to be prepared for that eventuality. taken into consideration with the fact that such a system to control boost has other benefits outside the scope of this particular argument, and that the development effort is relatively low compared to the other elements involved (as you alluded to in your post), it seems like a no brainer to do it right and do it once. |
#92 |
Ahhhhh. We see it two different ways. Takes 150 amps to do what the Phantom does now
.. 1.5 psi at the top, so I see generating boost and airflow as the realistic limitation. Here and now. Control system would be easy if it was required. You think the control system Is hard..... but boost and airflow will come easy. A Vortech blower moving 750 cfm at 1.7 bar takes 40 hp to turn it. Convert that to electrical draw and tell me how soon you think it will happen. |
#93 | |
btw i have sitting next to me an 11hp brushless motor that is smaller than a beer can. i run it on a battery i can charge at 5-10c. it's not that far off, especially if you're willing to pay for it. |
#94 | |
| The Following User Says Thank You to Toma For This Useful Post: | jamesm (07-10-2013) |
#95 |
Drives: 2013 FR-S whiteout
I think an onboard MAP sensor would be pretty cool if they can be found for cheap enough. At a minimum it would be nice to be able to be easily scaled to different MAP ranges.
#96 |
Drives: '13 GBS Subaru BRZ
You can find all kinds of MAP sensors on eBay for as little as $10. The other option is to just tap into the existing MAP sensor.
#97 |
I've added the MAP & TPS sensor connector types to the OP along with a good link for where to buy these.
This is useful if you want to build a wedge to tap into the sensors without cutting any wires.
#98 | ||
Speaking of power....and this is a bit off-topic but what about a TOUGH battery box for LiPo/lifepo4 with self-powered cooling and ventilation...Just thinking out loud. Quote:
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 05:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 02:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 02:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 09:20 PM |
